Old 07-24-2014, 06:14 AM   #1
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
How to turbo a KA24DE with a 250-300whp goal
I wanted to write a well documented, spoonfed explanation of how to turbocharge your KA24DE. A short caution must be taken as this is by no means the only way of reaching this goal but due to certain deals on parts and plans for more power down the road, I opted for a larger turbocharger than some may deem necessary for only 250-300whp. Before I start you should read this thread from nissanclub. It gives more general advice but OPs are well versed in KA-T knowledge. My thread is more documenting my experience for others to learn from.
240sx KA-T Turbo Guide => http://www.nissanclub.com/forums/gen...rbo-guide.html
KA-T.org DOHC Turbo for Dummies => http://www.ka-t.org/viewtopic.php?f=12&t=6263
KA-T.org KA24DET Walkthrough=> http://www.ka-t.org/viewtopic.php?f=12&t=57570
Nissanforums The KA Turbo Thread=> http://www.nissanforums.com/general-...bo-thread.html
Procedure
1. Acquire Parts
2. Precautionary Steps & Installs
3. Ensure health of the motor and no leaks
4. Install Turbo and Supporting Parts
5. Break-In Diagnosis
1. Acquire Parts
Parts I used:
- RS Enthaply Tuned Engine Control Unit (ECU)
- Emusa T3/T04 50 trim turbocharger
- Emusa log turbo manifold
- HKS SSQV V2 Blow off valve (BOV)
- Sport JDM wastegate (10psi spring)
- Hallman Manual Boost Controller
- Greddy intercooler
- S13 SR Greddy intercooler piping
- Isis 255 LPH fuel pump
- Five-O 550cc injectors (sidefeed)
- Isis intake filter
- Exhaust Gas Recirculation (EGR) block plate
- J30/Z32 mass air flow (MAF) sensor (N62)
- Deka ETX30 Battery
- Glowshift Boost Gauge
- Glowshift Oil Pressure Gauge
- AEM Wideband
- Oil Pan Tap
- Isis Radiator
- NGK BKR6E spark plugs
- Beck Arnley Water Pump
- ISIS 3" blast pipes
- Various oil lines, fittings, vacuum line, T-bolts, zipties, fresh oil, oil filter, small filter/breather, etc
Many of these parts I got for silly cheap from mostly Craigslist, Zilvia, friends, and Enjuku Racing. This is not recommended or advised but I was on a tight college budget and took a risk. If you can spend money on a few of these items it would be Tune, Turbo, and Wastegate/BOV.. in that order. Instead of scraping by just to turbo my car I spent money on food, beer, rent, mountain biking and other fun things too so this build took around 1.5 years to acquire while in college. All in all I spent around $1400 preparing, installing and getting this project running. Anyone that says you can do it for cheaper is either neglecting other costs such as oil, coolant, radiator, tune, etc or got it for free from some buddy deal. Even doing it cheap you still have to pay to play. This is also on a stock block with 260,000 miles on it, 165psi across all four cylinders. Please realize just because I chose some cheaper alternatives does not mean I cut corners. If you have broken parts on your car before installing this stuff, you're going to have a terrible time when your car doesn't run.
Some small advice now:
This is when you install everything you possibly can without actually seeing forced induction.
Engine:
This will likely be the downfall of this build for me. Ideally you should rebuild your motor at the very least when at such high mileage as myself (260k miles), but if the compression test checks out I'm willing to try for pushing the limits of a high-mileage KA. If the money is there though, you really should go with forged internals and refurbish the head for optimum power output and hopefully a lower chance of grenading the KA. I've come to learn that stock internal KA's are good to about 350hp but don't think that's a guarantee or a limit. I'm sure plenty of people have popped their motors on T25 setups and I also know people who have made stupid power (576whp on stock KA with new head gasket & 200,000 miles). Power, cost and reliability...choose two.
Engine build discussion/SR consideration => http://www.ka-t.org/forums/viewtopic.php?t=46682
KA-T.org How to build KA24DE => http://www.ka-t.org/forums/viewtopic.php?t=4156
How to build KA24DE or KA-T => http://www.240sxforums.com/forums/ka...24de-de-t.html
Upgraded Radiator:
You will need this to help cool your turbo engine. Whether the turbo is water cooled or not, the additional heat from forced induction will have an adverse effect on the rest of your cooling system. While you're here change the coolant, coolant hoses and/or thermostat as need be. Read up and choose at your discretion the temperature thermostat you should use. My opinion is to not use a colder thermostat and just replace with OEM temperature (I believe its 170 F, order from RockAuto). I also chose to only install an upgraded radiator and retained my mechanical fan. I went with the ISIS radiator and have had no complaints. Beat on it through summer mountain runs and drift event and never seen my OEM thermostat gauge move. Maybe a real water temp gauge would tell a different story?
