Old 10-31-2012, 08:51 AM   #1
Teigen
Teigen's Avatar
Teigen is an unknown quantity at this point
Question Turbocharged BTCC SR20 - 1000bhp
the build thread of my slow going silvia.
Spent a lot of money to get real gt300 parts, these are hyper rare as there was only made 3 cars and most of the patrts are trashed trough small crashes etc.
build started out as sleeper but now is a fully racebred timeattack car
1000hp, sequential gearbox, 380mm brakes, gt300 real bodykit parts, magnesium rims, btcc engine ++
Have fun reading trough the shit
*** CURRENT STATUS IMAGE ***
ENGINE SPEC LIST
Cylinder Head
P10 Primera BTCC Head
Supertech Dual Valve Spring
Supertech Titanium Retainers, SR20
Supertech Nitrit Titanium Valves BTCC size
Custom designed to this engine after flowtesting, manufactured by order from KM cams
CNC Adjustable Cam Gears
Mazworx 1/2" Head Stud Kit w/ Dowels
Mazworx SR20DET Headgasket, 90mm Bore and 1/2" Studs
Ported out oil ports for better oilflow
NISSAN CNC'd combustion chamber, later CNC'd by me for 90mm with low squish
Block
S15 RWD turbo Block
Darton Sleeves inserted, bore 90MM
Oil supply: DrySump system
1/2" main studs mazworx
4 Custom made on order CP Pistons (set of 4) -- 90mm 9.5:1 (Gasported)
Custom Connecting Rods, SR20 Crower
Wiseco 90 mm Billet Crankshaft
Rod Bearing 19,5mm Special made
ATI Super Damper
Waterpump - Dual Electric Meziere drag race waterpump
Selfmade drysump oilpan
Ported oil ports to match cylinderhead
Bore & Hone w/ Torque Plate -- 90MM
Resize Line Bore
Resurface Block & Oil Pump
Oil Groove Machining, SR20
19mm Rod Bearing Machining
Engine Misc
Mazworx Hallsensor Kit
Custom oil catch tank with -an16 fittings
Sand blasted alternator +powder coated alternator bracket
Lamborghini Black Whrinkle paint Valve Cover
NO OILCAP
Rocker Studs, Rocker Washers, Stainless Dome Nuts
INDUCTION
Exhaust side
TO BE ORDERED - Custom Borg Warner turbo
Dual 40mm Turbosmart Comp gates
Custom 4 inch aluminium intake pipe
Custom braided turbo oil/water lines
MLS 4 layer metal exhaust gasket
No turbo flange gasket
Cold side
Custom WRC Plenum
Customised Internal Throttle Bodies (ITBs) (4 x 46,5mm)
Custom aluminium cold pipe
-An fittings for IM
wiggins clamp
FUELLING
4x Injector Dynamics 2200cc Injectors
4x Injector Dynamics 1000cc Injectors
Stock fuel tank (for lowest weight point)
Walbro 255 Inline lift pump
Triple Bosch 044 external pumps
5ltr surge tank
2 inline -an 10 AEM fuel filters
Nylon braided lines with AN fitting whole fuel system
Braided lines feed -an 10 return -an 8
CNC dual fuel rail
Aeromotive FPR
DRIVETRAIN
Prototype Hoolinger/Quaif/grex sequential gear (6 gear)
Triple plate carbon clutchF1 custom flywheel
Braided clutch line
Carbon tail shaft
Carbonetics Carbon LSD 1,5 way
Custom Engine and Trans mounts
Code:
THE STORY:
 First I can write a few details about myself
 My home country is Norway, which somehow happens to be a place where JDM parts are not floating around and something one stumbles across every now and then :sadwavey:
 My car is a 95 s14, bought it about half a year ago, during spring time here.
 The car had BOTH nats 1 and 2 installed, as well as 3 GM market aftermarket security boxes. car was DEAD... totally
 Car was built in sweden for previous owner as a drag car with 5-600 whp after what i've heard with some piggyback shit system, thats about the specs I know about the car.
