s13 5 lug conversion ?
ok im looking for a 5 lug conversion for my s13 but im not sure which way to go. should i go with s14 spindles with 5 lugs or should i go with a conversion kit from like Ichiba? Ive done research on both but i would just like to hear some opions on both.
Thanks |
![]() Join Date: Dec 2002
It's your money, what do you want to do with it?
Ichiba is not OE but it costs less, and it's new. OE is better quality but more money, especially if bought new.
#3 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
as russ said i'd go with oem units, but then again i'm working on mine with 300zx rears since i want drum ebrake.... its all up to you, but i know i'll be getting s14 fronts oem.
Slip Gypsies Blog Quote:
im leaning towards the s14 spindles with 5 lug and 300zx rears just cuz id rather spend the money and have it done good the first time. im always open to hearing opions tho so thanks for the opions guys.
![]() Join Date: Dec 2007
![]() Don't forget to get the S14 ball joint for the S14 spindles!
For Sale threads: http://zilvia.net/f/sale-items/33286...tons-pics.html Review Thread: ![]() TRADER RATING: http://zilvia.net/f/traderratings.html?u=66301 |
Correct. You can do the LCAs too if you want some more camber, they're 15mm longer.
would an s15 brake system work on an s13. my friend bought a full front clip with complete brake systems all around. would they work? this is on a 91 180sx RHD if it makes a difference
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
Yeah Ichiba with OEM bearings is almost as good as OEM.
Because Ichiba's bearing suck. OEM is so good in fact, I put my OLD bearings into NEW Ichiba hubs.
![]() Best way to do business with me? Make your best offer FIRST. |
If you need S14 front and rear 5-lugs, let me know. I also have S14 front spindles as well. PM if you're interested.
I do not have ball joints, nor lower control arms. |
#15 |
S15 front brakes/suspension is identical to the JDM S14.
#16 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() Feedback Score: 7 reviews
Has anyone tried this?
eBay Motors: SILVIA 240SX S13 89-94 5 LUG CONVERSION FRONT REAR HUB (item 190268375515 end time Jan-19-09 15:26:08 PST) Its embarrassing posting a no name ebay product, but I was wondering if anyone has had any luck with them/ pressed OEM bearings into these? |
#17 |
you could drill out the front hubs for 5 lug
trim some fat off the back to make teh studs fight right. Then replace the wheel bearings eventually. even easier on s14 then find some 5lug rear hubs from z32 or s14
Keep it Classy |
#19 |
okay. i am just a little confuse and don't know if it is true but when i look on the ichiba website and they say that it comes with the oem bearing pressed in???? so is this true or not? is it just some kind of ichiba bearing or is it real oem???? here is the site ICHIBA 240SX S13 5-lug Conversion Front
#20 |
its OEM "spec" or OEM "style"
not a real nissan product per se i have ichiba fronts and S14 rears and have not had any problems. i swapped my 4 lug stuff with a local guy so i'm not sure if my fronts had the bearing replaced or not, but they are holding up fine for me. |
#21 |
![]() Join Date: Dec 2008
Trader Rating: (71)
![]() Feedback Score: 71 reviews
does anyone know if the older model of ichiba frt hub have oem bearing?
rear ichiba hubs splines to which axles? s13 right? also z32 rear hubs won't spline on stock s13 axles correct? thnx ya'll |
#23 |
Bandwagon.
ppl have told me to go 5 lug with the s14 because OEM are stronger than the ichiba's or what not,
thats the only thing thats slowing me down from upgrading |
#27 |
#28 |
You bumped a six month old thread to ask how to install a ball joint? Are you really that fucking stupid?
1) Remove old ball joint. 2) Install new ball joint. If that escapes you, wash your mouth out with buckshot. Please.
#29 | |
![]() Join Date: Dec 2006
but you forgot to mention he needs to press out the BJ..... yes the BJ
#30 | |
Second, You know most people use s14 ball joints on s13 LCA's. He used a s13 ball joint with s13 Front LCA's. If your gonna talk s**** go some where else. At least I didnt open up another thread thats useless. |
Tags |
5 lug conversion, s13, s14 |
