07-07-2017, 02:08 PM | #64 |
I have a Dyno graph from MA motorsports (Low reading dyno at 350whp) and another from BPC Motorsports (DynoJet 466whp) locally here but both were before the wastegate was replaced. I'm in the process of replacing the fuel lines and then will be going back over to the dyno to get the boost dialed back in and get the latest numbers for you. Thanks!
07-17-2017, 05:06 AM | #66 |
How much work have you done yourself? How much have other shops done?
07-17-2017, 12:19 PM | #68 | |
-Sheet metal door panels and cage (Done by Casey Quillen in Houston TX, phenomenal craftsman) -Paintwork (Done by long time racer Mark Canup in Knightdale NC) -Intercooler modifications / welding by by friend Nick at Road Rage Autosports in Houston TX. -Downpipe I tacked in place and had BoostFab in NC Tig weld it out. -Engine Calibration & tuning done by Carl H @ MA Motorsports. Things I did: -Engine wiring harness -Chassis wiring harness & switch panel -All plumbing for fuel system, turbo oil and coolant lines, power steering, brake lines, etc all ordered crimped to length with either XRP or BMRS. No cheap shit or hose clamps. -Aero kit trimming and fitting as well as all body panels, doors, etc after paint. -Splitter was traced out and sent off to get fabricated. -Canards I cut to size and mounted. -Interior painting was done by me, nutserted the floor for the street faction plates. Interior panels painted by me, -All suspension work, bushings, motor swap, clutch, turbo setup, wiring and anything else was all done by me. |
07-18-2017, 03:48 PM | #70 | |
35k is right where this belongs. |
07-18-2017, 03:54 PM | #71 |
Thank you! The compression was tested routinely over the years (within a few points across the board) and it did spend most of its life with the stock turbo, on stock boost. It was from an auto car as well. The motor has always had its plugs and oil changed at probably 1000 or less mile intervals, since it's not driven very often. I appreciate the kind words guys.
10-12-2017, 11:20 AM | #81 | |
You definitely will! It made it on to Enjuku Racing's IG page already. The car is now in Orlando |