Here is a couple images from the previous owner, as it was before mounting the Skyline rear wing
 When I finally saved up the remaining money (No, Silvias aren't thrown at you around up here, and pretty rare) and took a tralley and picked it up it it had a sr20det blacktop swap with 112000 on it, not modified at all, except t28BB turbo which is standard in Japan
 tried making it ignite for weeks but got tired of it.
 took some tools and started removing OEM ecu and every wiring which was not made by Nissan. Resulting in having only blinkers relay and wiring for the front wipers left, of all the wires going to the engine bay :bowrofl:
As I am having experience with Autronic standalone systems I decided to get one for my SX as well, still in thinking of having a pretty non modded s14 with just a litte more boost than regular....( I bet you all is aware of the trap (wont tune it a lot)
 Time flies and plans change, bought a pretty good top mount mani, JUN intake, 740cc JECS injectors, pretty cheap China turbo with 84 ar exhaust and 70 ar compressor housing. + some other small stuff
 plan was maxing the engine @ original parts inside both cylinder head and block, except some Brian C stage 3 cams ( got them for free with the intake so why not.  After a couple weeks working with it, mounting stuff and such things began getting ready for startup, with having barely 2 months left before season was totally over for the 2012 in Norway.
Trying to make it to the last of the Norwegian Gatebil series, one weekend of racing and girls, just the startup itself was missing.
 Fitted with Autronic and walbro 255 inline pump things were about to be ready for my m8s dynapack.
 Then some sad stuff happened, cranking it around a few rounds and it stopped. Removing a plug and E85 floated out of the plughole! Actually all 4 cylinders, Intake mani, Exhaust mani, FMIC and a bit of the exhaust was filled with E85. Something had happened to the injectors and fuelrail and the pump literally did its job, pumping a lot of fuel!
 Being a bit sad and down, I cranked it empty in order do try saving my new Agip racing oil from being waste but I was already too late. the next day my mates went off to the track and there was nothing I could do. Was almost broke anyway so guess I saved money On not going to a racetrack and get more inspired to spend more money on my car hehe
Engine out!
Starting to take apart the head
Head off
Most cylinders looked good but 1 piston had a few markings onto it
Bottom demount
and now, putting apart a little of it as this block goes to Cylmo for having Darton sleeves installed and later being a "showoff" on thei stand on norways largest motor show
 Bye bye srblock!
Will welcome it back soon, as a SR22 block with sleeves inserted :) So that story is not over for now.
Here is me looking like an idiot next to it @ the show
The past months I've come across a rare sr engine, Will throw up a picture of it. Some of you probably recognizes it?
Can tell a few of the specs which if done to the engine after its original primera usage
Darton sleeves, bored to 90mm
Mazworx 1/2 cylinder head bolts
The cylinderhead floeated pretty good as a N/A, but was sent to DTE racing in Sweden for more modifications. (This guy " Dr. Ernie" made the cylinder head and cams etc for Hotwok cherry, as well as Madtech s14. both cars made more than 900 whp)
From his measurements and work Kelford Cams made the cams and basicly everything in the cylinder head is made to fit eachother and my Garret GT4094r, I got both 95 ar exhaust and 85 ar exhaust for it.
The btcc head
http://i1075.photobucket.com/albums/w435/Mats_Teigen/IMG_3868.jpg[/IMG]
Dry sump is removed, as it might would not fit. Got a custom oilpan made, as the Greddy oilpan isn't good enough with aggressive grip driving
Gearbox is a new Tremec TKO600 with Libery Gears parts, converted to Dogbox, as well as longer splines on the shaft in the bellhouse so that the 2-plate tilton will require some grip.
Making it fit wasnt that hard in the end, with a Custom made exhaust manifold from Greddy things began looking good. I have all the time been sure about having my engine mounted in level, also the bellhousing on the gearbox is welded for that. On the image below you can see that it might doesnt get that bad anyway even with OEM engine mounts. The shifter would tilt a bit towards me but maybe it only is a good thing having it closer
First try
Emptied bay again. And no worries, Will be totally sexy when done, with new cool things and some nice paint
Inside the car I am working to make the OMP seats fit, would love to thev a slider underneath them but We'll see. All wires you can see in the image is removed and things are getting sexy in there now
Another problem I met with having this engine mounted is the FWD CAS, which would hit my firewall. This problem is fixed without cutting my dear Silvia, getting an SR20VE cas, which would fit the head and also is not thicker than an OEM rwd cas.
