02-11-2012, 08:36 AM | #61 | |
Trader Rating: (58)
Feedback Score: 58 reviews
I can ask him though, and send you a PM. Also, anxiously awaiting your dyno work. Did you previously dyno the car with a 2871?
02-11-2012, 08:36 AM | #62 |
Compressor map
http://www.atpturbo.com/root/release...366-1_comp.jpg "New GTX2863R dual ball bearing turbo with ultra high flow compressor wheel featuring Garrett 11-Blade technology. Turbine Housing is sold separately and is the same as one used on GT2871R using 53.86mm 76 trim turbine wheel " They are calling it a 2863 on the 2867 page, which makes me think fail cut and paste job. Also, here, "http://www.atpturbo.com/root/releases/release110101-1.html" it says "GTX2876R 55 Trim" and points to this map, "2867" which is apparently another fail identification. the gt2876r compressor is this turbo: And if so... the old gt2876 offers slightly more power potential than the 2867 according to the map, about 10 horsepower more for what its worth. Doesnt the 2871r tap around 45lb/min? All of these turbos appear to flow within about 30-50 horsepower of each other. But that says nothing about boost characteristics... real world results are about more than just peak power potential. ->in for a dyno |
02-11-2012, 09:32 AM | #63 | |
Trader Rating: (58)
It seems though most of the math/research/questions I've asked and gone over, that this turbo will produce more power at the same boost, but at the same time also offer a higher boost ability than the current 2871r. As it stands, I would go as far as to say that on a pump gas car, that 425ish whp is achievable at 22ish psi of boost on our engines (or an efficient 2.0) at the maximum with the current 2871r platform, before it starts entering the land of simply blowing hot air with quickly diminishing efficiency. The 2867 however seems to change that, as I think it would support 450ish at 25-26 psi, while still being efficient and not becoming a air torch. With that all considered the 2867 also has a smaller/better deisnged wheel, which 'on paper' points to quicker spool, but more importantly faster off throttle response (which is more important to me being a track guy). It seems that it will match the 28RS in that department, which is awesome, as there is ZERO doubt from my own experience that the 28RS rips up into boost much quicker than the 2871r, despite the 'over rpm' graphs being similar. Now the 2863 is more of a 'hot rodded' 28RS, I think guys should see 375 on that turbo, however it does seem to run out of some oomph in terms of airflow.
02-23-2012, 12:31 AM | #66 |
DO you think there would be enough room to fit a MVS, if the 44mm end was cut from the turbine housing and a 38mm flange was added. maybe even moving the flange closer to the housing! You stated that there was a little over 4" to the strut tower and the MVS(38) is 3.7" if i remember right. then the only other thing would be the top banjo fitting.
Maybe little hammer massaging to the tower could give a little room. I really just don't like how clustered the 90 looks, if it could come off the housing like it was intended it would look cleaner! |
02-23-2012, 08:54 AM | #67 | |
Trader Rating: (58)
02-23-2012, 09:26 AM | #68 |
There's a couple of cars around here that have had that housing installed, but have had 90 degree elbows mounted on the v-band and some other wastegate mounted on the end of the 90, then custom fabbed dump tubes. I rode in one built S15 with this configuration and it was impressive, which drove me to go the same route.
My car will be done in the next few days and I will be posting pictures of my EWG housing installation, since there are very few posted online. |
02-24-2012, 02:06 PM | #70 |
i have been watching this page and i don't even own any of the cars on this sight. I have a jetta 1.8t and the shop its at is in the process of installing one of these turbos. Hope to see decent numbers!
02-24-2012, 02:17 PM | #71 |
Trader Rating: (58)
Just remember the 1.8t is going to obviously require more boost and be slightly laggier than the SR 2.0, but it's a decent reference. I know 28RS 1.8t cars are really fun, so the 2867 should be good!
02-24-2012, 02:29 PM | #72 |
i had a GT3071r on before and blew the turbo. With the 3071r i saw 28psi around 4300rpm.. With some water/meth and good tuning i think some decent numbers will come from my car as well.
