![]() Join Date: Apr 2007
1UZFE into S-Chassis
It doesn't seem like it is done too much here stateside seems more in other parts of the world.
Anyone have any HARD information on what is needed with this swap? Does anyone make a motor/trans mount kit for these? i've looked around a little and can't seem to find any that are for sale, there all just custom one off kits. I have someone who can do the wiring on the car, i just don't have the fabrication skills to make the motor mounts. any year 1UZ's better then other years? i know a few companies that make performance parts for them. i don't plan to make a whole bunch of power out of it, just something that will be fun and reliable. and i'd like to keep with the Toyota powered Nissan stuff lol.
![]() Join Date: Apr 2003
from what i recall there is not a real aftermarket for it, it only comes auto, and really costs too much for a motor thats not really performance oriented, just seems like a bad idea unless you have really good fab skills or a shop to get something like this started
Well, there is a aftermarket for these, they make stuff for the heads (valves,springs,retainers,etc) they do camshafts,pistons,rods,Individual throttle bodies,etc. so there is a good amount, also they make adapter plates to run the V160/R154/W58/Z33 6spd,etc. so it would could be 5/6speed if need be.
#5 |
![]() Join Date: Aug 2009
![]() Feedback Score: 27 reviews
1uz in an s chassis sounds like gold to me. full of win. and 1uz's are actually kinda cheap too bad i don't have any info on that for you but good luck if you try
#6 |
![]() Join Date: May 2008
There should be a guy on nico with it. I remember a few years ago i went to one of the nopi shows and at the nico booth there was a 1UZ swapped car. Lol 90% of the people didn't know what engine it was.
#7 |
i have found alot of parts for the motor/trans/etc. i'm just looking for any info on putting it in the actual car. i pretty much just wanna do a mid 300whp 1UZ and that kind of power in a SC/LS really isn't gonna move the car too good. so why not put it in a S-Chassis.
#8 |
Check out tamparacing.com, scroll down in the forums section to Nissan and go into the build thread. There's a member named AgentAndy that just did this very swap into an S13.
#9 |
Just going to bump this thread.
As i have been doing alot of research over the last few months on doing this setup. i think come this spring i will be pulling the trigger on doing this build, so look forward to that coming later. anyway. I found that the connecting rods are the major differance between the years of the 1UZ ![]() judging by that picture the 89-94 has the strongest OE rods, and that is what most of the people who do this motor in other cars use, But the the 89-94 1UZ-FE is rated at 250hp and 260tq. well i'm not going to go too crazy on this build so i was hoping for some more horsepower from the get go, so i think i will be going with the 1997+ 1UZ-FE with VVTi with 300hp and 310tq. and do a custom set of headers/exhaust/intake and a tune. should be sufficient. i found that there is a guy in Flordia who is making a swap kit so i will be going with that one i do believe. just wondering if anyone else has since done this or done any more research on the 1UZ? maybe we can make this a 1uz-s-chassis help thread?
#10 |
if people are serious about this swap, heres the link to convert to a manual tranny. these guys have a kit for the w58 tranny and i belive there almost done with the kit for a r154. News
#11 |
from Ultimate 1uzfe W58 Conversion Thread! (LOTS OF PICS!) - Club Lexus Forums
Main Parts 1uzfe W58 Swap Kit (Quantum-Auto.com) includes the following -Adapter Plate -Flywheel (Steel or Aluminum depending how deep your pockets are) -Pressure Plate -Full Face DF Clutch -Clutch Lines -Howe Bearing Spacer -Alignment Tool -Pilot Bearing -Bolt Kit -OEM Flywheel bolts Custom trans/Motor mount for S13 Parts you need to source W58 Transmission from a MK4 Supra OR SC300 - Any year - DO NOT USE AN MK3 Supra W58 unless you know what you are getting yourself into! Howe 82870 Throwout Bearing ![]() adapter plate to the W58 ![]() ![]() Take the Automatic bellhousing from the transmission that you just removed and bolt it to the adapter plate. You will see where you have to grind the bellhousing for the couple of bolts that are in the way and part of the front seal cover. ![]() the spacer from the kit ![]() ![]() ![]() ![]() |
#14 | ||
here is the current 2JZ-S13 build thread if ya wanna take a peek. http://zilvia.net/f/chat/223490-2jz-...ect-300sx.html
#16 | |
![]() Do you know if he offers and wiring services or diagrams? Also with the 1UZ - 5spd stuff using the SR/VQ/KA trans are those adapter prices included?
#17 |
hey pm my good buddy on here his name is RPS13drift were doing a 1uz in his s14 and he has alot of info on everything tell him mike told you to talk to him
#18 |
theres a guy on ebay who sells the full kit for cheap to use ka trans which is the cheapest since the stock drive shaft works with it but he also sells bell housing adapters for w58's and such.
i know if you use your ka trans you can use your clutch disc and get an MR2 pressure plate and flywheel which will need to be machined to bolt up to the 1UZ. ive also been doing research on this and its stupid how cheap it is to do. surprised no one does this swap more often, there was a guy on nico who did it all under 2g's said n done. |
#19 | |
#20 | |
Looking aound some more, i found these diagrams on another forum for a 1UZ-FE into a S14.
Anyone know how close this is to a s13? ![]() ![]() ![]() ![]() ------------------------------------------------------------------- Also came across this, If this is true it could really be made VERY simple to run in a s13. Quote:
#21 |
Any progress?
I've been going to the track with brett for a few years and he's a good dude and a even better driver. Theres a few locals here in central FL who have the swap with his fabbed parts and love them and the swap. My friend Ben sprays his 1uz in his cressida, brett is working on a sc kit and Bill Shermin is actually butting together a TT kit for his 1uz supra. So the motor must be strong, its a toyota. I myself am highly considering going to the j-yard this week to yank one out for the hell of it. I seen somewhere on the web that some stock tundra headers will clear the steering shaft saving a ton of money/time fabbing headers. Agentandy just told me he sells DIY header kits for this swap, I just don't know if it would be a good idea to mig them together with my lincoln pro mig 180... |
#25 |
/\ thats whatsup /\
His e mail should be on his eBay listing. I know you have to use a mr2 Turbo flywheel/pressure plate and clearance the bolt holes to fit the 1uz crankshaft bolt holes (3sgte?). I think he also makes pilot bearings tob's that go with this trans retro-fit. |
#27 | |
![]() Join Date: Oct 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Link to flywheel Modified 3SGTE Flywheel I will post more pics after the needed parts arrive and we can start making some progress on the swap. ![]() |
#28 |
![]() Join Date: Jul 2009
im also doing this swap soon ive been talking to brett to seems like a cool dude does anybody know what flywheel bolts to use if u order a flywheel from these guys
Modified 3SGTE Flywheel and aslo what headers are those |
#29 | |
just source out a 3sgte flywheel and extend the flywheel bolt pattern along with flipping the ring gear since its backwards, take the flywheel to a legit machinest. i got mine done for $90 and paid $40 for the 3sgte flywheel. |
#30 | ||