Beautiful little Silvia next to my mates old Opel. After 4 Opel CIH engines hazards, he decided to build and Volvo 8v turbo... (I dislike volvo hehe)
The Turbo I have decided to use on the right, GT4094R, I have both 85 a/r and 95 a/r exhaust to try out. Here is some cylinder head bolts, guess which of them I got installed
Last thing I have started with is lowering the whole rear setup
Will be fitted with everything that can be exchanged and will work good with grip driving. Was an easy job, took me about 1,1/2 - 2 hours as I have never done this to a s14 before,
Will update this post daily with images and info about whats been done
Cheers
Teigen
Don't PM me asking for parts
Teigen is offline   Reply With Quote
Old 12-31-2012, 10:32 PM   #2
Teigen
Teigen's Avatar
Sorry for late Update, was only updating my build thread in the Premium members section. Copying and pasting what I have wrote there:
11-23-2012, 05:56 PM
So, there have actually been some nice updates to the car, I will throw up some images and write a text to each of them, Enjoy!
The engine bay is these days totally clean and most paint is matted or removed, by hand of course for the best result! It's not awesome work but one gets used to it, and a baby like this needs some love
Removed everything, including that I drilled out the bonnet/hood locking device to, as I have sanded that and it will get a slightly different color than the rest, but thats just a minor detail!
80% of the holes in the engine bay will be welded and then grinded down to the invisible! I don't want anymore holes in my chassis than I have to! Also in the "Do, or should not" weld the seems of the front towers and such, most likey end ut with doing it to get more stiffness to the chassis.
Original battery placement was the only rusty place on the whole car, believe it or not! Of course the battery will be place rear, on the opposite side of the driver to obtain weight balance as I guess I will most likely drive alone with no passengers, at least when doing timeattack etc.
The fusebox is also removed, along with absolutely all wires, and every wire in the engine bay will be remade to look as nice as possible and clean! Fusebox will be placed in the rear, + I will try to make a custom fusebox, as half of the fuses and wires is removed as I no longer need them, most likely end up with some aluminium stuff
the 2 pieces of metal which I cut away, on both sides in the front of the bay was too ugly, and I want things to look clean and therefore I am making new plates to weld in there. Also will make some custom piping to the intercooler.
Regarding the interior, most is removed as of cleaning up wires etc, and the mid-console is going to be the place with the switches! The car is meant to be a sleeper, and after hours of thinking I got this idea of making the switches in the "box" in the back of the mid-console.
Anyway, had to make the switches fit in there, and room for wires and such, so therefore I made a plate inside the box/room thing.
Painted the plate in the special Wrinkle Paint, used om lambhorginis and stuff, this is the same paint as I use on my rocker cover on both my engines, as well as the turbohousing and plenum. This will be invisible when the box is closed, but once I open it, voila! a ton of switches, for things like Antilag, Launchcontrol, Fans, waterpump etc etc
Another thing that is solved is the Oil system. As you mught know the BTCC engines had dry sump, but this system requires some space and I the engine would not fit with that on. Therefore I built wetsump, and had Moroso make me an Oil pan after my measurements, could have used a Greddy one, but those just ain't good enough. Also, I have mounted an Accusump! I am not going to explain how it works, but it keeps oils pressure on top even if the pump would fail in heavy corners. you can google it and you will Understand. Image coming!
Now, over to the sexy part!
Finally had them Internal Throttlebodies, aka ITBs mounted yesterday. These are ported 4 x 46mm throttlebudies, one for each cylinder. This will increase throttle response and such, but mostly this is helpful when having natural aspiration.
Cheers, Will write more soon. If you have any questions, or would like more photos, feel free to ask!
__________________________________________________ _________________________
Yesterday, 01:34 PM
Originally Posted by PerilousActs View Post
How exactly did you come across that head?
been looking for decades, until I found it by visiting a Nissan Guru for buying a few parts and by coincidence saw he had one.
UPDATE:
For the last months it's been going slow, but I have finally placed a milestone in my little project.
after removing everything from the enginebay, yes, everything except the windshield wiper engine, I was not able to remove it
When things were strapped I encouraged to start cutting into my dear Silvia, at first removing the metal underneath where the batteryhousing was, as seen on the pictures in the earlier post.
STarted welding things done, spotwelded some parts, filled most smaller holes, replaced some metal, seem welded towers and grinded down
When that was done, maybe the worst part came, sanding everything down, then laying the filler, sanding down, adding filler, sanding down... hehe yes, taking shitloads of time. I would say that when I felt done, I was happy, because it is not something I would like to repeat!
Hung up some tarpaulins around the car and washed the enginebay with thinner a couple of times, waited for it to dry then added the base filler/grey paint.
The next day, got paint made in the paintshop and went up to the garage for painting.
Laying the color done:
Adding the last layers with transparent gloss
And voilÃ*, things looks so much better. Pictures below are after about 15 hours of dry
Letting the baby get a feeling of the "new" home, I could not stand having an engine like that, bolted up in a dirty and bad-looking enginebay
This time mountined it with the gearbox mounted to the engine, but surprisingly the paint was not scratched any places!