02-26-2012, 07:31 PM | #73 |
So I'm having an idle issue with my car. If I set the power fc to around 68% for the injectors the car idles fine. But when I run them at 50%, as they should be run, the car dies out. They are 740s so I'm sure they are supposed to be run at 50%. Not sure whats going on but hopefully i can figure it out soon.
02-26-2012, 07:46 PM | #74 | |
Turn and Burn! |
02-26-2012, 10:09 PM | #75 |
Could also be your fuel pump going. Do you have a fuel pressure gauge?
Also, I've tuned Haltech but I'm not too familiar with power FC's so when you say 50%/68% what exactly is that in reference to? And thanks for starting this thread. I'm very excited to see what this turbo can do. |
02-27-2012, 12:14 AM | #77 | |
02-27-2012, 12:37 AM | #78 |
Ah so 370/740 = .5, makes sense.
Can you adjust that number with rpm? Something that you could set it at 68% for idle rpm and 50% at redline with it being linear in between? I still think it might be the pump if it's not just a power fc issue. You do have an upgraded pump of some sort, right? And is it relatively new? Also, as was said, it could just be different latency. Try setting the injector correction to 50% as expected and then adjusting the latency until you get a good idle and see how it runs then. Here are some times for you to give you an idea of a normal range: Power FC Injector settings - Get your car drivable to get it to your tuner - Hardtuned.net Also, is your battery/alternator good? I ask because injector latency changes with voltage. |
02-27-2012, 02:11 AM | #79 |
injector latency should be around 800-900µs with these injectors, and is around 350-400 with stock ones. If it dies near idle it surely is that. I dont understand powerFC latency setting but i guess it could help.
02-27-2012, 06:38 AM | #80 |
I received this turbo last week, I had 2 weeks to test it and return it. I haven't even removed my turbo yet! I'll call and ask for a couple more weeks, but i'm gonna repackage it for return. I was all hyped then it just slipped my mind. Is there anyone with a 4cyl running this turbo with dynograph and data, also coming from a gt2871r making the average power 370-410hp and 350-380tq Trying to be all scientific and shit!
02-27-2012, 09:50 AM | #81 | |
Any chance of you dynoing yours? And people make 350-380tq on a gt2871? I thought it was more around 330-340tq. I'm mainly going off of codyace's which did 333tq. |
02-27-2012, 01:54 PM | #82 | |
I really don't want to get into my power vs that guys. I'm just interested in the data, and whether it'll be wise to upgrade from a certain turbo or bypass it all together. Kinda like the 2540r I hate that turbo!
02-27-2012, 02:06 PM | #83 |
Sweet number there man, that gives me a higher goal to shoot for when I finally get around to tuning my gt2871. I have the model with the bolt on intake rather than the 3" opening tho. If I'm not mistaken, that one has a little less power, right?
And yeah, I'm excited to get some hard numbers on this thing too. I may be looking at trading up if it puts on a solid showing. boostfreak27: Still having idle issues after adjusting latency? |
02-27-2012, 03:19 PM | #84 | |
Sent from my Highly Tuned Vibrant!!!
02-27-2012, 03:37 PM | #86 |
I think it came standard on the older .48, but it's an option for them all. We're talking about the compressor housing, right?
1. Read your tag. 2. Measure your wheels 3. Dyno? Maybe... Sent from my Highly Tuned Vibrant!!!
02-27-2012, 05:37 PM | #87 |
Yeah, compressor housing is what I'm talking about. I wasn't aware that they made the bolt on version for all trims, good to know.
I'll have to check the tag when I'm back home. EDIT: I'm only seeing the bolt on one in 52 trim on Garrett's site Last edited by LuckyX2; 02-27-2012 at 06:15 PM.. |
02-28-2012, 06:12 AM | #90 |
Any updates anywhere on the net?
www.motoredge.wordpress.com |
gt2871, gtx, gtx2867r |
