11-21-2009, 07:26 PM | #61 |
Trader Rating: (106)
Feedback Score: 106 reviews
Trac arms are the same, toe arms are the same length but the s-14 requires thicker spacers on the rod end, and I believe that the s-13 and s-14 rear uprights (not knuckles) are actually slightly different. The entire s-14 rear suspension is rotated forward slightly compared the the s-13 rear suspension in order to reduce the retarded amount of anti-squat that the s-13 has.
03-09-2010, 07:35 PM | #67 |
hello everyone this is gonna be a bit of a noob question but i came into a good deal with my friend who's getting rid of his s14 with many parts on his suspension. I was planning to swap the entire brake system, 5 lug, wheels, suspension, and lsd off of his s14 on to my s13.. i was wondering what problems would i face once i start switching all of the parts over and what would be needed to be adjusted or taken from the s14 also and could be used on my s13 coupe. any help would be greatly appreciated because i am very interested in picking all these parts up and putting them back on my car
04-24-2010, 07:01 PM | #68 |
this might be a dumb question but i rather ask this question in this thread rather than starting a new one since its the same topic. I know its all in personal preference, but what are some good coilovers for track & street use? im thinking of going with a grip setup. I would drift too but i doubt its possible to have both setups. How are the apexi N1 ENV?
A'PEXi N1 Damper ExV Coilovers 1989-1994 Nissan 240SX (S13) - P/N: 269AN006 |
06-05-2010, 02:00 PM | #69 |
hey musikjunkie with your s13 suspension stuff your askin about i know on your rear end as far as the rucas go they might not fit your car. most of the rucas you see for s13s go all the way around the coilover like the stock ones. and on s14s they only go half way around but if you mount them on your car theres a rubbing issue on the back. there is a few companies that sell the rucas that only go half way around like part shop max, or battle version that fit both s chasis. ask your friend whats on his car or show us what they look like so we can tell you if theyed work or not. also one more thing when you do install the rucas weather they fit or not i would recomened doing the toe rods and rucas at the same time. if you just put the rucas on and dial them in your toe is going to be affected as well. and with your coilovers i think its already been addressed in this thread but the rear coilovers on his car is going to be a lot longer than yours, but the fronts i believe are fine.
06-05-2010, 02:31 PM | #70 |
and i got a friend that has the apexi coilovers your talkin about on his car and he loves em. ive drove his car a few times and they dont seem too bad to me. he does mostly track racing but now that im gettin him into drift i think its gonna become both as well like your talkin about. im personally sportin part shop maxs coils. ive had em for about 2 years now and there fuckin awsome! i do go to scca events some times but keep in mind they do get kinda pissed if u do crap like e-brakin the harpins real fast or crap like that. me personally, i think drifts way more fun if your tryin to decide what to get into.
07-07-2010, 01:54 AM | #71 |
interesting. how well does the max coils handle besides drifting. would u recommend them for grip/time attack cuz u seem much more satisfied with your coils over the apexi's
07-07-2010, 03:42 AM | #72 | |
I'd highly suggest Stance in that price point, even with the 9k/7k springs they felt much better.
02-22-2011, 10:24 PM | #74 |
hey fellas first time here. got a s14 completely upgraded and im tired of going to the rack tfor alignment. i read somewhere that a decent set up is -2.5 front camber and -1.1 rear with 0 toe. it seams to be on flat suburban roads but as soon as i get into the city the front is all over the place. would the problem be solved by taking the front camber close to 0. I can always do trial and error but if someone can give a directio woud be great. thanks
02-23-2011, 01:55 AM | #75 |
That's a great setup, but the one thing you didn't address was caster. Lots of people like lots of caster (-7* or more), I run bigger tires and like a little less (I ran like 5.5* on my S14 last time I aligned it).
If your alignment feels good on great roads and shitty on shitty roads, guess what? It's not your alignment, it's the road. If you'd rather the car 'want' to drive straight all the time, give it a little toe in, like an 1/8".
02-24-2011, 08:41 PM | #76 |
Thanks for the tip. i checked the caster angles and it looks like i got an 1/8-1/4" more caster on the driver side then the passenger. i think that might explain why the car pulls to the right when i brake at high speeds. i think im going to have to lower the caster angles a little and put them up when i get to the track...its unnoying fighting the road all day long.
03-07-2011, 11:09 AM | #77 |
can some one help me with my problem I have nisson altama 97 I touched the battery cables backwards for 1 sec and the car starts and ones and the headlight are the only thing that works ele, I replaces the 75 amp fuse and still no change pleae help it is broke down away from town thaks
05-25-2011, 01:47 AM | #81 |
Is there any chance caster could make the front wheel shake at speeds above 65?
My car got aligned and for some reason they put the caster at 4.5 and 4.6, and ever since then its had a vibration about 65. It didn't really do it before the alignment so I'm confused. They tell me its bad tires though, because on one the rubber is showing cracks, but its just confusing that it didn't do it before the alignment.
