#92 |
Well obviously, it doesn't even have a blow off valve. No JDM points 4 u /:
#93 | |
![]() Join Date: Jul 2005
In short, any pressure spike seen near/at the throttle body is not going to increase wear and tear of any parts in that region. The part you are trying to protect is the compressor wheel. |
#94 | |
#95 | |
It wasn't necessarily the idea that you need to protect the TB or equipment, but moreso that the pressure wave would be caught early and dealt with prior to the shift event ending and the TB opening again. I am unsure of the speed of the pressure wave and whether it reaches back to the BOV next to the turbo quick enough to open the valve, vent the spike, and close before the exhaust is spooling the compressor again. Could this result in overspinning the compressor wheel? By that I mean, if the BOV is open and the turbo is being spooled could the compressor rpm spike without the pressure building in the IC plumbing? I'm just throwing my thoughts out here, not trying to be obstinate. There are a lot of things happening at this point in the cycle, and the fluid mechanics isn't a simple equation. I did well in Fluid Dynamics in college, but that was 10+ years ago and I don't deal with it regularly at work. |
#96 | |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
I just wanted to touch on these real quick. I think whether the application calls for it or not is really up to the user. If I can instrument a stock sr20 with enough sensors and fail-safes to make it last way longer than it ever would have without them then I'm all for it. And even better for my built motor if I ever decide to put it in. So it has a fuel cut rev limiter. What if oil pressure is low? The PFC is gonna run the engine until the rods come out since it doesn't have an input for that parameter. That's pretty important. I have a fuel pressure sensor in my regulator wired directly to the AEM. This is a fuel cut safety. If my fuel pressure ever drops it will cut the engine off or cut the boost pressure, pull timing, limp mode or whatever I tell it to do in that event. What am I missing here? I don't see how any external fuel cut off would be better. |
#97 | ||||
#98 | |||
#99 | ||||
![]() Join Date: Jun 2010
Great discussion! There are some strong opinions here, but it's good reading for anyone choosing a tuning solution.
Now for me to fuel the fire and play Haltech rep lol ( I have a Platinum Sport 1000 on my SR) Quote:
#101 |
Okay while we have a haltech rep here, do you currently offer any plug and play options for the S13 SR?
#102 |
lol I'm not actually a Haltech rep, was just poking fun because someone above was talking about a PFC rep being in this thread too!
But my Platinum Sport 1000 is "plug-and-play" for S13 SR. It uses a patch harness to connect the factory engine harness to the EMS. Like this: ![]() Stock harness plugs into the blue part and the 2 black connectors plug into the EMS. There's also the Platinum PRO Plug-In for S15 SR. ![]() |
#103 |
I definitely like the ability to stick my hand in and start the car when I'm not necessarily wanting to get in it yet. Yay cold start maps.
Sent from my iPhone using Tapatalk |
#104 |
Ahhh, I know what you meant now, I misinterpreted. You're right. The start settings (pulse prime, crank timing) each have a table based on coolant temp. IACV also has cold and hot settings based on user defined thresholds.
#105 |
Idle speed and idle airflow are the same thing. You need a $0.35 vacuum line plumbed into the car from say, the brake booster line, to get it to idle at any speed you want cold, regardless of what ECU is installed. Then, stick a $0.02 bolt in it when it warms up to bring the idle back down. I also had another easy idea that I intent to implement and test soon. A circuit to energize the A/C airflow of the IACV when you initially start the vehicle should raise the idle speed as long as the circuit is energized. I am not sure how to time it yet (might just use a switch) but this will accomplish the same thing- extra airflow during cold start for sr20 engines, and using only a single wire. Either way, a switch and some wires can't cost more than a couple dollars.
Still not worth $2000 to fix this, what is merely a $0.37-$2.00 problem. I just don't get the thought process there, but maybe that is because I accept that engine airflow adjustment is as a simple as a line and a bolt, and it does not bother me? Furthermore, it is only an issue for severely cammed engines (HKS 272 in my engine) and that camshaft is specifically for engines making over 500bhp (not a 400hp camshaft, those would idle like stock without issue) and since nobody in their right mind should use an sr20 to make over 400bhp anyways, that means this problem literally doesn't exist except for those rare instances where you want the camshaft lope without the power (like myself). And further, further more, there seems to be some kind of adjustable device on the front of the throttle body I have not attempted to adjust yet, and it might just do the trick with no further additional "special treatment". I am not a rep of any kind. I am a broke ass college student, and we find ways to make things work while there is no income, then depending on how lazy we are, changes how much time we spend worrying about these details. Basically it all comes down to saving money, and making a profit by driving a car. You can profit from a 240sx... I have every single car I ever owned. But it wasn't by throwing 2k here and 3k there into an inconvenience I could fix with a $2.00 line and bolt. |
#106 |
Running a vacuum line into the car to plug it every time it warms up just seems extremely ghetto. Let's throw carburetors on it with a choke adjustment lever while we're at it :P
#107 | |
2. the brake booster essentially does the same thing, everytime you mash the brake pedal its like taking the bolt out and putting it back in: un-metered air enters the system and the engine runs lean. But you don't call the vacuum assisted brake booster mechanism "ghetto" despite it acting identically to a hidden line/bolt. 3. I offered several other options and also pointed out that if you aren't using a huge camshaft it is a non-issue. |
#110 |
no, its just a one time thing. the vacuum only leaks when you STEP DOWN on the brake. Once the pedal stops moving there is no more leak. The point was simply that these leaks exist, even if you are not aware of them. Its part of the big picture of where air goes on an engine, lots of people don't realize the brake mechanism is a source for unmetered air. Try pumping the brake and watch the wideband go lean.
