01-08-2017, 01:38 PM | #7263 | |
285's tho... Rocket bunny front flares, so another 50mm wider than my previously rolled fenders.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
01-11-2017, 01:26 PM | #7264 |
These are the coolest extended FLCA I've ever seen. They are also priced amazingly:
https://technotoytuning.com/nissan/s...arms-s13-240sx |
01-11-2017, 05:46 PM | #7265 |
This is the roll center, suspension pickup, and steering angle modification thread.
Look cool, and heavy. Also no inner heim joint so caster adjustment is limited. Weird that they're wider than stock.
Sent from my iPhone using Tapatalk |
01-12-2017, 09:16 AM | #7267 |
Anybody see the new grip oriented knuckles from GKTech? Probably going to be selling my GKTech drift knuckles for those.
My S13 SR Street Mod Build |
01-19-2017, 03:42 PM | #7268 | |
I'm about to purchase their front set and they only sell the V3 on their site? Am I missing something? PBM came out with a new set is that what you mean? |
01-20-2017, 07:16 AM | #7272 | |
Yeah it's been out for a while. The cost is a little exhorbitant IMHO, but it's interesting to see a caster-biased kit. Stewy loves caster haha. One of these days I'll update the OP, I swear, hahah.
01-20-2017, 12:08 PM | #7273 |
Quick question guys. I am putt on my front driftworks knuckly. The top of the spindle is hitting the bottom bracket of the coilover ever so slightly.
I have two options, 1. flip the coilover bracket 2. grind a little of the knuckle <1.5mm on the edge. (I went with this one, but the coilover bolts on a little tight to the knuckle... What you guys think? Thanks!
Turn and Burn! |
01-20-2017, 12:45 PM | #7274 |
01-23-2017, 06:40 AM | #7277 |
I currently have the GKTech drift knuckles but I autocross, not drift. They're better than stock knuckles for me but the grip knuckles would be even better in my case. If you want the extra lock and adjusted ackerman, go drift knuckles, if you just want the fixed geometry, go grip knuckles.
Slider, I'd say you're fine having ground off a bit of the knuckle, those things are pretty beefy and 1-2mm isn't gonna change much.
01-23-2017, 01:53 PM | #7278 |
01-23-2017, 02:08 PM | #7279 | |
You've never driven a car with shorter tie rod pickups have you? You still have 2.25 turns lock to lock, it's nothing crazy.
01-29-2017, 12:38 AM | #7280 |
Been looking into getting an angle kit for my s13, and came across the "Unicorn Angle Kit"
LINK:http://www.driftknuckles.com/product...corn-angle-kit Seems to be a pretty basic setup just seems the rank would over center like a mofo, can't seem to find any reviews or anything online of it, any feedback? |
01-30-2017, 05:28 PM | #7282 |
I've searched Silvia and google and can't quite get an answer. I've messaged gktech and pbm and they both vary from answers.
The pbm top camber plate (16mm) and spacer (7mm) according to pbm are able to be used and would avoid cutting of the strut top. According to messsges from gktech they say you will need their top plate (20mm) and if it's an s13 a 8mm spacer in order to not cut the strut top. Short story pbm says 23 mm clears gktech says 28mm has anyone actually purchased either of these sets would like to elaborate on which is the correct one or what makes them vary in size other than I assume the allowable clearance of the dampener screw top. |
01-31-2017, 08:37 PM | #7283 |
They're probably both correct due to design differences between each brand's plate. PBM's requires the 23mm to clear and GkTech requires 28 like they said. Doesn't mean either is incorrect it means they're designed differently.
02-12-2017, 01:17 PM | #7285 | |
Also, I know these are terribly wrong, but not sure exactly how. I figured you guys would have fun tearing them apart. |
02-12-2017, 02:13 PM | #7286 |
Those arms hurt my eyes. They will sit flatter/lower like they are correcting roll center, but the centerline of the ball joint to the centerline of the spindle is all that matters. Plus putting the kink in the arm introduces a potential bending stress since there is no longer metal in a straight line between the ball joint and the pivot pt of the bushing.
02-12-2017, 04:15 PM | #7287 |
The guys at HeatMaker helped me with a rack relocation. Moves rack brackets 25mm forwards.
225 Link: http://heatmaker.bigcartel.com/produ...nt-crossmember
Instagram: @cleantune |
02-27-2017, 02:22 PM | #7288 |
Just FYI guys, over the course of this week I'm going to be overhauling the original posts, so if they're all jacked up for a bit, you now know why, haha.
03-03-2017, 08:34 AM | #7289 |
Driftworks just released pre-orders for Geomaster V3! compilation with wisefab. Drift and grip settings on front knuckle. New rear knuckle with revised kinematics.
03-04-2017, 01:36 PM | #7290 |
First two posts updated. Let me know what you guys think, or if you have any input!