08-02-2011, 09:25 PM | #82 |
does anyone know where to get rebuild parts for kts coilovers? looks like spl doesnt sell them anymore and i havent been able to find anywhere else...searching google just brings up older forum threads
09-05-2012, 08:07 AM | #83 | ||
Bushing FAQ
So, I've done a lot of research, ripped apart my subframe and control arms, and since I didn't feel that this topic should go anywhere else, I figured I'd add on to the Suspension FAQ.
Q. Bushings... WTF are they? A. Bushings are the buffers between your control arms, differential, subframe, and the chassis. They are rubber inserts that form a protective cushion between the metal, moving parts of your suspension. Q. What do they do? A. Their job is to absorb Noise, Vibration, and Harshness (NVH), while keeping your suspension geometry somewhat within spec while cornering or going over bumps. Being made of rubber they make the ride more bearable. Nissan of course made our cars to be "sporty", and rubber is slow to respond sometimes, which means they aren't the best for spirited or motorsports use. The problem with these bushings, is that, like anything else on a car, they wear out over time, when subjected to road-grime, heating and cooling cycles, vibration and all the other elements that our cars endure, not the least of which is the driver. Q. So what are the alternatives? A. Well, you can replace them. There are 3 main types of replacement: --Rubber is the first. Now, these come in OE or Performance Flavors. These bushings are usually pressed in, which as a result means to replace them, especially with OE-hardness bushings, that you'll need a press or new arm. Performance Rubber Bushings are generally harder, like Nismo/Full Race/Megan. These provide a tighter feeling while still being very street/daily-driver friendly. --Polyurethane is next. This is a plastic alloy (lol) that is more dense than rubber, but still has some give to it. There are more than a couple companies which make these types and the performance benefits are pretty sweet. You get to tighten up your handling to better than stock, your handling becomes more predictable and you STILL have a car you can use on the streets. The downside with these is that like rubber, they won't last forever, and ones that move, like the control arms, need periodic lubrication (depending on manufacturer/style) via Zerk-grease fittings or Dis-assembly. The big names here are Energy Suspension, Prothane, and Whiteline. --Solid/Heim Joints are last. These are the fully adjustable units you see the racing/hellaflush guys running. These are usually spherical bearings (in the case of Control Arms), or Solid Metal Slugs (in the case of your differential or subframe). These bushings are the best for performance, because they allow very predictable handling, because they bearings will only move a certain amount, your suspension geometry remains more static as well. The bad is that all the NVH that was previously captured by the rubber, is going to get to you now much easier (a reduction in ride comfort). Heim joints also need periodic inspection to make sure the vibration isn't shaking bolts/nuts loose, they aren't binding. Q. That was really long winded... A. Not a question, but okay, here's the short version: Bushing replacement should be determined by your own sensibilities and what you plan to use the car for. Rubber - Good for Daily, Not as good as others for performance Polyurethane - Acceptable for daily, acceptable for performance, may be more maintenance involved Heim/Solid - Great for performance, not as good for daily, Heims require vigilance/maintenance Q. So... How do I install them? A. I shall direct you to Project Car Magazine for a detailed How-To with our cars. And also Here. Remember to say thank you when you get there. Q. Anything else I should know? A. There was some interesting discussion with Poly-bushings going on here, and over here we have some Subframe Bushing Install Tips. Now, if you have clunks coming from your suspension, when cornering or going over bumps, it means your bushings are probably shot. The reason is because the suspension is contacting itself in ways it was never designed to. Quote:
energysuspension.com | Welcome Whiteline Performance Suspension – Activate More Grip Prothane Suspension Parts - A Dealer of the Prothane Brand of Suspension Parts Nissan 240sx - Suspension & Steering - Suspension Bushings - Enjuku Racing Parts, LLC Well, that's it for me. Let me know if I missed or need to add anything to this.
"Power Is Nothing Without Control" |
09-05-2012, 08:25 AM | #84 |
Trader Rating: (42)
Feedback Score: 42 reviews
So your telling me that my 10k 8k swift springs on fortune auto coils is too stiff for any type of driving but drifting? Cause I'm not building my car to drift
11-18-2012, 08:04 AM | #85 | |
Posted from Zilvia.net App for Android |
12-23-2012, 08:01 PM | #87 |
Trader Rating: (60)
Feedback Score: 60 reviews
Can some one help me out, I took my car to get alinement i had just installed new suspension. they said they try adjusting my ruca and I was hitting the fender? I'm really confuse because my old never had this problem and when I had just install my new suspension I adjusting them the same as my old. Now I'm getting negative camber and my wheel not even close to being in the middle it's hitting the rear bumper? Do I need to adjust the traction and toe, do I have my ruca install backward (but I really don't think I did) or do I just take it back for they can do the alinement right?
Want to roll fenders, custom gauge pod pm me |
07-04-2013, 04:07 PM | #89 |
I have a question....
Can someone please post the eye to eye length of the front and rear OEM suspension / tension arms / lca's for the s13 and S14? TIA CH Sent using XT912 M |
11-14-2013, 05:59 PM | #90 |
Want to widen my wheel base should i get 20mm spacers or get wheel adapters ? I he read that spacers arent good or safe but then others say they are...can you guys give me some input