NICO Radiator Install => http://forums.nicoclub.com/isis-prod...s-t427793.html
Altima Electric Fans:
Another modification I was at first intimidated by but realized this is pretty easy as well. I used the first generation Altima fans (93-97). The fans and shroud costs $30 at a junkyard. Unfortunately the S13 is a litte more difficult to fit the fans in. I measured around 26.25" clearance between frame rails while the Altima fan shroud measured just over 28" wide. I was doubtful but if you trim the Altima fan shroud it surprisingly fits well.
My Tutorial => http://zilvia.net/f/showthread.php?p...13#post5750513
BADASS information on Cooling Setups: http://texasnissans.com/tx/forums/sh...ad.php?t=10117
Water pump:
This is straightforward, your KA likely has ~200k miles on it at this point so replace the water pump. OEM replacement is fine. In hindsight, might not be a bad idea to change your front main seal while you're there as I did. Oil pump would probably be a good one to consider as well. If I had to do it over again I would've done the oil pump too for safe measures but it's all up to you in the end.
NICO Water Pump Install => http://forums.nicoclub.com/1991-1994...e-t220947.html
KA Coolant Bleeding Procedure:
This is the easiest and most simple way I've found to efficiently clear our cooling systems of air. I can't remember which forum I sourced this from but read carefully.
1. Fill cooling system with whatever you want mix-wise with the bleeder closed. Fill it until it doesn't take any more.
2. Open the bleeder screw, squeeze the upper radiator hose frequently, fill it until no more air (only liquid) comes out.
3. Leave the radiator cap off and bleeder off if you don't get pure liquid out of it.
4. (Optional) Jack the front of the car up with floor jack or park on steep hill, front of the car facing uphill.
5. Turn the car on, put temp slider to full heat, turn blower on. Let car run and close bleeder once pure liquid comes out. Leave radiator cap off, let car warm up, add coolant as needed when it goes down (thermostat opens).
6. Once you have the thermostat open and heat coming out the vents, top off the radiator. If you want to double check the bleeder for pure liquid open it back up and see. Close bleeder, put rad cap on, and fill the coolant reservoir up to the line. Done
Intake:
Most of you I'm sure already installed a cone filter but if you haven't, purchase one and install for now. Odds are nothing will fault here but it's worth making sure one more thing won't go wrong (advice from sleepy_steve).
Gauges:
The choice in gauges is all up to the driver. Some people want every gauge under the sun, others don't want any at all. I would recommend boost and oil pressure for someone low on budget while still providing some decent insight on how the turbo motor is running. A wideband O2 would be nice if you can tune and/or want to monitor combustion. Water temp is another good gauge to have as the factory gauge is not very accurate. Here is a quick DIY of a boost gauge install I did temporarily before the turbo was installed. Also, don't buy stupid tinted gauges like I did haha. I thought it was cool and would look nice but you can't see them worth anything, especially with a convertible.
First, choose your mounting location and test fit. I chose to get rid of my center vent and installed this gauge pod from eBay. I attempted to make one myself but sheet metal I had lying around was too thin.
Wire according to gauge manufacture. Most gauges don't draw much anyways so if you have three gauges you're looking to find a power wire for, the radio harness should have plenty to splice into.
This might also be a good time to start simplifying vacuum lines. I've seen some remove many of the lines coming from under the throttle body with the intention of having a vacuum block in the brake booster line. I chose to retain close to stock vacuum routing, will edit this if I have problems and modify.
Battery:
You have two choices here: Relocate or resize your battery. I initially thought relocating to be cheaper and better but ended up choosing resizing.
Smaller battery
You will read everywhere about every which option to use. The most frequent options I see are:
  • Lawn mower battery
  • Miata battery
  • CRX battery
  • Odyssey battery
  • Deka battery (Rebadged as BigCrank, Braille and other brands)
In my opinion the lawn mower battery is underpowered for most applications and cuts too many corners, might be good for a track car but I am looking for daily duty in the always variable Virginia weather (100+ degree summers, below freezing winters). The Miata battery appeared to be a overpriced lawn mower battery as they have nearly the same CCA. The Odyssey battery was my initial first choice but after reading up on it I wasn't sold on this pulse technology capable of 680 CA but only rated at 220 CCA. The CRX battery sounded great too at 500CCA but was too wide at 9.5".
