12-08-2018, 07:39 AM | #16502 |
The biggest cancer to car community is not the car owner ricing out his car but the sheople who look over every inch of the car for rice and when they spot ugly wheel lugs or body kit that didn't line up great etc they post it in here while most consider the car awesome that person has to circle the flaws for people to see,if you have to do this the car doesn't belong here and its those people that are cancer to car community as if everyone must build a car to look a certain way with zero originality...I understand calling out rice but some of you are beyond picky and try way to hard to find a "you,re doing it wrong" car.
12-08-2018, 09:07 AM | #16503 | |
https://www.instagram.com/jdpowersport_/ |
12-08-2018, 01:23 PM | #16504 | |
This is worth posting in here
Tuners are big bullies |
12-09-2018, 07:58 AM | #16506 | |
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
12-10-2018, 12:20 PM | #16507 | |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
Best way to do business with me? Make your best offer FIRST. |
12-12-2018, 01:20 PM | #16510 |
Can I get an F in the chat... got new Type X tails. Wouldnt fit for shit, tried to see where the high spots where and found out my whole QP is caked with bondo
All I wanted was a clean schassis and stay stock body but NOPE |
12-12-2018, 05:03 PM | #16511 |
you also need to change the rear trim piece under the tail lights, it different between kouki's and zenki's. you don't have to but will look like shit imo
12-12-2018, 07:21 PM | #16513 | |
Also had an s14 that I had bought a few years back. Had bad rockers, but what can you expect from MA/RI heavy salt roads. Get into it and the PO decided to fix holes in the floor by filling them with expanding foam and then riveting aluminum and steel panels over it followed by black undercoat. By the time I dug into the car, I felt more like I had some random G body that sat for 30 years rather than a 90's import. Foam was packed all the way up into the A and B pillars that when I was cutting out the rot, the foam would catch on fire. |
12-12-2018, 09:26 PM | #16514 |
I have the trim piece, took it off so I can rip off that scab of bondo..... If I attempt to break away the whole panel ill post more pictures haha its maybe half inch on the whole side.
Honestly dont know what to do because nothing conventional will help. Either gonna have to 1) send it to a shop, see if than redo this such as pull the metal out right then rebondo again. Seems like the whole panel is smooshed tbh so have to redraw body lines, still have hella bondo etc 2) Switch to over fenders, maybe cute out the metal and make my own bracket at least for the one section of the tail lights and pull the top metal part of the fender as much as I can then run some overs that cover the entire fender around the lights. Either Origin type 2, chargespeed which are 50mm dont go well with type x kit or if possible get car modify wonder rear overs which are 30mm and closest thing to stock replacing from what ive found 3)Find a shell instead spend the money on body work to reshell and deal with another shot 240 chassis. I got a lot going on next year and dont have the time like I do when I was fresh out of highschool. 4)Part out and be out the game. Switch to another chassis once im done with college and making decent money then get an FD or import a genuine type x which is around the time ill finish. Just sucks because this was my first car and put a lot of time and money into it thinking it was a clean chassis... but i guess thats DIY LOL instead of trying to make it nice with genuine parts, should of just thrashed the shit out of it like most kids now. |
12-12-2018, 10:47 PM | #16515 |
nah, dont do any of that. Get in there and find out whats going on. I suggest removing the bondo and see the extend of the damage. For that tail section piece, try and find a junkyard car and cut that section out. 240s never rust back there unless its the spare tire tray. If you can't weld it, have a professional do it and then finish with body work. With all that needs to be done, you'll be Grade A at body work when its finished. My friend smashed his tail light in this area and we pulled it out with dent puller and then any area where there was metal missing he filled with a welder and then smoothed out. Anything is possible if you use your head
12-13-2018, 02:06 AM | #16516 | |
People come in here for the wrong way to do things, by god ur skrewing it all up ah crap now im in here also |
12-13-2018, 10:54 AM | #16517 | |
I wouldn't reshell or part it. Get the bondo off, look for someone parting a car out and grab that rear section. Either replace the QP or replace just that tail light portion and do some overs.
12-13-2018, 12:04 PM | #16518 |
Do have a local by me who has some cut up QP in amazing condition, basically said I could have them. This is problem best case and just throw the cash at a proper shop to do it. Was going to cost my 700ish for car modify wonder 30mm rears plus have a shop try pull the metal straight again. If they can do it under 1k or little over ill be happy.
12-13-2018, 12:25 PM | #16519 | |
No need for overs, only reason would be trying to fit a large rear tire.
12-13-2018, 12:41 PM | #16520 | |
12-14-2018, 10:35 AM | #16521 | |
12-14-2018, 02:52 PM | #16522 |
At least it was repaired correctly.. I mean, if a bought a car and was told it was stock but had repairs that were actually decent and not half assed, I don't think I would be as mad. I mean, looks like someone took the time to cut the metal to shape and clean it up. Cant be that bad if you only noticed from the inside.
12-14-2018, 03:55 PM | #16523 | |
12-14-2018, 03:58 PM | #16524 | |
12-14-2018, 04:21 PM | #16525 |
I've seen something similar. maybe not exactly but very similar in almost every 240sx I ever looked at. There were cars that had DEFINITELY never been hit, that had little unpainted welds or bits of welding wire in the back there. I'm not sure what to make of it- but I do know that just because I see something now in the rear of a 240 I don't immediately assume its been hit. That does look like a patch deal though because of the other color panel. Its just usually things like that are bad enough they scrap the car- unless its still fairly new. And if work like that is done by pro body shop when the car is new... yep usually shows up on carfax because insurance etc... its a $5000 job
12-14-2018, 06:26 PM | #16526 |
My s13 has mint panels. Like perfect quarters and front fenders with a tiny bit of rot on the drivers side. The only rot this car had was from the brake booster leaking and caused the drivers side frame rail to rot. Bought it thinking that was it for it and that it was going to be super clean, and I checked the VIN and it had no reported accident. But after taking the engine out for a swap, I noticed there was tears in the strut tower (no rust or rot, literally clean tears as big as my palm) and a small kink in the frame rail. car drives straight as an arrow. underneath the fenders, there was bondo to make the fenders sit flush with the front end.. and then when i took the back seat out of the car, there was glass underneath it. Cant figure out for the life of me what happened to it. Its an 89 hatch with 100k. I am the 3rd owner and I know for a fact the kid before me didn't do it because he only had the car for 4k miles. and the owner before him was an old woman. Im thinking the car was parked and someone hit it because theres no others damage to the car and I've been through the whole thing
12-14-2018, 07:22 PM | #16527 |
There was a guy with engine problems with his s14. After swapping out the oem injectors with 740cc, the engine didnt like that. Well, you guessed, no changes in his ecu or whatever, just swapping out the injectors and after 3 weeks, he went looking for help.
I was a good laugh after a long time. Didnt knew this could exectly happen in these days. ?https://forums.sxoc.nl/index.php?/to...injector-swap/ |
12-16-2018, 10:36 PM | #16528 |