Ordered AN fittings and steelbraided lines for 1087 US dollars with todays currency! Must admit it's in imo shit expensive for AN fittings, at least here in Norway.
Bought 2 x Meziere waterpumps, they are quite big and heavy, so I guess they will flow the water pretty fast. Each pump delivers 22 gallons trough the engine.
Also got fabbed an expansion tank for the radiator in aluminium.
Will update this in mid January, hopefully more things are done then
HAPPY NEW YEARS EVE!
Old 01-01-2013, 07:41 AM   #3
Teigen
Teigen's Avatar
Going to post up a few pictures of the engine and components. Feel free to ask anything
Here is my custom made twinscroll exhaust manifold, inside the collector, it's made in a special way so it starts spinning the air aldready before the turbo.
To make shit hold some serious boost, one have to get rid of the Normal size studs for head, so I had this as an replacement, 1/2"
Picture of the block with new bolts, and Dartons inserted + powder painted
Cylinder head
Old 01-01-2013, 05:18 PM   #4
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
BTCC head is from what motor ? it sounds like its similar to a NEO VVL but it has a different VC.
interesting build though, keep up the awesome work!!
Old 01-01-2013, 05:23 PM   #5
drscooper
drscooper is an unknown quantity at this point
very interesting and nice man! keep up the good work! sounds like its going to be a beast!
drscooper is offline   Reply With Quote
Old 01-01-2013, 05:49 PM   #6
Teigen
Teigen's Avatar
Thanks guys, I enjoy (almost) every hour I spend on this project
Today i test-fitted the Mezeire water pumps, i have still not decided but I most likely will have one pushing into motor and one pushing into radiator, that way the system keeps up the flow all the way around. 1 pump is going to run all the time, and the second will start at a specific temperature, so the water flow incrases and temperature hopefully decreases a bit. Will also make an override button so that I can force 1 waterpump running all the time by using a switch, for like when engine is really warm and I stop the engine, waterpump can still run etc, or if it should get hot while waiting to get out on the track I can manually start the second pump so that it flows better when no air going trough radiator, except the fans.
By first look I thought this would be nice positions, but when I just held the radiator where it belongs I could see that it would not fit with the pump on the left side/ would make a messy and bad solution. So that is also something I have to figure out, the pumps are quite big and heavy so cannot mount then anywhere.
Also just took some old Silicone and pipes and made an early sketch of how the IC piping would be from turbo to the IC. The valve on the tower is the electronic boost solenoid for my Autronic ECU
The Engine was originally a BTCC (British Touring Car Championship) engine, developed by Nissan with the SR20DE as base in the 90s.
By the end they could produce up to 340 BHP and USABLE torque as a Non-Turbo engine in the Primera P10,P11 which was the car Nissan raced in the class.
http://www.youtube.com/watch?v=3jtLuIe3n6Y
http://www.youtube.com/watch?v=q4657veIQ1M
http://www.youtube.com/watch?v=2n8OTdbanJo
Old 01-01-2013, 06:04 PM   #7
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
That engine is gonna be a load of fun to drive
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 01-01-2013, 06:16 PM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Nice seeing the updates !
Old 01-02-2013, 06:24 AM   #9
Teigen
Teigen's Avatar
Thank you my friend, I will keep them coming!
Old 01-02-2013, 09:00 AM   #10
projectkouki
projectkouki's Avatar
projectkouki is an unknown quantity at this point
Nice build man! Can't wait to see the HP numbers!
projectkouki is offline   Reply With Quote
Old 01-02-2013, 10:05 AM   #11
Teigen
Teigen's Avatar
Thanks! I'm dying to get this done myself hehe.
Running with 1680cc injectors and e85, head flows for 1200, only problem is producing enough exhaust to get some serious BAR/PSI
Old 01-02-2013, 11:08 AM   #12
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
what are your power goals? what do you plan to do with the car once its done? and why go for such a huge turbo, sheesh!
