12-28-2009, 03:11 PM | #61 |
Trader Rating: (106)
Feedback Score: 106 reviews
I have some concerns about adjusting the rear roll center by simply spacing the joint down. The balljoints are mounted at an angle. That means that if you simply space the joint down you end up with a longer lower control arm to put the upright in the same position. Since the rear is a multilink that could affect the camber and toe curves. The affect could, of course potentially be positive or negative, but negative is much more likely. IMO in the rear the way to go is to re-locate the subframe and modify the spindles.
12-28-2009, 04:00 PM | #62 | ||
Man, it's too bad GP Sports stopped making those for the S-chassis. Supposedly you can use the Driftworks knuckles with the Z32 rear brakes, but they require "modifications" to fit. Quote:
Most roll center adjusting control arms/ball joints only move the pivot point down by 15mm or so and that 15mm only increases control arm length probably 5mm effectively, which should be able to be offset by the adjustment of the inner heim joints if you have an adjustable arm. And if not, just adjust all your other arms 5mm longer.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 10-03-2010 at 04:19 PM.. |
12-28-2009, 04:52 PM | #63 |
He's talking about the actual arcs that the arms go through being effected in a negative way. Which is why a modification to the rear toe arm mount on the knuckle is likely necessary to achieve proper suspension geometry out back (like the picture I posted of the S15 with Z32 uprights).
Danny, I do not believe there is enough material on the front spindle to just cut the bottom off and bolt something else on. You can see the GP Sports knuckles have a good 1/2 inch more material then the stock knuckles where the bottom part bolts on. It IS a shame that GP Sports stopped making them....but at the same time it was an unmarketable product. Very few S-chassis owners can afford/are willing to throw a good 1000-1200 bucks for a set of knuckles here in the US. Especially when it can be corrected by just raising the car up (which is what people who care about performance usually do).
Instagram - SJKnoop |
12-28-2009, 09:40 PM | #65 | |
EDIT: The relationship between the arms does change slightly, but as stated below, the change is not really a performance-hurting one.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 12-29-2009 at 12:31 AM.. |
12-28-2009, 10:56 PM | #66 | |
.25 till 3 |
12-28-2009, 11:51 PM | #67 | |
As for the GP Sports knuckles - if you're fine with two bolts in bending, why not just drill out the stock spindle and use a 3/4" bolt in bending in place of the balljoint?
S13 Hatch - Goes around tracks quickly DEFSPORT |
12-29-2009, 12:06 AM | #68 |
Just making the point that it requires more attention to correctly raise the roll center given a multi-link suspension. Unless I misread.
.25 till 3 |
12-29-2009, 12:26 AM | #69 | ||
Anyway, I was responding to racepar1's post. You have a point, but as I stated in my post, the only real difference is LCA length. Which is really quite slight, as the angle of the ball joints makes the additional length of the ball joint/shank not the length the control arm is extended. Here's my crude Paint example: And as Def stated, the camber and toe curves change very little with this. I think you guys are making it out to be a bigger deal than it actually is.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 12-29-2009 at 12:53 AM.. |
12-29-2009, 06:28 AM | #71 |
This is the reason we went ahead with making our set up. Alot of assumptions, I think's, and what if's. Until we get this 95katurbo's car on an alingment rack and take it to the track we will not know the results. Kinda ol'skool engineering I call it. Build it and take it to the track and beat the piss out of it. If it works everyone will want to have his set up. If it breaks into a billion pieces then we will get "the i told you so". As I look at the set up on the ground with the new GM ball joint set up we will be spacing the LCA about 20mm down. The spherical bearing that I intalled works with the up and down movement of the LCA. Essentially affecting nothing at this point. Under lateral G's we will have to wait and see. As far as I can tell I see nothing but positives from our set up. It beats the crap out of an old worn out rubber set up.
1994 FD3S Drift // 945garage // sumospeed.com |
12-29-2009, 09:26 AM | #73 | |
POWERED BY MAX: Forums フォーラム/ 作ã£ã¦もらã„ãŸ㠄パーツ Wish List / Rear knuckle
12-29-2009, 09:40 AM | #74 | |
good info subscribed
12-29-2009, 12:07 PM | #76 |
Solid! I've just found out they also make tie rod offset spacers (found them in that link). These space the tie rods farther forward to correct for "over centering" of the steering rack with all that increased angle. Sick!
Check them out: Original post edited!
12-29-2009, 01:20 PM | #77 |
^^^ Driftwerks = killer stuff. I'm happy to see innovation still being done in the S-chassis community!
I might have to get some measurements and CNC a spindle... I wonder how long it would take and how many pieces I'd screw up before I got it right lol...
Jordan Innovations has a new web site! www.JordanInnovations.com -- All your favorite FD Pro Drifters love it, trust me -- www.JordanInnovations.com |
12-29-2009, 02:02 PM | #78 |
i love learning things about my car. this is the most ive learned in probably the 3 weeks ive been on break. awsome.
WTB: 1/24 scale chuki s13 model. |
12-29-2009, 05:22 PM | #81 | |
It would be kinda nice if some people in the US made some of this stuff. Not that I don't want to support Drift Works, but I can't imagine it being very affordable to ship stuff from England. Oh well.
12-29-2009, 05:41 PM | #82 | |
looks kinda sketchy to me. |
12-29-2009, 05:54 PM | #83 | |
That's a Chromoly bolt, CNC'd billet aluminum, and a tie rod. How is that sketchy?
12-30-2009, 07:18 AM | #85 |
those have been around for about 2 years now. The first time I saw them was on the C's garage yellow coupe.
12-30-2009, 07:46 AM | #86 | |
or are they a drift only, trailered back and forth to track car deal? |
12-30-2009, 08:35 AM | #87 |
I dont see how it could effect anything. All you are doing is correcting geometry when the car is lowered or has extreme angle. I daily drove my car with modded knuckles and super low ride height. Did it suck? Yes, but I knew that was going to happen. Now did it perform on track. Hells yeah!!!! I dont drive my track car on the street anymore. The coilovers will rattle your teeth lose and the road noise is loud. hahaha.....I just realized I sounded OLD.
12-30-2009, 09:44 AM | #88 |
I read a post on driftworks concerning those offset spacers. They were originally developed and used in japan, but during usage they either broke or caused heavy wear on the steering rack causing it to deform. I'll try to find the post.
.25 till 3 |
12-30-2009, 10:43 AM | #89 | |
They were talking about the URAS ones, which are a different design and less quality.
Driftworks designed theirs to be better. I'll quote: Quote:
Tags |
anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
