Old 02-01-2013, 10:02 AM   #61
Bink Industries
Bink Industries's Avatar
Bink Industries is an unknown quantity at this point
Originally Posted by Beejis60 View Post
If the OP has a few extra shanks lying around, I'll gladly buy two
if you are looking for some tapered monoball stubs for s chassis I should be getting some soon and I will sell them separate for anyone that wants to buy some. they are for a 3/4 inch monoball (spherical bearing)
Bink Industries is offline   Reply With Quote
Old 02-01-2013, 10:12 AM   #62
kewilso3
kewilso3 is an unknown quantity at this point
Originally Posted by redsx13 View Post
Ahhh..no. They don't
Unless your calling the bolted section a pivot point. In which case you should probably tighten those bolts, because that sounds dangerous
Ahh..yes. They do. During caster adjustment. You tighten the bolts after adjustment to lock it in of course, I didn't think I'd need to explain all that.
kewilso3 is offline   Reply With Quote
Old 02-01-2013, 10:29 AM   #63
Bink Industries
I will have to agree. the factory had no intentions of people putting adjustable tension rods there and as you adjust your caster in this way with the stock FLCA it WILL begin to bind.
there is a small amount of room in the holes to acount for some misalignment but that will only take you so far. i beilve that is what your talking about.
hope that helps explain some stuff.
Old 02-01-2013, 10:34 AM   #64
kewilso3
whether or not Nissan intended it, there is a range of adjustment there, and that is what allows adjustable tension rods to work. All LCAs I've seen that use oem style tension rods have this play built in. Yes you will bind eventually, but you can bind any setup eventually. There is plenty of adjustment for most people, and if you want more/less caster than you can get at the LCA, you should probably be adjusting it at the top hat anyway.
I'm not saying oem style is end all solution, or any better than other styles, I'm just saying that there is room there for adjustment without binding, which is true.
Old 02-01-2013, 10:58 AM   #65
Bink Industries
the stock tension rods have a pretty good fit into the holes leaving almost no room for "adjustment" to that every car has the same caster (ie location of the tensioni to the FLCA, and again there was no intention for it and it was never built into it to adjust it.
what makes aftermarket adjustble tension rods work is that instead of using the the right size bolt in the two holes on the FLCA they use undersized bolts to give you more "wiggle room" that is the built in "play" that your talking about in the aftermarket units. that is not a good design from an engineering stand point
that being said. i had some on my car for YEARS and they worked fine and they do have some adjustment you are absolutely right.
Old 02-13-2013, 12:45 PM   #66
Bink Industries
240sx flca Prototype - YouTube
here is the video you guys asked for. its not much but its something to look at.
Old 02-13-2013, 01:08 PM   #67
Beejis60
Beejis60 is an unknown quantity at this point
Are you running a NASCAR style sway bar?
Beejis60 is offline   Reply With Quote
Old 02-13-2013, 01:23 PM   #68
Bink Industries
No. it is a prototype that i made myself from scratch. this was designed specificly for 240sx. there is nothing like this on the market. It is totally my design (based on offroad/nascar style swaybars) made for drift cars and road racing cars alike. it bolts up in the stock location and will clear a least 65 DEGREES OF ANGLE. it will be avalible to the market soon.
there willl be two options one for sr ka with nismo power brace and one that will clear LS1.
it will be sold in the sub $300 range with additional center rates available for a fraction of the cost.
Old 02-14-2013, 10:01 AM   #69
Beejis60
I don't care about angle.
But it looks like a nascar style 3pc but it's mounted a lot lower, obviously in stock location, from that camera angle. Spline bar/ends?
Old 02-14-2013, 09:40 PM   #70
Bink Industries
it is a nascar style, it is in the the stock location, but no it is not splined.
Old 02-15-2013, 07:25 AM   #71
Beejis60
How the hell are the side pieces mounted to the bar then?
Old 02-15-2013, 03:24 PM   #72
Bink Industries
welding and bolts.
flca, major angle, s13 240sx, steering angle
