Old 04-04-2016, 03:01 PM   #31
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Yup I'm with OP too
I need that color code to match
Old 04-04-2016, 11:09 PM   #32
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
Originally Posted by BossHogg View Post
They are not confetti just so you know, they are crayola.
Best quote in a long time hehe
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 04-05-2016, 06:05 AM   #33
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
good change. how did that engine bay paint job come out(any close ups)?
supersayianjim is offline   Reply With Quote
Old 04-06-2016, 07:47 AM   #34
hvp014
hvp014's Avatar
hvp014 is an unknown quantity at this point
It was good for a rattle can job, ended up Por-15ing the bay later on.
hvp014 is offline   Reply With Quote
Old 04-06-2016, 07:48 AM   #35
hvp014
hvp014's Avatar
Love this. I know what you mean about color changes. Messes with my OCD.
Thank you, there was no way I'd just do a respray and have silver trunk/engine bay, etc.
Old 04-06-2016, 08:05 AM   #36
hvp014
hvp014's Avatar
So after the car was back from the body shop and had a photo shoot it was onto restoration.
Oddly enough Nissan Japan still stocks a lot of 32 parts 20+ years later.
Nismo metal intake gaskets
About $1300 bucks in parts in this photo. OEM front and rear wheel bearings, balljoints, kingpins, HICAS joints, seals and bushings. Completely redo the 25 year old suspension.
OEM rear finishers (the glue lets out and they sag)
New 355mm floating discs to replacing the aging ones on my F50 kit.
Nismo braided lines, balljoint spacers and front upper arms with some spare axles.
And intake back off again for the THIRD time now but on my terms haha
...To make room for my OEM powdercoated intake and battery relocate.
Remember when it was stock?
After.
Got something else back from the shop as well. R33 GTR rear brembos and my F50 kit coated.
New lines, pads, rotors, caliper seals and fluid!
Installed and bled.
Back on the ground.
Old 04-06-2016, 08:14 AM   #37
hvp014
hvp014's Avatar
Kept setting a 4WD error light, checked the code and got a G sensor fault.
Pulled the console and saw the error.
Replace analog with digital!
Next was for some headlight restoration.
All pulled apart.
Glued and sealed.
Few more photos during Cherry Blossom season.
These would be the last photos before the worst struck...
Old 04-06-2016, 09:35 AM   #38
future
future's Avatar
Trader Rating: (42)
Worst struck?
Old 04-06-2016, 09:59 AM   #39
Frank_Jaeger
No please! God, no!
That cliffhanger though.
Frank_Jaeger is offline   Reply With Quote
Old 04-06-2016, 11:24 AM   #40
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
Originally Posted by Frank_Jaeger View Post
No please! God, no!
Z_Spool is offline   Reply With Quote
Old 04-06-2016, 07:19 PM   #41
tricky_ab
tricky_ab's Avatar
Nah, Nissan guys in Japan are crazy hardcore. There's quite a few stories of the older heads pretty much forcing them to continue to produce a lot of the older parts.
Instagram
Back for round two... 4 doors this time around...
Old 04-06-2016, 08:32 PM   #42
spools420a
spools420a's Avatar
spools420a is a well-known jackass
We need more skylines sent here to Arizona,The dry climate will preserve them to the end of time.
spools420a is offline   Reply With Quote
Old 04-14-2016, 11:34 AM   #43
hvp014
hvp014's Avatar
Sorry for the cliffhanger, props for the Negan gif!
So where we last left the car was running good and everything was looking up.
One day I was driving home from work and the car just shut off. Went to restart and heard a very not normal metal on metal noise. Stopped cranking and towed the car home and started digging.
Pulled the cam covers and front cover, wasn't looking good...
That pulley isn't supposed to be be like that..
Front cover removed and cleared.
The fault was a defective idler pulley bolt and rb26's are interference engines so that meant this head was toast.
Onto pulling the motor then!
Removing minor things ahead of time
Official tow vehicle! 66hp!!
Motor out!
Decided now was the best time to clean the bay and replace hard to get to parts.
Stripped down
Scuffed and taped
First coat
Replacing leaky P/S lines!
Out with the old
Tightening up the steering system, S15 metal rack bushings and solid steering shaft bushing.
Next was to ship the motor to the builder and open the checkbook
Old 04-14-2016, 12:01 PM   #44
hvp014
hvp014's Avatar
Sat down with my builder and set my expectations and budget. 500 RELIABLE horsepower. Didn't want to have to touch the motor again and wanted to freshen up everything internally.
We went with Eagle rods, Weisco pistons, .5 mil over bore, N1 oil and water pumps, Jun crank collar, Tomei oil pan baffle, Tomei engine gasket kit (including HG), APR head stud kit, Cams and cam gears, single turbo conversion!, Haltech!, upgraded 750cc injectors, 300LPH fuel pump, Orc twin clutch, Tial WG, 33 GTR transmission and a few more things I'm probably forgetting.
With everything set, dropped the longblock off and he got to disassembly.
The block would head to Tomei in mainland for a .5 mil over bore, hone and deck.
The head well..
With all the valve guides broken the builder recommended sourcing a new head to keep us in budget. Thankfully a local friend came through with HKS cams and cam gears for $300!
