#391 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Anyone have trouble getting a hold of Collins? I sent an email with some good questions, failed to receive a reply. I', looking at their whole 1jz/cd009 SWAP kit. So it includes everything needed. Doesn't mention motor brackets, think it comes with it?
EDIT: lol, I just heard from them. It does include everything I need. I'll be getting the whole stage 3 kit. I'll post up the result when I get it.
#392 | |
#395 |
Hey guys,
Our next batch of bellhousings just started heading our way so they'll be available in about 2 weeks. In the next 2 weeks you can preorder your kit or bellhousing for 10% off! |
#396 |
Cd009/Fk40 trans---- hooked up a Dakota digital sgi5 to one of the abs sensors on the q45 (97-01) diff but I can't get it to read under 40mph. 40mph+ I can get it pretty close so I scoped the sensor and found it doesn't seem to put out enough voltage at lower speeds for the sgi5 to work. The sgi5 is 1-19V input. Anyone else encounter this or found a solution other than some kind of a gps box?
S13- 2jz, 370z 6spd, PT6262 Nissan Master/GT-R Technician |
#397 |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
There's a shop that makes a speed sensor for these trans that goes on the driveshaft yoke, can't remember who it is at the moment. They do Z32 LS swaps a lot.
Sent from my iPhone using Tapatalk |
#398 |
https://www.lojkits.com/products/cop...smission-mount
This is what you're looking for you can use the stock trans harness to send the speed signal just pop a corresponding plug on the sensor they provide. |
#401 |
It's cheaper than the racepak module that does the same thing and you don't need a racepak. Seems like a good price to me.
#402 |
Ok so I got the speedometer all fixed and working correctly now!!! The air gap between my abs sensor and reluctor ring was too large.
So here's what I did for $40 plus some wiring and a little sheet metal to make the S13 speedo work. *S13 2jz w/CD009, FK40C trans *98 Q45 rear diff/92 J30 5bolt axles into the stock hubs * Now with the S13 cover, this poses a problem. The abs sensors on the 97-01 q45 diff are located on the diff cover so I made a metal bracket to attach one of the abs sensors back onto the diff. The FSM states the air gap for the abs sensor to reluctor ring should be .035-.070mm and check with a feeler gauge. Mine was too far away, causing it to produce too little voltage. Got it to .045mm and pow! I got a nice wave signal out of the abs sensor. * I picked up a used Dakota digital sgi-5 for $40 and wired the 2 wires from the abs sensor I rigged up to signal and sensor ground on the sgi-5 box. Using the 1st output on the sgi5 I ran a wire to the back of the cluster (not the yellow and green one at the dash connector that won't work, it's an ouput) yellow wire with blue tracer, turned switch #3 to on all others off. After messing with it for a bit I was able to get my speedometer to work flawlessly from about 7mph-90mph so far. So if you want a permanent cheap setup that works great with any powertrain then boom, there you go. This is of course if you are running a diff with an abs sensor.
S13- 2jz, 370z 6spd, PT6262 Nissan Master/GT-R Technician Last edited by kkaleher; 06-19-2017 at 07:24 PM.. |
#404 |
The Q45 diff is actually pretty bad ass. It can take over 1100whp and pull 1.2x 60' times.
#405 | |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
DLG - DIRTYLOVE |
#406 | |
Okay. But there still isn't a quality clutch type LSD for it that I know of. Sent from my iPhone using Tapatalk |
#407 |
Isnt the z32 turbo rear diff the same housing as the q45? I would think the ring and pinions/LSD would be interchangeable, that's another topic all together tho lol. The everything rear axle thread talks about all that too.
#408 |
Z32 turbo is a r230 and is to big for s13/14.
Q45 is a r200 but they share the same size axle stubs. That's why everyone runs them in the s13/14. Bolts right in with the correct axles. |
#409 | |
But yes, apart from Quaife, you cannot plop a nice and cheap S15 helical in for instance which does suck ![]() |
#410 |
So what gearing are most people running with the cd009? I have a j30 3.9 I was planning to use but am wondering if I should try to source the q45 diff. Car will mostly be a street car so a decent freeway rpm would be nice.
#411 |
Collins s13 jz cd swap kit arrived. This included everything needed(mounts, xcessive motor brackets, cd09 trans bracket and mount, collins flywheel, clutch and pressure plate, pilot bearing adapter, shaft masters drive shaft, adapter plate, all hardware needed: cd09 bell housing bolts, Arp flywheel bolts, pressure plate bolts, brackets etc, and a shortened shifter.
Quality is top notch, the flywheel is so nice. I'll post up all the pictures once I get everything done. I paid $2500 or so for everything. Good deal I think, considering how much a r154 is these days.
#413 |
I had way to many problems with CBF with communication, attitude, and he kept saying it be done at the end of the week and for a whole like 2 months. I when with serial 9
#414 |
I ended up purchasing a serial 9 as well, but I never canceled my CBF order so I'm waiting for that thing to arrive still. Side note is, I will have a CBF shifter for sale when and if it ever arrives.
DLG - DIRTYLOVE |
#417 |
I was also running the 3.9 j30 diff and wasn't a fan of cruising at 70mph in 6th at 3kish rpms. I swapped in the 97-01 q45 3.6 now its at 75-80mph at 3k in 6th and 1st gear is much easier to deal with.
#419 | |