I found that the longest your battery could be for a quick and painless install was ~7" and the minimal CCA to turn over a KA is 356CCA (refer to FSM). This led me to the ever popular Deka battery. Some use the lightweight, small, low CCA versions but I opted for the Deka ETX30 that fit very snug in the stock battery location and rated at 400CCA. Not a lot of comfort room for starting but it'll have to do.
More battery Info=> http://www.freshalloy.com/showthread...weight-battery
Remove stock battery, rotate Deka battery as necessary and install.
I also modified some things and made a tie down. Photo above does not show tie down and only a temporary configuration.
Relocate
I chose against this for a number of reasons: my battery was old and about to go, venting the battery properly when in the contained space was initially difficult to account for, and 2GA wire is more expensive than I expected. Regardless...here's a tutorial.
Budget Battery Relocation=> http://www.nicoclub.com/archives/low...elocation.html
Emissions (EGR, PCV, Charcoal Canister):
One of the most confusing aspects of the turbo install for me, there really is many ways of doing this as well. I still can't tell you what works best. In my opinion this is the worst part of turboing a KA is figuring this out.
Reading material:
240SX One EGR Removal => http://tech.240sxone.com/115/ka24de-egr-removal/
Zilvia PCV Discussion => http://zilvia.net/f/chat/285145-conc...worthless.html
KA-T PCV Discussion => http://www.ka-t.org/forums/viewtopic.php?f=2&t=27437
Zilvia Vacuum Discussion => http://zilvia.net/f/tech-talk/362347...help-pics.html
EGR
The EGR system has been given a bad name but I don't think it's inherently bad. Positively the EGR system reburns exhaust while in vacuum to improve fuel economy (unburnt hydrocarbons), lower combustion temperatures which are already enhanced from the turbo, and lower emissions specifically NOx. The reason this is so commonly removed is because most are too lazy to weld a bung in the downpipe to continue to operate the system correctly. Admittedly, I have also ditched the system as well because it frees up quite a bit of space in the already tightly packed KA intake manifold and I didn't have easy access to a welder. In the future I'd like to reinstall this system. Below is block off plate that can be made from nearly anything. Trace the shape from the removed valve. Refer to the tutorial above this section on how to remove.
PCV
Here's an example of the OEM crankcase PCV configuration:
Originally Posted by S14DB
Here the red lines are connected in the factory NA setup.
I run the crankcase vent to a catch can (air-oil separator) that will draw air pressure out via the turbo intake. The valve cover port will have a breather filter on it and the 4-1 vacuum tree will be closed as indicated here. This a common method but some prefer an 'old school' method where you create a venturi effect by using your exhaust. The intake is an easier setup in my opinion but you do you, eventually I'd like to try the exhaust setup. Again, emissions are debated quite a bit and this is just my opinion.
PCV valve replacement => http://www.240sxforums.com/forums/ka...-dohc-dyi.html
More PCV info => http://forums.nicoclub.com/positive-...d-t446254.html
Even more PCV info => http://www.lotustalk.com/forums/f25/...r-vent-100572/
Summary of Different Crankcase Evacuation Methods => http://honda-tech.com/showthread.php?t=1199935
Charcoal Canister
Many simply remove all lines and canister then bend the hard line in the engine bay coming from the gas tank downwards. This is one option but I chose to remain close to emission legal ...err at least look like I am. I simply removed the two lines coming off the valve on top of the canister. The smaller, top one was then placed in vacuum by being attached to the turbo intake pipe while the other, larger bottom hose of the valve is VTA and pointed downward. This keeps the appearance of no modification even though it is VTA.
AIV PAIR Valve (S13 only)
Remove this.
NICO Tutorial => http://forums.nicoclub.com/1989-1994...l-t254273.html
Oil Feed & Drain Lines:
Ensure no leak and that the bung isn't too low on the pan or the oil drain line will not drain correctly. Incorrect drainage from the turbo from either too small of a drain line or incorrectly positioned oil pan bung is a failure point for any KA-T. Also account for the slight angle at which the KA sits at on the subframe. Cap the fitting once installed while still NA. Below is a pic of my turbo oil drain line.