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 01-02-2013, 11:29 AM   #13
Teigen
Teigen's Avatar
Want to test how far this little badass can go, everything is built to hold 1200 hp
Would been nice to see it make 1001 or something if lucky
Going to drive grip/ timeattack with it, and maybe I do some dragracing who knows. Also would like to sneak it into the public road in the summer, cruise a little and play those germans and amercan cars a lesson hehe no offend
Wont be much of that, totally illegal to bring this car in the public in Norway
Old 01-03-2013, 06:04 PM   #14
Teigen
Teigen's Avatar
Evening folks!
time for todays little update, havent done much but it's going forward as usual
Today I only had a few hours to spend so had to work a little quick, started the day rethinking of the placement of the Meziere waterpumps, where I am using 1 pump each side of radiator. After some thinking and measurements I found the best spot top place the pump that will push water into the radiator:
Spot's great and will give quite short passage for the water to reach the radiator, I can tell that It wont help anything about cooling if one have 30 cm of tubing or 10 meters. Will mount the aifilter close the the car's frame in the large hole i Cut there, will pass waterpump fine so wont be any trouble hitting that.
Another thing I did today was testmounting the IC and the radiator, the new radiator is going to fit fine and I will have lots of space for maybe a 3rd or 4th Fan between the IC and radiator, as the OEM Aircondition radiator is long gone
2x 12" fans
About cooling the engine's oil, I wont be doing the classic way of having an air-cooled oilcooler. Instead i picked a watercooler oilcooler made for the Industry, like large diggers and other machines. This is of very high quality and can hold up to 40 bars of oil pressure ( Cause it's bare for hydraulics) and temperature up to 200. Effectivity is around 6kw and This will work great. "MadTech" SR20 project used this as well, they made over 900hp in their S14A.
Having a problem using SR20 top feed, will need some fabrication to make this work!
Peace!
Old 01-04-2013, 02:57 AM   #15
MeSs
MeSs's Avatar
MeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura about
Another Norwegian Nice!
Awesome project! Maybe a stupid question, but wouldn't the itb restrict alot of hp?
2011 BMW F11 5-series and 2003 Nissan 350Z
MeSs is offline   Reply With Quote
Old 01-04-2013, 04:06 AM   #16
Teigen
Teigen's Avatar
thanks! Norsk? -
no it would not i think, whats your theory?
Posted from Zilvia.net App for Android
Old 01-04-2013, 07:50 AM   #17
silviavert
silviavert's Avatar
silviavert is a well-known jackass
Good Stuff
silviavert is offline   Reply With Quote
Old 01-04-2013, 08:16 AM   #18
Teigen
Teigen's Avatar
Originally Posted by silviavert View Post
Good Stuff
Thank you
More updates tonight
Old 01-06-2013, 09:23 AM   #19
Teigen
Teigen's Avatar
Rest of intake manifold test mounted, more pictures and a larger update tonight. + som more revealing of parts used on this machine!
Old 01-06-2013, 11:36 AM   #20
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
this thing is cool
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 01-06-2013, 03:14 PM   #21
TheRealSy90
TheRealSy90's Avatar
I love this build.
Such a good signature.
Old 01-07-2013, 02:13 AM   #22
MeSs
MeSs's Avatar
Originally Posted by Teigen View Post
thanks! Norsk? -
Stemmer det Godt nyttår! Hvis man fortsatt kan si det.
Ive just never seen a 8-900+ RB26 with the stock intake manifold w/itb.
Maybe the stock intake manifold doesnt flow that good.
Thats why i said "Maybe a stupid question". I wish i had a theory.
Old 01-07-2013, 03:10 AM   #23
Teigen
Teigen's Avatar
Originally Posted by bc. View Post
this thing is cool
Thank you!
Originally Posted by TheRealSy90 View Post
I love this build.
I love it too! Thanks
Takk det samme!
I have big faith in this, those are custom, not much stockish. + they flow more than a 3" single throttlebody. I have had this flow tested and it will follow. Cams are custom built for this setup, and although it looks original on the outside, it's not + Will earn 0.01 seconds faster throttle respond
Old 01-07-2013, 04:18 AM   #24
Teigen
Teigen's Avatar
Update
Sorry, got a bit late, but better late then never
So, I can start off by some more info about the gearbox, it's a brand new Tremec TKO600 with forged internals from Liberty Gears, a company that is specialists on these.
Also got DOG rings so I can shift gear without clutching if I want to, fast shifting etc. Anyway I will use the clutch tho, so used to it
Also have a custom axle with longer splines so that my twin disc Tilton get some serious grip. Using a twin disc on regular isnt helping much, when the rear disc isnt fully in contact with the splines....
Picture:
Also, had to make the gearbox fit the engine so I cut off the bellhousing of a Primera gearbox and made an adapter plate and voila, in the game.
