Old 06-04-2013, 08:41 PM   #121
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
Originally Posted by unwtdhero View Post
Write up pleaseeee
What he said haha. That's sick I hope someone figures out the speedo issue. Those clusters are pretty sexy. I've been looking for one of the euro 140mph s13 clusters for a while now.
Boost Coming soon...
twofortyrida1388 is offline   Reply With Quote
Old 06-04-2013, 10:34 PM   #122
username
username is an unknown quantity at this point
now that i've had it for a year i might as well spill the beans....
If you cross reference the s2000 pinout(found on a lot of honda forums) and the 240 cluster pinout it really simple.
-You can only use an ap1 cluster as the ap2 need the s2000 ecu to work
-Power, ground, blinkers, brights, dimmer just use the same wire on the 240 cluster harness
-fuel gauge uses the same wire but requires a 27?ohm resistor to be somewhat close
-tach is the wrong voltage so you either need a dakota converter or do whats called a "pull up resistor". T into the rpm signal a 12v source with a 680?ohm resister. This will bring the 5v 240 signal upto the needed 12v signal. Will be accurate for 4 cylinder engines.
Think that covers the basics. It was a year ago i did the swap with a digital cluster harness so i dont have it written down anywhere.
username is offline   Reply With Quote
Old 06-04-2013, 10:58 PM   #123
bombaybe
bombaybe's Avatar
bombaybe has made poor choicesbombaybe has made poor choicesbombaybe has made poor choicesbombaybe has made poor choicesbombaybe has made poor choicesbombaybe has made poor choices
Send a message via AIM to bombaybe
Just got this done on my convertible today. Bought cluster w/HUD on Craigslist for $110, they pulled it off a junk yard thinking it was a plug and play or something.
HUD heads up display works(Do not cut the dashboard, get a S13 coupe dashboard with HUD slot)
Mad wires to match up, nothing a FSM and a solder iron can't handle
Download a '94 maxima, 89-94 240sx FSM and prolly some pills and you're good to go! Just match up the wires
Fuel gauge is not working properly, might need a maxima fuel sending unit. Shows 3/4 of thank but I only have 1/4 in tank with the original cluster. Need help on this...
bombaybe is offline   Reply With Quote
Old 06-14-2013, 05:02 AM   #124
twofortyrida1388
Thats awesome ^^^ actually the first time I've seen one actually wired in and running in an s-chassis. Thanks username. Seems like it would have to be done the old fashioned way.
Old 06-14-2013, 05:50 PM   #125
WheelWhore
WheelWhore's Avatar
WheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymore
Can I play?
WheelWhore is offline   Reply With Quote
Old 06-15-2013, 12:35 AM   #126
twofortyrida1388
hell yeah, I love this stuff.
Old 07-03-2013, 02:23 PM   #127
rubhamusan
rubhamusan is an unknown quantity at this point
rubhamusan is offline   Reply With Quote
Old 09-29-2013, 04:37 PM   #128
TheCakeIsALie
TheCakeIsALie's Avatar
TheCakeIsALie is an unknown quantity at this point
Send a message via AIM to TheCakeIsALie
This may be getting a little extreme, but I supposed with patience anything is possible. I think this would be very nice looking. If you've ever sat inside a CRZ, you'll know the pictures do this cluster no justice. And correct me if im wrong, but I believe as you approach redline/enter redline, the backlight to the tach fades and eventually turns red. Mega awesome in my opinion.
http://0.tqn.com/d/cars/1/0/L/7/2/11_crz_ip.jpg
http://www.ridelust.com/wp-content/u...s1-500x333.jpg
TheCakeIsALie is offline   Reply With Quote
Old 09-29-2013, 04:38 PM   #129
TheCakeIsALie
Also, the G37 and IS300 ones are also pretty legit. I like those. Just my .02
Old 09-29-2013, 09:08 PM   #130
S T Y L E S
S T Y L E S's Avatar
S T Y L E S is an unknown quantity at this point
Detailed pics of the s2000 cluster please!