Oil Feed/Return Line info =>
Great Links: http://forums.nicoclub.com/pics-oil-...g-t140446.html
http://zilvia.net/f/showthread.php?t=176575
For feed lines refer to this post:
Originally Posted by Northwest Nissans forum
There are a few ways of going about this. Its really all about personal preference (some ways look cleaner then others but all work very well)
Greddy makes Two different ways to do an oil feed line.
The first one is an oil filter relocation kit. This one is the most expensive. This one is nice though because you can run the oil feed line to the turbo with the provided Oil filter block adapter (Sandwich plate) and it also is set up to let you run an oil cooler. (I dont have any pictures of this set up but its what I'm planing on running)
The second one is to just get the Greddy Oil filter block adapter (Sandwich plate) This will allow you to run a oil feed line around to the turbo and it looks pretty clean.
Greddy Sandwich plate
The third way to do this is from the oil pressure sending unit. Like the previous post said its just a few brass fittings and then run the oil feed line around the back of the motor and to the turbo. Its not always the cleanest looking way though, unless you take the time to make it look clean. Its probly the most cost effective way to oil your turbo.
Oil pressure sending unit
Brass Fittings => http://www.mcmaster.com/#catalog/119/36/=q6hwn4
Turbo End of the feed line info for T3 or T4 (with part numbers!) => http://forums.nicoclub.com/oil-feed-...ll-t96306.html
Here is my parts order from McMaster Carr:
  1. 50785K219 Medium-Pressure Brass Threaded Pipe Fitting, 1/8 Pipe Size, Female X Female X Male Tee $2.81
  2. 5832T111 BSPT-to-NPT Threaded Brass Pipe Nipple, 1/8 Pipe Size X 3/4" Length, Fully Threaded $2.79
  3. 50695K171 Steel 37 Degree Flared Tube Fitting, Straight Adapter for 1/4" Tube OD X 1/8 NPTF Female $1.86
  4. 50785K161 Medium-Pressure Brass Threaded Pipe Fitting, 1/8 Pipe Size, Cap $0.91
I was already given a -4AN oil feed line, a -8AN drain line, and turbo fittings so they are not found on my list. For reference:
Fuel Pump:
Thanks to the stock fuel pressure regulator, an upgraded fuel pump can be installed in a stock 240SX. Some have reported fuel pressure can be found to be 3psi higher at idle due to a more powerful fuel pump but performance should remain the same. There are plenty of tutorials out there on this, check out some of the following links:
Zilvia Fuel Pump Install => http://zilvia.net/f/archive-faqs/143...-approved.html
If you wish to do so, an adjustable fuel pressure regulator can be installed at this time too but I had no use for it just yet. All this allows you to do is exactly what it sounds like...adjust the fuel pressure if you wish to alter or tune the performance of your engine.
Hot-wiring Your Fuel Pump:
After installing the turbo, I had issues with an erratic AFR at idle and lean in boost (13.2). After reading a few threads and talking with Martin at RS Enthalpy, it was suggested I do this procedure. The basic premise is that stock fuel pump relays and/or wiring can become faulty and fail to send your fuel pump the full 12V signal. Typically fuel pump relays are designed for low load (9V) to enhance the life of the fuel pump and high load (12+V) to keep a rich combustion. This modification allows your fuel pump to see the high load setting all the time by wiring it directly to the battery through a relay (important!). Do not just run a wire from the battery to the fuel pump or use just a switch. For electrical noobs, a relay and an inline fuse close to the battery are a necessity for safe electrical operation.
Tutorial: http://www.ka-t.org/viewtopic.php?f=12&t=59949
More info: http://blog.amsperformance.com/2009/...r-to-run-lean/
Intercooler routing:
Like many aspects of this project, this is another with quite a few different ways of doing so. Most use eBay S13 SR intercooler kits and have no issues. Some that do a low boost don’t run an intercooler at all. Others run a custom assortment of bends and couplings found on eBay, source at shops, etc. I was lucky enough to acquire an SR Greddy intercooler kit with piping that only required small modification to fit for cheap.
This is also a time to consider which layout you choose to place your MAF or convert to MAP. I will not lay out every detail there is to know on reliability, performance, etc of each but I'll explain briefly what I know. All requires different tunes so be aware when ordering pretuned ECUs and what not. The green box is the MAF.
1. Draw through MAF
This method seems to be the most common and easiest to install but boost leaks would be a nightmare. One leak in the system and that's metered air going out the piping. This is most common because installation is the most straightforward. Be careful and don't place the MAF too close to the turbo inlet, it can cause screwy readings especially at idle.
