![]() Join Date: Oct 2008
Trader Rating: (131)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 131 reviews
I recently looked into this as well but it didn't look like you could purchase only the T fitting- just a complete valve cover (which is discontinued.) I may be wrong but haven't been able to find a lookup code or part number for only the T fitting in any of the schematics.
#8 | |
Yes, it can be removed. The SR20 I just recently bought did not have the T fitting. A friend had a spare valve cover as a wall decoration and I was able to remove it and install it in mine.
#10 | ||
![]() Join Date: Mar 2009
The fitting itself does not have any baffling. There is a little restrictor pressed into the middle of the rear hose between that fitting and the factory catch can. If you don't have the original hose then i'd bet you also don't have that restrictor in the hose. |
![]() Join Date: Oct 2004
Yeah its actually in the hose that is on the right side from the air oil separator. So you will ALSO need the black square canister coming off the block breather... So you would need both those original pieces to really work. Else stuff is just going to blow through that hose all day.
#14 |
So why do I see so many SR engine bays without that original can? Not being an ass...asking a legit question because I have the can still just not the hoses and I cant find them to purchase anywhere...so I'm curious as to if I TRULY need it.
Sent from my SM-N960U using Tapatalk |
#15 | |
The oil catch/blowby thread will answer your question. If you remove the can without thinking about how the system works, then you'll have to deal with excess blowby/oil vapors/vac leak from the PCV side edit: power steering return hoses can be used to create the lines... I bought some bulk line and cut it to fit, along with auto parts store PCV 90 degree fittings. The disk in the posts below are a flame arrester (in case the crankcase vapors get ignited). Last edited by Abeo; 02-20-2019 at 05:15 PM.. Reason: more info |
#16 |
TBH i always kept the stock catch can with my s13 valvecover and i never had any noticeable blowby on that engine in the 8 years I owned it.
It's not well documented and difficult to find pics online of it, but yes about mid-way in that hose between the T and the stock can there should be a plastic disc that acts as a baffle of some sort and its pressed into the original hose. Of course by now a lot of engines might not have that original hose anymore due to wear and tear etc. I'll check if I have mine still when I get home if I can remember. I think I replaced the hose but also reinstalled the restrictor in the new hose. EDIT: My fault I was mistaken, the OEM restrictor/baffle is located in the forward hose to the T fitting. Shown in this FSM diagram as part: 11826H ![]() I know RHDJapan lists the hose itself, Item 11828N Part# 11823-52F00 but i'm not certain if it comes with 11826H pre-installed or not, and they do not show it on their parts list for some reason, and I can't find a Nissan Part # for it. Item 2: https://www.rhdjapan.com/oemrequestl...catid/588/?p=1. Highly recommend to keep that restrictor if changing out that house for different routing like for an aftermarket catch can, etc. I could have swore the rear hose on my sr also had that baffle in it, but I might be mistaken. Last edited by TheRealSy90; 02-20-2019 at 12:49 PM.. |
#17 |
My fault, I was looking under the SR20DE parts on RHDJapan. I switched over to the DET parts list, and
they DO list the part as "ORIFICE-AIR HOSE", Part# 14889-D4201 Item: 11826H. 10th item down: https://www.rhdjapan.com/oemrequestl.../subcatid/588/ Curiously there is no picture online of the part itself lol. It's even shown in the forward hose for the S14/15 engine as well. ![]() |
#18 |
Same here in my redtop it was definitely in the back hose not in the front one between the T and the Intake. Weird.
Even its pictured and noted that it is between the T and the air oil separator https://zilvia.net/f/showthread.php?t=235851&page=4
#19 |
tap/thread it and put an AN fitting on there, it can attach to a hose or more fittings and make a T to accomplish pretty much the same thing...i used a restrctor from one of the ebay catch cans i bought years ago as i didn't have the original hose either
#20 | |
#21 | |
![]() Join Date: Sep 2012
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Its a 3/4" NPT to tap it and get a fitting that fits.....just don't crank on it when you tighten. |
#22 | |