Coming apart
Jun collar
Old drive length
Finished result!
Still stocking parts! External oil cooler, R34 splitfires (Igniter delete), coolant swirl tank.
Tomei baffle
A few weeks later I got the call and said the motor was ready for pick up!
Old twins out
At the shop going back in (Anyone know how to embed Youtube links?)
https://youtu.be/Vr0weGkKRXc
Back at home, waiting for more parts to show!
Scored a awesome deal on a Greddy 4" intake and hard pipping kit! Also meant I would have to pull the intake in the car... again...
Figured new motor why not new look as well....
Old 04-15-2016, 01:33 AM   #45
silviamang
silviamang's Avatar
silviamang is making a name for him/her selfsilviamang is making a name for him/her selfsilviamang is making a name for him/her self
Man this is a quality build. Keep it up!
silviamang is offline   Reply With Quote
Old 04-15-2016, 04:18 AM   #46
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Oh shit...... Cliffhanger was real
Old 04-15-2016, 05:35 AM   #47
DIENOW
DIENOW's Avatar
DIENOW is an unknown quantity at this point
Subbed! This is awesome!
DIENOW is offline   Reply With Quote
Old 04-16-2016, 01:33 PM   #48
hvp014
hvp014's Avatar
Just got a call, some parts came in.
Old 04-23-2016, 01:53 AM   #49
boostedk
boostedk is an unknown quantity at this point
Wow amazing
boostedk is offline   Reply With Quote
Old 04-23-2016, 11:07 AM   #50
MP/B240
MP/B240's Avatar
MP/B240 is an unknown quantity at this point
great build! really digging the look of that green too
MP/B240 is offline   Reply With Quote
Old 04-25-2016, 12:42 AM   #51
hvp014
hvp014's Avatar
Covers are back from the body shop. Porsche Mint Green with rainbow flake.
Installed
Oil cooler installed and Greddy I/C pipping
As well as the PIA Greddy intake
As far as I can go, need the Tuner to fab and finish.
Car getting picked up.
Photos I got two weeks ago
The build is current as of now. Still waiting for the final touches and tune, the shop is in drift season mode right now, so the car is on the back burner.
I'll update once I get some more photos and hopefully a video or two.
Old 04-25-2016, 03:30 AM   #52
rawgarage
Trader Rating: (75)
Wow I didn't expect that.... Unique color
Old 05-04-2016, 09:42 AM   #53
hvp014
hvp014's Avatar
Just a quick update, more parts are coming in.
OEM window and door seals. These rip near the top and 32's have pillar-less doors.
Heat management items
And ZLeds coming through with the new LED rear tail conversions!
As for the 32, shop said they finished some more small items and are working on a motor in for another customer 32. They're trying to schedule a 2 for 1 tune when the tuner stops in.
Old 10-09-2016, 06:57 AM   #54
hvp014
hvp014's Avatar
Way long past due update!!
It's been a busy summer for me, not so much for my 32. As it has been sitting at the tuner's shop while he was busy working and building for drift events in mainland. But finally, some progress has been made including starting and driving this past weekend. The car is now getting a inspection tune to pass shaken next week then street tune hopefully the week after.
It was such a relief to see it run again and I'm excited to get her back home.
Also, I got orders to mainland and I'll be heading there next summer for another four years of Japan! Thinking of a 33 or NSX to accompany the 32.
Any-who, onto the photos.
Coolant return plumbed for the swirl pot.
P/S reservoir mounted
Down pipe finished
And the car as I saw it today
Old 10-09-2016, 07:00 AM   #55
hvp014
hvp014's Avatar
Start up video
https://youtu.be/IOViJrhJs3k
Old 11-03-2016, 06:32 AM   #56
hvp014
hvp014's Avatar
Car passed inspection this week and is at the shop for final tune! I'll keep you all posted, its been a long year without my baby!
Old 11-03-2016, 06:52 AM   #57
hvp014
hvp014's Avatar
Forgto to add, snagged these a while back for a good price! LMGT4's in 17". Perfect for track wheels as 17" tires are noticeably less expensive.
When I first picked them up, no rash but nasty as hell.
After a trip to the sandblaster.
At the paint shop.
Back from paint!
And new tires just showed up today.
Old 11-03-2016, 09:19 AM   #58
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
That's a hell of a journey, thanks for sharing.
Is there a reason why you didn't powder coat the rims?
SoundEfx is offline   Reply With Quote
Old 11-03-2016, 09:28 AM   #59
hvp014
hvp014's Avatar
No problem, its been a big project for me time and money wise. Good news is I'll be able to enjoy all the tracks in mainland!
I have a good connection with the paint shop here locally, painted my car, valve covers and now these wheels. They give me a great price and the quality is top notch. Whereas local powder-coating shop quoted me about 3 times as much as the paint job. Joys of Okinawa.
Old 11-04-2016, 09:34 AM   #60
grapejuice
grapejuice is an unknown quantity at this point
Looking great man, awesome build!! Love that blue, someone that lives close to me has one too.
grapejuice is offline   Reply With Quote
gtr, r32, rb26, skyline