2. Blow through MAF
My personal preference, this setup is more difficult to install and account for but provides better driveability and reliability. Please be aware that the tuner must know about this setup if applied. As many understand, the MAF readings are based off of a hot wire in the center of the MAF housing. This wire is then cooled by airflow, changes the resistance of the wire and as a result sends a proportional voltage signal to the ECU. Due to the effects of compressing air, flow from the turbocharger, even after intercooled, is still warmer than ambient air seen at the turbo inlet. This can result in a lean condition of operation due to reduced cooling effects on the MAF hot wire. My reasoning behind choosing blow through is that in the event of a boost leak, it is just boost lost at the MAF since it is placed so closely (~within a foot or so) of the throttle body. In other words you could blow a coupler off and continue on without incident. It’s important to note that the MAF should be placed in the center of a straight section to avoid turbulence generated at corners and what not. In Greg Banish's Engine Management: Advanced Tuning he also makes a point that
Originally Posted by Greg Banish
Since airflow is biased towards the of outside radius of a bend, placing the metering element on the outside radius of a bend yields an output that indicates higher total flow than is currently present. The opposite is also true with reduced outputs resulting from element placement on the inside radius of a bend. Generally speaking, if the MAF must be placed following a bend in the inlet plumbing, it should be done such that the element in perpendicular to the plane of the bend...
Constant diameter approaching the MAF sensor is also desirable. Remember that the same mass flow through a smaller diameter increases velocity. If the diameter of the inlet plumbing increases immediately ahead of the MAF sensor, it often results in an unstable charge flow with plenty of tumbling. This tumbling air may cause the wire element to read incorrectly depending on inlet flow and velocity. A length of straight, constant diameter pipe is preferred before any mAF sensor. Typically this length should be at least double the diameter. This gives any tumbling flow an opportunity to stabilize before entering the sensor.
Many OEM applications reduce clocking and velocity effects by integrating a laminar flow element into the MAF sensor assembly. The design of these flow straighteners ranges from simple wire screens to honeycombs with an exceptionally high Reynolds number. Many performance enthusiasts looking for extra power mistake the laminar flow element for a genuine restriction and remove them. Benefits of removal rarely justify the loss in metering accuracy and usually fall well below statistical accuracy of most chassis dynamometers. Typical changes I have seen from such modification rarely exceed 4 hp at the wheels even on modified V8 engines. If a vehicle has a modified inlet system and erratic MAF sensor output, it is often helpful to install some sort of flow straightening. This can be done with a simple wire mesh or length of straight pipe leading into the MAF sensor.
3. MAP or manifold absolute pressure is virtually what a blow through setup wants to be. KA's are not factory equipped with MAP sensors so this is a completely custom job. Basically instead of measuring the flow rate of the air passing by the hot wire of a MAF, MAP sensors read intake air pressure in the manifold or plenum. You will have to research this yourself as I'm not well versed in this.
Global Tech Engineering => https://www.globaltecheng.com/Produc...idCategory=145
Race Part Solutions => http://www.racepartsolutions.com/ind.../mandrel-bends
eBay
Make sure you aren't missing bungs for said Idle Air Control Valve (IACV). Although, no big deal if you do not have a bung for IACV on your intercooler pipe, you can be super racecar and 'crack' the throttle body open.
Originally Posted by KA-T.org
What we mean when we "crack" the throttle body open, is just adjusting the stopping point of the throttle plate within the throttle body.
Basically, if you move the point where the throttle plate stops (in closed throttle position), you are allowing air into the intake. This supplies more air to the motor and raises your idle.
That is all the IACV does, is allow air into the intake to raise the idle and maintain it. It's just electrically controlled, and has been known to be a common failure point on intakes (I had this happen on my last 240 and it was a pain to deal with).
Originally Posted by KA-T.org Photos
This is a picture from the passenger side of the car. The picture is of the throttle plate "cam" / wheel (whatever you want to call it). You can see the throttle cable coming in from the top. It's tied to your gas pedal.
When you push in on the gas pedal, the cable retracts and pulls the wheel counter-clockwise.
Full throttle stop
What I have circled is the full throttle stop. You should never have to mess with it, so don't worry about adjusting it. I just wanted to show it cause it's easier to see... The line points to the jam nut (retaining nut) that holds the position of the set screw. By adjusting the set screw, it changes how "open" the throttle plate goes.
