Old 11-20-2013, 11:02 AM   #31
Skynet
Skynet is an unknown quantity at this point
will definitely do that today with the rail, and possibly the o-rings as well. Where should I check the fuel lines for leaks?
Thanks for this thread by the way, this has been a ton of help since gas is 3.45 here in Louisville right now, hahaha
Skynet is offline   Reply With Quote
Old 11-20-2013, 01:09 PM   #32
Slippin'eight-nine
Slippin'eight-nine's Avatar
Slippin'eight-nine is an unknown quantity at this point
Ive had just about every type of fuel leak imaginable. The actual filler neck and rubber sleeve running to the tank. If I filled the car Full it would leak out to 3/4 tank.
Ive had the rubber lines coming off the tank going to the hardlines leak. It was a steady drip. I couldnt tell cause I parked in the grass and gas evaporates.
Ive also had the fuel injectors leak from the injector body rather than the orings.
My car used to reek and I would be high as a kite upon reaching my destination. Haha!
Keep in mind these were all at different times over the course of several years.
Good luck and keep searching
Project cars: "Fail to plan, plan to fail"
Slippin'eight-nine is offline   Reply With Quote
gas mileage, ka24e, s13, stock
