Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 05-10-2013, 03:28 PM   #1
TNR Performance Parts
TNR Performance Parts's Avatar
TNR Performance Parts is an unknown quantity at this point
Synapse - 40mm & 50mm Wastegate's w/Flanges available @ TNR Performance Parts
Synapse Synchronic Wastegate's Available at TNR Performance Parts
The Synchronic Wastegates feature 6 different boost settings per spring combination. Fine tuning the boost level is also available using the preload adjuster. Both the 50mm and 40mm gates now come with 2 preload springs and 2 main springs to suit a wider range of boost levels right out of the box. All wastegates also come with 2 different diameter valve seats to combat boost taper/creep, and a high temp, high pressure sealing ring for installation without having to use gaskets. Units come with a nitrited, one piece, forged, tooling-grade crucible steel valve designed for a low coefficient of thermal expansion. The nitriding has resulted in a significant reduction or eliminiation of chemical deposition on the valve surface, and a higher surface hardness.
50mm wastegates are designed to be used with 2.5" V-Band clamps, and 40mm wastegates are designed to use the common 38mm 2 bolt flange.
Older setup with the Synapse Wastegate installed on our CA18DET.
Newer setup with the Synapse Wastegate on our CA18DET
Please PM us for price.
TNR Performance Parts is offline   Reply With Quote
ca18det, sr20det, synapse, wastegate
