01-16-2009, 11:12 PM | #1 |
progress of my s13 shell
I don't often post on here, but i figured i'd take a few minutes to share my project that's been keeping me busy. to get a little background, here's what i had before that i'm putting down
it's a 1993 se. sr swapped with type x aero. a few other upgrades, nothing really impressive and basically it was too rough around the edges to keep. It has MASSIVE frame rust and it's not worth taking the time to fix it so i'm starting fresh. Back in september I found a 1990 base model shell (no motor or trans but everything else intact) with 91k miles on it and no underbody rust. it's a little bit of a fixer upper but basically clean. there was however minor rust on the body. the seller was asking $800, but after inspecting it I decided it was worth maybe half of that. I offered the guy $300 and he wanted to wait a little since someone had offered $500. After a week of waiting the other person that had offered hadn't been heard from, I reminded him that I had cash in hand. The next day my dad and brother came with me and we left with it nice and secure on the trailer. I got it home and immediately started working on it after unloading it. My brother removed the batter tray as i stripped what was left in the bay. after cleaning, scrubbing, sanding and prepping it was ready for paint. I won't bore you with all the pics and details, but i started swapping the good parts form my type x replica as well as purchasing some other nice pieces. i picked up a z31 bmc and swapped over my new remanned q45 brakes and ss lines. I spent hours under the car scouring the underbody and coating it with truck bed liner. since it was to be daily driven i had to prepare for bad weather and protect against rust. I originally planned on doing very basic work and having my sr swapped in in less then a month, but once you get in there its easy to keep going until everything is PERFECT. a firend convinced me to drop the gast tank and subframe. i cleaned the tank and truck bed lined that as well. i picked up the energy suspension master bushing kit and replaced every bushing on the car. I also picked up the ES subframe pienapple bushings. subframe dismantled and being cleaned looking fresh to be put back together. pineaple bushings every suspension arm was removed, had the bushings pressed out and was wire wheeled before being painted semi gloss black and having the new bushings installed. I also took apart my vlsd and reshimmed it using the thickest shim you can get (1.49cm) in a nutshell, it'll make it look harder. i also cleaned everything up and installed my jdm vlsd diff cover with the vents! i bolted everything up to teh subframe and torqued it all to spec i got the subframe and gas tank reinstalled and covered the interior with fatmat i got the rear carpet cleaned and installed with the kai project battery cage and the lower mount for the cusco tri brace bolted in It's not finished yet, but i also started doing major work with the electrical system. with the help of a friend and fellow forum member we swapped the entire body harness in favor of an SE harness so all the power options could be added. before putting it in, we traced and removed every single wire that wasn't needed. to really clean it up we did a tuck that removes any unneeded wires from the engine bay. only whats absolutely necessary is in the bay at all. as you can see the bundle of wires is very thinned out, and with a little bending of that lip the wires will run up where i'm holding them, so i don't shread anything when i slam it. type x cluster is also ready to go. i used maxima plugs and built the harness myself, repinning everything where it was needed the front and rear also got new moog ball joints. at this point the rear end is finished and back on the ground... and the front end is just waiting for me to put the flcas with new bushings and ball joints on as well as truck bed line the front wheel wells and install my kyb struts wheel wells wanting attention my plan was to do everything except for actually swapping the engine outside, but considering its 5 degrees outside, i plan on sanding the wheel wells (so i don't have a mess inside) then wheeling it into the garage for the rest of the project (reinstall interior, get front end on ground, swap engine and other little things). I plan on putting the type x aero on but not until i get to the body work and get the car professionally painted. Until then i refuse to rock the pignose bumper so i'll be rattle canning this chuki bumper i got for free. well technically it wasn't free, i wired up type x bumper lights in return for it. That's basically it, theres a few mods i haven't bothered mentioning since i don;t want to make this too long or detailed. feel free to ask questions or give opinons, thanks
buy my type x stuff |
01-16-2009, 11:18 PM | #2 | |
Trader Rating: (25)
Feedback Score: 25 reviews
Hi Jeff! I'm glad you're taking the clean route to this one! Let me know if you need any help.
01-17-2009, 03:14 AM | #5 |
Awesome!!
Looks fresh and squeeky clean! I'm sure you've heard this before, but so you're ahead of the "type X" police. You may want to start referring to your bumper/aero as Kouki. Aside from that, it looks awesome!!!
"I am not good English, I like the drift" CHINA DRIFT "some guys have a better relationship with their car than their wife haha. sad but true." SECRET SOCIETY |
01-17-2009, 05:23 AM | #6 | |
as for the fatmat, its only in the trunk but thats because i haven't been able to do more. especially with it being cold, it's hard to to work that stuff even with a heat gun thanks. thats actually the first time i've heard that though about calling the type x aero kouki. I mean i know it is from a kouki s13, but i didn't know "kouki" was prefferred. especially since not all kouki s13s had the aero, only the type x model
01-17-2009, 10:53 AM | #7 | ||
Aero was available on ALL models of 180sx, and standard on at least two. Referring to kouki 180sx aero as simply being 'TYPE X' is akin to saying that automatic transmissions are ONLY on 240sx convertibles. This is obviously wrong, because you know better, but if you didn't know better and knew that AT was the only option for verts, it might be an assumed conclusion. Either way, you know that ATs were available on all models of 240sx just liek I know that kouki 18s0x aero was available on all models of kouki 180sx.