#111 |
To be fair, and compare apples to apples cost wise, almost NO ONE is going to find a Power FC for $350. I looked for almost 3 months before I determined that a used unit for the RB25 Neo was never going to come up for sale. A S1/S2 perhaps is more possible, but still super rare.
So cost wise, the L-Jetro clocks in at $850 new with the Commander, plus you are looking at $350 for the Datalogit, and $150 for a Windows Tablet. So $1350 for the capabilities of the ECU plus tuning ability. A D-Jetro clocks in at $1050 plus $350 for the Datalogit, and $150 for a Windows Tablet. So $1550 for the capabilities of the ECU plus tuning ability. My Link G4+ GTTLink plug in ecu with a $150 windows tablet will ultimately cost $1317 and has all the capabilities of the Haltech or AEM. The AEM I6 506 costs $1400 plus a $150 Windows Tablet, the overall cost is $1550. The Haltech PS 1000 costs $1519 plus a $150 Windows Tablet - $1669 Comparison: L-Jetro, Datalogit, Win Tablet - $1250 D-Jetro, Datalogit, Win Tablet - $1550 Link G4+, Win Tablet - $1317 <- NEO price, S1/S2 is mildly cheaper AEM I6 506, Win Tablet - $1550 Haltech PS 1000, Win Tablet - $1669 These are prices I just pulled from eBay, so YMMV slightly, but it gives you a good idea of the true cost without finding a diamond in the rough with a used PFC. |
#112 | |
![]() Join Date: Jan 2010
Anyways, so no real complaints about the AEM infinity? I've been trying to track down why my car suddenly stopped wanting to coldstart for about 2 months now with no luck.. Thinking about refreshing the motor then going infinity with a WS pro harness when I get my tax return and never worrying about it again.
#113 | ||
Heres one for $300 http://www.ebay.com/itm/apexi-power-...FXx19z&vxp=mtr and $400 http://www.ebay.com/itm/Apexi-Power-...9X3oZR&vxp=mtr and $300 again http://www.ebay.com/itm/Apexi-power-...JX0so~&vxp=mtr they come up all the time for common swaps. Just be patient. Then, a MAF power FC, can EASILY be tuned via commander (no need to buy a data-logit) the data-logit is for people who want to tune the basemap of a D-jetro (map sensor type). If you are into map sensors, to begin with, you should be in the 500+RWHP crowd. No reason to go map until 480rwhp+. Therefore, you might be looking at better ECU options anyways (AEM, Haltech, etc) I would never suggest somebody buy a brand new PFC D-jetro over an AEM for 500+rwhp setups. Personally, I would never spend over $500 on any power FC, that isn't an option for me. Quote:
This is novice/newb thinking. I have 2 bypass valves on my car and neither one of them makes a chirp or woosh noise. The noise is for beginners, first time turbo owners. A truly well setup turbocharger system incorporates significant insulation, and is deathly silent, because a silent exhaust/tone overall is an enormous benefit to listening to the engine itself. Noise in general will put a damper on your ability to diagnose the engine, mechanically. |
#114 | ||||
Am I missing something, or did I just state something specific to the RB25det the OP was looking at for a stand alone ECU? Look for used RB25det Power FC units. 0, let me repeat, 0 come up on eBay. Plenty of RB26, but NONE for RB25. Be patient, that's your answer? Well then I should just be patient and find a used Haltech for half or less than the original and the point still stands. Quote:
#115 | |
In other words, nobody likes using the hand commander. I don't need to use it because I have the data-logit. But there is no real reason why I couldn't use the hand-commander if I had to, in a pinch, or if the data-logit broke, there would be no difference in the final tune or the way you drive afterwards. #2 if ebay doesn't have any used PFC for your engine, you have the wrong engine for such an easy, cheap used tuning option. The chance of finding a used PFC for different engines will obviously vary. Try to plan before you buy the engine, make a list of all the parts and their availability, and anything in this category (used, ebay parts) try to buy well in advance if possible. Either that or be prepared to pay the price. RB engines are prestigious, excessively extravagant, and are only used when the owner desires the RB name tag over displacement and power output from other, lesser cost options. In other words, the minute you say RB anything, you will generally expect to pay double for parts and accessories for something like 30 to 50% less power output given a similar investment as other, more common engine swap options with 6 or 8 cylinders. |
#116 | ||||
