Old 12-03-2011, 11:09 PM   #1
tossaxe
tossaxe's Avatar
tossaxe is an unknown quantity at this point
SR Improve engine cooling (???)
Hello,
Just wondering would removing the AC radiator help with engine cooling? Would it improve FMIC and engine radiator effectivness?
tossaxe is offline   Reply With Quote
Old 12-03-2011, 11:18 PM   #2
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
the less material "obstacles" that air has to go through to get to the radiator, the better cooling possible. If your car is all factory or just minor upgrades, there really isn't a pooint to remove it. Cars from factory are built with a cooling system to combat/deal with those obstacles (i.e large fans, larger radiators, ect.)...but if you already removed some A/C parts, then go ahead and do it. If not, just do a larger radiator if you want to keep your A/C
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 12-03-2011, 11:28 PM   #3
tossaxe
tossaxe's Avatar
almost everything , execept engine internals and turbo, will be changed by spring. I'll be looking for 300hp.I'll probably be running 1.2bar and scramble boost set to 1.5.
Well I never use the A/C. Now I have easy acess to it. But if the advantages of removing the whole A/C would be unnoticable, then I'm not wasting my time
Looks like I'll remove it =]
Old 12-03-2011, 11:45 PM   #4
xSoCalxRiderx125
xSoCalxRiderx125's Avatar
xSoCalxRiderx125 is an unknown quantity at this point
You can do ducting to direct airflow to your rad and intercooler. It could only benefit
xSoCalxRiderx125 is offline   Reply With Quote
Old 12-03-2011, 11:58 PM   #5
tossaxe
tossaxe's Avatar
Yup in in the middle of fabricating one Now I was thinking if I'm improving flow before the FMIC and radiator should do something behind as well. Ideally I would want a vent on the hood, V shape the two important coolers and seperate there incoming flow. But for now thats out of the budget =] Now any improvement, that's not just in my head, will do
Old 12-04-2011, 02:27 AM   #6
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
keep your a/c..keep the stock clutch fan and remove the stock a/c fan something more beefy. You'll be fine
hence
Be Cool 75062 - Be Cool Qualifier Fans - Overview - SummitRacing.com
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
a/c, cooling