About making the block stand some serious beating, it got inserted with some badass sleeves. Without sleeves, one can see that the aluminium in the top doesnt like the heat and beating. This picture is from Woken, a Nissan Cherry dragmachine, worlds fastest FWD under 9 seconds...
Inserted ones:
90mm bore to make it SR22
In the bottom, Using a custom made scraper for the crankshaft, so that the oil is removed to insure no trouble hitting the oil etc.
Exhaust manifold, EGT sensors.
ABout the fuelsystem, I am using a custom swirlpot, which is feeded by a Walbro 255 inline pump. It flows great for filling the swirlpot, actually a strong little machine
From the swirlpot to the fuelrail, the main pumps, Dual Bosch 044 is used. They build great pressure and is still delivering. Here is a graph of the Aeromotive A1000 pump compared to Bosch and Walbro
The clutch and Flywheel is a bit custom, dics are custom to ensure it handles heating well and not haveing to replace so fast.
The flywheel have been fabricated with a inserted plate to rub the clutch on, as the flywheel isnt something one inds everywhere It can be reused if the clutch fucks it up etc. The plate can easily be replaced.
Thats it for today folks, Hope you like the thread.
Best regards
Old 01-07-2013, 07:40 AM   #25
ali-d1936
ali-d1936 is an unknown quantity at this point
Awsome sauce! Lucky find With the head man, you norway guys build crazy machines
ali-d1936 is offline   Reply With Quote
Old 01-07-2013, 08:24 AM   #26
Teigen
Teigen's Avatar
Thanks man! Yeah pretty crazy, maybe there is like 20 left in the world maximum. I heard a rumor of 34 of them being made, I dont know if it is right. Anyway there wasnt THAT many BTCC cars for sure Definately having a piece of Nissan/Motorsport history in my Silvia.
Pretty expensive build, and parts are even more expensive up here as Norway have some ridicolous taxes and taxrates.
When paycheck comes its about 20 hours until its almost empty, only enough left for diesel to my car and bills hehe
Old 01-11-2013, 03:22 AM   #27
Teigen
Teigen's Avatar
more pics tonight. solved waterpump placement as well! cheers
Old 01-12-2013, 03:11 PM   #28
Teigen
Teigen's Avatar
Update
Updates
Let me start off with the OEM SR20 waterpump placement on the block. The OEM waterpump isn't flowing enough water trough to keep up with some serious horsepowers which again makes more heat to the engine. The pump simply does not flow enough! Here is an image of the inside of the waterpum placement on the SR20 block
As you see, it is a quite small opening for the water, whihc restricts the water flow. This opening makes a far less volume than the waterflow into the waterpump. So what I did to make sure things would flow good is to gently remove the "restrictor" with an airtool
Another thing I got in hand is a AEM water/methanol injection kit. For now I will not use it, but after the first dynosession I will read the logs and watch the numbers of every sensor in the angine and do some mathematic challenge and figure out if i would be a good thign to try this. I do not want to hazard this engine, cant just go to the local shop and order a new one lol
If I commit to use the injection kit it will be only when the tempratures reach a certain number. Does not want to be using this all the time, to experience what happens with too much pressure and the water injection tank runs out...
The plenum from an old WRC car over in Canada is Cast aluminium, some say it flows the air good and others only use polished plenums and runners. I want to try the polished version, but as this is cast the surface wasnt exactly very smooth inside, rather sandy
So, smart and full of bravery I started sanding it down with some very small-corned sand paper, so soft one could rub it to the skin and it would not scratch much After almost 8 hours it looks like this
Starting to look good, and it feels as well. I can no longer feel anything but a silk-smooth surface when i sweep my fingers across. Sanded it the way I want the air to flow correct into the runners with spinning. Still not done tough, tomorrow I am starting all over, with paper so fine thing wont even need polishing when it's done hehe. Will take some more pictures. My opinion is that air flows best at smooth surfaces, but I know people also says that there is nothing air flows as good at as air laying in the rough surface.
Old image og head
Old 01-13-2013, 05:17 AM   #29
Teigen
Teigen's Avatar
Updated first post with info for those who wants to know internals and measurments etc
Old 01-13-2013, 10:48 AM   #30
bc.
bc.'s Avatar
Updates
Have you seen this done before with success? I am a little skeptical of grinding away part of the pump housing. I would be afraid of a pressure drop or something. I am in for the updates and data from your cooling setup
Old image og head
Did you get combustion chamber smoothing and rolling/removal of the squish area? Or is this just the way the stock head looks?
btcc, s14, tremec, turbo