Anything non RB specific runs the same amount as other forced induction motors, and various other RB specific items can be cross referenced to other domestic Nissan motors to keep costs down. RB items that cannot be cross referenced aren't nearly as expensive now as they were 10 years ago given the increased popularity of the swaps in the states. 30-50% less power output given the investment?!!! Really? I call bullshit on that one... you're pulling numbers out of your ass. I for one would never let the availability of a used Power FC drive my selection of a motor. That seems like a backwards way of going about it. Besides that, I generally do not buy used electronics when their function is key in keeping an expensive project from being relegated to the recycling bin. Kind of why I would never buy a used power supply for a high end computer. If it fails or is buggy it can take the entire project down in the process. You obviously feel different, which is fine, but I wouldn't let $500 be the difference between $10k of super sweetness or $10k of scrap metal. You do not know the condition of the components when buying second hand. It could have been dropped several times, or subjected to extreme static shock, or any number of other not so good situations. |
#117 | |
So cost X output the JZ family would win here stateside at least. |
#118 | |
![]() Join Date: Dec 2013
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
#119 | |
Let me just say this about my current costs. I am $10k in, with $2700 in the stock R34 Neo motor and R33 transmission. So for ease of calcs, let's say I have $7k in aftermarket parts. I don't plan on touching the stock internals since the Neo is solid lifters, RB26 forged rods, and VCT which I plan to keep. I may throw some Pon Cams in just to do it while the motor is out. I am doing ARP head studs and stock gasket replacement, so it is a possibility since I can keep VCT with them. Here is the list of parts so far: Neo water pump RB Greddy Super Kevlar Timing Belt <- Stock is cheaper, but meh, kevlar aside, the durability of the belt teeth is really a plus in my opinion. Timing Idler and tensioner pulleys Greddy style intake plenum and 90mm TB <- TIG welded aluminum sheet plenum, the same as Go-Zirra sells on eBay. Amazing build quality, no cast crap. Top mount twin scroll exhaust manifold <- Hybrid Performance out of NZ. Good Quality, Great Price. Will be modified for dual wastegates. Dual Precision 46mm Wastegates Synapse Synchronic Diverter Valve Twin Scroll BorgWarner S200SX-E 7670 turbocharger <- Found a deal no one could come close to beating. I couldn't even beat it through my girlfriend's brother who works at Kenworth and could get it at cost. ECOtrons wideband O2 CANBUS controller with Bosch ADV sensor FiveOMotorsports 850cc Black Ops injectors <- was about to pull the trigger on the Injector Dynamics, but price got the better of me. We'll see how these work out... Fuelab Fuel Pressure Regulator Aeromotive Stealth 340 fuel pump SPEC Stage 3+ clutch <- Read the good, read the bad, generally the 3+ has good reviews Treadstone TR1235 Intercooler ARP head studs Full RB25det Neo gasket set LS truck coilpacks Taylor 409 Race Pro 10.4mm plug wires Link G4+ GTTLink plug in ECU and extension loom Link 4bar MAP sensor Link IAT sensor (Bosch) with weld bung HKS Hi-power exhaust for S14 <- nice and throaty but not too loud with the KA currently ISR test pipe <- found out the 95 KA was a straight pipe anyway, no secondary Cat, but oh well, this one was shiny and should flow even better. Sentra early 90s 1.6L IACV <- Same as R33 RB25 minus the T, which is useless since I am not running coolant through the throttle body Pathfinder early 90s 3.0L TPS <- same as Q45 as far as I can tell ISR RB25 into S14 mount kit <- Seems good so far, welds are the best I've seen from ISR, good thickness, great price compared to others and doesn't require the R33 crossmember. Things left to buy: Quest alternator and associated hardware for install Driveshaft <- need to measure after engine/tranny are in to make sure a DS shaft will fit, or a custom shaft will be built. WS engine harness <- I could make my own, but they have a great quality product even at the somewhat high price. Radiator and fan set-up <- Looking for a radiator with integrated oil/transmission fluid cooler to knock 2 birds out. Teflon Fuel lines <- setting it up to possibly run E85 etc when Green Initiative forces everything towards ethanol. Radiator and coolant lines <- Loving the Viper lines from the UK currently, just need to figure out what I need. Vacuum Tubing Intercooler Piping Exhaust pieces for custom down pipe NGK copper spark plugs Coolant Temp Sensor Thermostat Exhaust Temp Sensor Fuel Pressure Sensor Other odds and ends I know will come up that I won't have thought about until the engine is in the chassis. Possibly S15 Helical differential. Might run the open diff until I determine 1 skid mark needs to be 2. Possibly new oil pump depending on condition of stock clearances and whether I got lucky with the upgraded crank without the crank collar requirement. There you have it. If you cannot tell from the above, the list is extensive. TL/DR - Lots of shit purchased, some shit left, $10k spent so far Last edited by ADIDASilvias; 11-14-2016 at 11:28 AM.. |
#120 | ||||||||||
