02-28-2012, 08:08 PM | #31 |
It's easier if the walls buckle... Which, unless you've removed some rubber, probably won't happen. I was able to knock it out using the method I described, but you probably couldn't have used the sleeve over again... I skipped the cutting cuz it took too much time, then again, my subframe was bare because I did all the bushings, and it was easier to finagle empty obviously... Sorry you're not having the same luck.
"Power Is Nothing Without Control" |
02-29-2012, 09:46 AM | #33 |
presses are expensive. I used one on one of my bushing's center pieces, and it was only a small one. The Subframe is large and unwieldy, I can sympathize with someone poor who can't be hauling around 100+ lbs of steel (he still has his diff, ect. in).
A press does wonders, if you use it right. After I knocked my sleeves out, I brought it to a local shop to press my new ones in. Because my press was too small and I didn't have the "proper" (read: makeshift) tool to press them in myself. Plus I was burnt out on the whole thing by then... Laziness prevailed.
03-01-2012, 08:24 AM | #34 |
I finally did it. Finally. I got the rings out and already installed the aluminum DIF solid bushing in and installed my subframe. All I have to say about the ride is .... Damn! My car is so much better
03-01-2012, 09:01 AM | #37 |
Sorry to thread jack, but the ES poly sub-frame bushings only require to remove the inner sleeve, while the dif aluminum bushings require to remove both inner and outer sleeves?
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
03-01-2012, 09:18 AM | #38 | ||
presses aren't the best way to do this, too awkward and a PITA there's a specific tool made for bushings (look in the FSM) that makes the job cake, THAT is the best way to do it. I did mine (SPL solids) a few years ago by myself over a weekend left the bushings in the freezer overnight and used a caliper pad expander with a long threaded rod and washers to pull the bushings with an impact gun. |
03-01-2012, 11:51 AM | #39 | |
yah i have a press; took all of 2 minutes to press out the bushing and put in the new one.
03-01-2012, 01:11 PM | #40 |
Yea your correct. The s14 has only one sleeve on the rear bushing, then the front bushing has plastic/small metal ring/ big metal ring/ outer sleeve. It was confusing. It seemed like the s14 should have had metal collars already in the bushing from stock. Those things had toooo much gap.
03-01-2012, 02:35 PM | #41 |
I noticed that too... It was a bit odd because Energy Suspension really didn't say that in their S14 Specific Kit/Instructions.
bushings, energy suspension, polyurethane, s14, subframe |
