05-20-2019, 01:08 PM | #31 | |
04-02-2020, 08:12 AM | #33 |
Anybody else run these and have any positive feedback? I ordered a set to run with a 2871 setup, but there hasn’t been much info available on them.
instagram@stevie_fingers 350z for sale |
04-02-2020, 02:05 PM | #34 | |
thing is, the way they make cams today is different. Some companies do it wayyyyy different, materials and methods. So your question isn't one of how the cam "works" but rather how it was made, what materials were used, who cut it, how did that part go. Is it safe to use in your engine. Do the lobes match up with the cam card. Quality control. so you can't easily ask a blanket question like that. Sure maybe from 05-08 the quality control was amazing but in 2012-2015 the manufacturing for the same exact grind was done somewhere else and its shit. or something like that These days I would only buy a cam brand new directly from JWT or Tomei or HKS or Greddy. And use the matching valve spring and recommended valve hardware. For some engines it doesn't matter but when it comes to sr20 I don't like to mix and match valve spring/cam manufacturers unless I am absolutely sure I need the extra pressure. And then cross ur fingers. |
04-02-2020, 09:07 PM | #36 |
I just installed these on my s14 SR. Yes not much info about people running them.
I got the Tomei USA 258 set for s14/s15 SR. Some info for me, S15 turbo. Still stock ECU, Stock 370cc injectors and have the basic bolt ons, exhaust manifold, elbow, downpipe, exhaust etc. 10psi I'm still driving it easy to break in. So far a little loss of torque in low end but it kicks in pretty good on mid range. I haven't redlined yet, going to drive it a bit more before I do but I can tell the power comes on strong. Idle is pretty stable, a little lumpy and rough but that is to be expected on a step 1 cam. Only question I have that I haven't found answers to... On cold start, my SR hesitates a bit in the revs. Once it warms up it seems fine. I know I'm still on stock ecu. Anyone else experience this on cold start? Don?t have any vacuum numbers but nothing seemed out of the ordinary other than a more lumpy/rough idle.
Sfourteen Last edited by dct223; 04-03-2020 at 01:53 PM.. |
04-13-2020, 04:55 PM | #37 |
Just a follow up
Seems like my vacuum at idle for the tomei 258s match what some already posted. Idle is approx -0.51ish bar on my defi advance boost gauge. Cam isn?t off a tooth. It?s timed correctly at 15deg.
Sfourteen |
05-24-2020, 09:18 AM | #38 |
Got mine installed and pull around 15 inHG at idle once warm. haven't gotten it all back together after paint to do a test drive, but they seem to be in-line with what others have stated so far.
258, poncam, tomei |
