Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 11-11-2012, 11:17 AM   #1
RARE-SNARE
RARE-SNARE's Avatar
RARE-SNARE is an unknown quantity at this point
MEGA Low Prices on KSPORT Pro Damper Systems!!
Check out our latest deals on KSPORT Pro Damper Coilovers! Our prices are too low to advertise.
Please PM MODEL and ZIP CODE for a quote.
Product Information
Ksport Coilovers Kontrol Pro Damper System
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber can be adjusted via the Pillow-ball Top Mounts, which means no additional Camber Kits are needed.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride. Contact Us with any questions.
Features:
  • 36 levels of adjustable damping.
  • Made from high quality 6061 aluminum with T6 for increased hardness.Compression/Rebound adjustable.
  • Adjustable spring perch for height adjustment.Adjustable body allowing maximum suspension travel.
  • Pillowball top mount with adjustable camber (not available for some models)Monotube high pressure design reduces oil leakage.
  • Electroplated body for protection from corrosion and rust.
wheels// suspension// expression
KSPORT | STANCE | WORK | ENKEI | BRIDE
www.rare-snare.com
Facebook Twitter
PayPal:[email protected]
★★ ENKEI BLOWOUT SALEKSPORT Pro Damper SystemsVarrsToen BLACKOUT SALE ★★
RARE-SNARE is offline   Reply With Quote
Old 11-11-2012, 12:36 PM   #2
arg23
arg23's Avatar
arg23 is an unknown quantity at this point
PM sent,
Thanks in advance.
the clock IS ticking!
arg23 is offline   Reply With Quote
Old 11-11-2012, 12:59 PM   #3
RARE-SNARE
RARE-SNARE's Avatar
PMs replied to!
www.rare-snare.com
Facebook Twitter
Old 11-11-2012, 06:46 PM   #4
RARE-SNARE
RARE-SNARE's Avatar
All PMs replied to!
www.rare-snare.com
Facebook Twitter
Old 11-11-2012, 09:03 PM   #5
Srsil
Srsil is an unknown quantity at this point
Pro for a s13 98512
Srsil is offline   Reply With Quote
Old 11-12-2012, 03:09 AM   #6
pancakes562
pancakes562's Avatar
pancakes562 is an unknown quantity at this point
sexxxxxxxxxxxxxxxxxyyyyy
pancakes562 is offline   Reply With Quote
Old 11-13-2012, 06:52 AM   #7
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
rebuildable?
roninwon is offline   Reply With Quote
Old 11-13-2012, 08:19 AM   #8
boosted ep3
boosted ep3 is an unknown quantity at this point
95 S14 to 31316
boosted ep3 is offline   Reply With Quote
Old 11-13-2012, 11:46 AM   #9
RARE-SNARE
RARE-SNARE's Avatar
Originally Posted by roninwon View Post
rebuildable?
Yes sir. Replacement parts are available directly from KSPORT.
www.rare-snare.com
Facebook Twitter
Old 11-13-2012, 04:58 PM   #10
RARE-SNARE
RARE-SNARE's Avatar
All PM's replied to!
www.rare-snare.com
Facebook Twitter
Old 11-15-2012, 04:44 PM   #11
RARE-SNARE
RARE-SNARE's Avatar
These are priced to MOVE!
www.rare-snare.com
Facebook Twitter
Old 11-21-2012, 02:10 PM   #12
LOVERboy
LOVERboy is an unknown quantity at this point
Send a message via AIM to LOVERboy
Pricing for a set for s14 shipped to 91730 please
Sunny D.-
LOVERboy is offline   Reply With Quote
Old 11-29-2012, 05:30 PM   #13
RARE-SNARE
RARE-SNARE's Avatar
All PMS replied to!
www.rare-snare.com
Facebook Twitter
Old 12-12-2012, 04:57 PM   #14
RARE-SNARE
RARE-SNARE's Avatar
All PMS replied to!
www.rare-snare.com
Facebook Twitter
Old 12-12-2012, 05:10 PM   #15
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
2013 corolla shipped to 92336?
Old 01-23-2013, 05:50 AM   #16
RARE-SNARE
RARE-SNARE's Avatar
All PMs replied to!
www.rare-snare.com
Facebook Twitter
Old 02-27-2013, 05:27 PM   #17
RARE-SNARE
RARE-SNARE's Avatar
All PMs replied to!
www.rare-snare.com
Facebook Twitter
coilovers, coilovers for sale, ksport, ksport pro damper