01-17-2009, 10:57 AM | #8 |
I've seen your type x project on NICO.
http://bhworld.wordpress.com/ |
01-17-2009, 11:10 AM | #10 |
Admin Asshole
"Type X" is the ultimate Nissan Fanboy BUZZWORD, I swear.
If you had a build thread with "Type X" and "Bayside Blue" in it, you would win Fanboy of the Year. Show your intelligence, call it what it is, Kouki 180sx.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
01-17-2009, 11:26 AM | #11 | ||
Stop pretending to be ignorant, Brian. I know you know better.
All models of kouki 180sx (X, R, S) were available in 5MT and 4AT.
01-17-2009, 11:37 AM | #13 | |
I also can see that the Type S has the SR20DE(~140hp)...N/A? Correct? I just found it interesting that Nissan added the Type S in the catolog as an automatic...all three could have been M/T. Thanks Mr.Meph.
01-17-2009, 11:49 AM | #14 | ||
Nobody ever asked you to. It's a matter of using proper terminology to describe things. Frankly, if you wanted to move away from the 'zenki/chuuki/kouki' set of descriptors and describe things by production dates or other specific terms, I'm completely fine with it.
01-17-2009, 12:02 PM | #15 | |
Type G
I'm just curious, thanks.
01-17-2009, 12:20 PM | #16 |
Just curious on what kind of front bumper is on the red car in the first picture that mrmephistopheles posted up? It does not appear to look like the other two or maybe it is, hard to tell from a side shot like that.
01-17-2009, 05:46 PM | #17 |
haha told ya..
01-17-2009, 05:56 PM | #18 |
Looks like a Type R front bumper.
01-17-2009, 07:36 PM | #19 |
I know this is a bit off topic. But I have that Carrozzeria head unit and cd changer that is pictured in that bottom add. I have never seen or been able to find any info out about it. It works good but doesn't receive us radio stations. Is it worth much?
01-17-2009, 07:50 PM | #20 | |
Japan uses different FM waves then most of the world but you can buy a radio frequency converter so you can use it. Example: C.A. Tronics - Car Radio Frequency Converter There was a guy selling that Carrozzeria head unit on a local forum with a fm frequency converter for $90, as far as I know if still hasnt sold, so no, not worth much.
-Trevor |
01-17-2009, 09:34 PM | #22 | |||
01-17-2009, 10:47 PM | #23 |
yeah i see know, wow i had no idea it was such a hot topic. i'm aware that the other models (type s and type r) have the same bumper and tail lights and the R even has the wing, but i thought that the full aero (sideskirts, rear valences, etc) were only available on the type x though. it's no big deal either way, i can call it kouki if thats better. I don't think that calling it type x aero makes me anymore jdm.
thanks for the comments
01-17-2009, 10:56 PM | #24 | |
I didn't mean for the last comment to come off as dickish. either way please keep updating your thread, I'm always interested in seeing some nice clean chassis'!
01-17-2009, 11:27 PM | #25 | |
it's all good, thread jacks don't bother me but thank you om1kron. and holybush, i didn't take it as dickish, i just had no idea anyone cared what it gets called.
forgot to mention before i'm ragged on for the kyb's, there only temorary cuz i got em for $250. coilovers will be coming as well as some sexy pbm parts. the last part i got was nismo motor and trans mounts. In the near future before the car gets on the road will be pbm rucas, pbm radiator and possibly a pbm intercooler kit. I have to check out the current fmic and see if its leaking at all. the lower corner is crunched a little (from before i bought it). just for reference heres how the engine looked when i first bought it and heres a more current pic, but it's still over a year old i'll keep updates of the progress coming. i shoudl have a little tim e on monday and hope to get it in the garage. i've been working on the car outside and with it being like 5 degrees it really sucks
01-17-2009, 11:34 PM | #27 |
^ good question. never one on the car when i bought it and now that i have an efan theres no need for stock shroud. i do with i had a shroud for the permacool fan
01-18-2009, 12:04 AM | #28 |
Only issues I see with the initial chassis build are as follows;
When you stripped the chassis, you forgot some rubber grommets, the horns, some misc hoses and wiring, and seems the windsheild wiper mechinism. The grommets will be the 1st area this duplichipper bedliner will flake off. Also, if your car see's sub 30*f weather, I wouldnt advise "just" spraying the bedlinner on the bottom of the car. Reason being the stuff pretty much sucks ass. You need an epoxy paint over etched clean primer. When the bedliner flakes/lifts up it forces the salt right between the chassis and paint, forcing intercourse with the metal. You will never know the rust is spreading like aids underneath. Undercoating is a very touchy thing, really the only way to do it, is to completely strip the underbody of paint, etch it, epoxy paint, and a durrable top coat. Rubberized undercoating will stick to the paint, however lift all layers of paint "up" when it cracks from the heating/cooling cycles of mother nature. So just use epoxy paint. On our cars the most rust happens where the factory undercoating is. |
01-19-2009, 05:24 AM | #29 |
hmm thats interesting to know. I'm skeptical myself about the bed liner but i tested it in a small area it seems durable. its not the spray on kind if that makes a difference. I've found that with multiple thick coats its seems pretty resistant to scratching. heres a short vid of me trying to scratch it with a grade 8 bolt
but time will tell, i plan on pulling it over the pit every week or so to check everything. thanks for the heads up on the proper way to undercoat, i will definetly do that on my fc. no update until tomorrow, i have to work a double and do some laundry before work