S T Y L E S is offline   Reply With Quote
Old 08-06-2014, 04:28 PM   #131
WheelWhore
WheelWhore's Avatar
No one else has done a S2k Cluster? Looking at putting on in my S14.
Shouldnt be terribly hard.
Old 09-09-2015, 11:22 AM   #132
R3cK
R3cK is an unknown quantity at this point
any idea? no rpm. ca18det cluster incl resistor and sr20det with 62ecu.
triplechecked pinouts.
https://www.youtube.com/watch?v=ACoQvaZO89s
R3cK is offline   Reply With Quote
Old 10-23-2015, 08:42 AM   #133
DEMo
DEMo is an unknown quantity at this point
Working G35 Cluster in S13.
https://youtu.be/JLkXX7UdWNk
Instagram: @hexagarage for VQ S Chassis Parts
DEMo is offline   Reply With Quote
Old 10-23-2015, 09:55 AM   #134
Gingersmurf
Gingersmurf is an unknown quantity at this point
That's really cool, but i feel those lights in the dash are too bright.. Might just be personal preference though
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 10-23-2015, 01:05 PM   #135
DEMo
Thanks! The filter makes it appear that way but it's OEM. The stock S13 dimmer control switch and headlight dim will be wired in soon.
Old 10-23-2015, 01:20 PM   #136
Malik
Malik's Avatar
Malik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant future
that g35 cluster looks good demo... and the motor sounds good too
Malik is offline   Reply With Quote
Old 10-23-2015, 01:29 PM   #137
Gingersmurf
Perfect. excellent work
Old 03-06-2016, 04:10 PM   #138
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 03-07-2016, 04:16 PM   #139
Slanderous
Slanderous is an unknown quantity at this point
The maxima hud is amazing. What I wouldn't do for a plug and play
Slanderous is offline   Reply With Quote
Old 08-08-2016, 01:14 PM   #140
tuzzio
tuzzio's Avatar
Finished up my cluster last week. Made the backing plate out of a butting board. I'm a cheap fuck, but what broadfield does is amazing. nothing but respect for him. Thanks for getting me my gauges Toby.
Old 08-13-2016, 08:08 AM   #141
michaelbsr20
michaelbsr20 is an unknown quantity at this point
tuzzio, what brand are those guages?
michaelbsr20 is offline   Reply With Quote
Old 08-13-2016, 05:21 PM   #142
Ronald_Mcdonald
Ronald_Mcdonald is on a distinguished road
Send a message via AIM to Ronald_Mcdonald
Looks like Speedhut.
Determined to be famous, destined to be infamous.
Ronald_Mcdonald is offline   Reply With Quote
Old 08-13-2016, 11:02 PM   #143
ditchs14
ditchs14's Avatar
ditchs14 is a well-known jackass
anyone ever messed with a German s14 cluster? the one i got said its a zenki unit and it should just work like all the rest of the cluster. but my tach is off pretty bad. its just a stock zenki with a KA
ditchs14 is offline   Reply With Quote
Old 08-14-2016, 12:55 PM   #144
tuzzio
tuzzio's Avatar
This. Holla at broadfield for a quality discount.
Old 08-15-2016, 01:05 PM   #145
EJ8 944
EJ8 944's Avatar
EJ8 944 is an unknown quantity at this point
Pics? My UK cluster was PnP no issues.
EJ8 944 is offline   Reply With Quote
Old 08-15-2016, 09:55 PM   #146
rcefoonia
rcefoonia is an unknown quantity at this point
R33 Cluster is pretty similar size/shape to an S14 isn't it?
rcefoonia is offline   Reply With Quote
Old 08-15-2016, 10:00 PM   #147
rcefoonia
wow that Z33 dash definitely looks awesome.
Old 08-19-2016, 12:57 PM   #148
Davizz
Davizz is an unknown quantity at this point
How about some custom stuff:
Davizz is offline   Reply With Quote
Old 08-19-2016, 01:01 PM   #149
Davizz
Old 09-18-2016, 02:28 PM   #150
ehhhregartless
www.zeedakay.com
IG: @zeedakay