180° from this position is the closed throttle stop which you will see in the pictures below.
This is the "closed" position throttle stop. It is on the bottom side of the throttle body. This is the piece we're talking about having cracked open just a bit to raise your idle when you have no other means of doing it (removed IACV, etc.)
Closed throttle stop
The green arrow points to the jam nut. It takes an 8mm wrench to loosen the nut. Once the nut is loose, you can use a 2.5mm allen wrench ( http://en.wikipedia.org/wiki/Allen_wrench ) to either screw in, or screw out the adjustment set screw (red arrow). By adjusting the set screw either in or out, you effectively change the position of the throttle plate when there is no gas pedal input. By screwing more of the set screw towards the wheel stop, you raise the idle. By retracting the set screw, you reduce your idle.
Here is a picture showing the throttle plate open a little bit (as if you're applying the gas pedal).
Hope that helps...
Power Steering Reservoir:
Potentially relocated if you choose to face the outlet of your compressor housing to the drivers fender. Conversely,you can clock the compressor housing downward and avoid the relocation of this PS reservoir and external coil at the cost of additional bends in the hot pipe. I have my turbo clocked downward and initially had to unbolt the reservoir for it to fit.
A more permanent solution will be a reservoir relocation, placing it in the corner with clutch master cylinder and brake booster. This is the way to go. Not only will the reservoir heat soak next to the compressor housing, but your power steering fluid will be more likely to boil over. I had issues while NA KA with boiling over my PS fluid at drift events. To correct this, relocate the power steering reservoir in the corner of engine bay right next to clutch master cylinder. It's so easy, don't stress it.
INSERT IMAGE
And while you're at it get some extra power steering lines and add a PS cooler. Super cheap to do. Here's a tutorial but it really only costs like $45 including lines, cooler, and ATF fluid (you should always use ATF for power steering fluid).
External Coil:
Again, this may not need to be moved but this is all dependent on hot pipe routing. I didn't have to move mine and doubled the location as a holster for my manual boost controller
Adjustable Fuel Pressure Regulator:
Stock FPR is fine for 99% of turbo KA setups. I ended up installing one of these for future applications and experimentation. Spend the money on a decent one (SARD, Aeromotive, Tomei) to save yourself the headache of poor regulatory performance. My Aeromotive setup ran me around $200 which is steep but worth it. Also I read to remove the gauge once you're done because under the hood temps can damage it. If you just want a way to ensure fuel pressure is correct, I would recommend an inline fuel pressure gauge so you can ensure the fuel system is operating correctly for a fraction of the cost of an AFPR.
[PIC of AFPR]
Upgraded Clutch:
Another item I thought wasn't all that necessary but first time in boost and I was already kicking myself for not doing this beforehand. You can do your typical 240SX clutch upgrade or look into the White Bunny. I will leave the story-telling behind the name in other threads detailing this White Bunny setup but basically you can retain stock clutch pedal feel with greatly enhanced performance. I spent around $250 for a 13lb RB25 flywheel and Exedy RB25 stock clutch. A cheaper setup can be easily had but I valued the lighter flywheel.
http://forums.ma240sx.net/showthread.php?tid=16
http://www.nicoclub.com/archives/240...heel-swap.html
Tuning Options
This section is still in progress (7/29/2014) as I hope to make this more of a general section. You have three tuning options as I see it:
1. ROM "Mail Order" tune
2. Full standalone
3. Piggy-back tuning
And for those of you looking to tune or even modify a ROM tune with a SAFC...just don't do it..
Originally Posted by Croustibat View Post
Originally Posted by Zilvia member
It doesnt hurt, thats what I did with my first S14. Enthalphy romtuned, AFR was dipping down to 10s, leaned it out a tad bit to 11-11.5 at WOT with a SAFC.
Congrats ! You just ruined the timing part of the tune
This goes to all SAFC users: do yourself and your engine a favor : throw that piece of crap in the nearest bin. What is does is altering the MAF signal to make the ECU believe there is more/less air going in. Problem is, that MAF signal is used to compute the "load" of the engine (TP value), and that value is used as an axis on the main and secondary fuel map AND timing map, amongst other things.
Lowering fueling by changing the TP value means you are most likely to be adding timing advance. Enriching usually does the opposite... usually, because there is a reason there are TWO distinct maps with the same axis : the values between the fuel map and the timing map are not proportional.
SAFC users don't know anything about tuning, because anyone who does would not touch an SAFC, even with a pole (a hammer is ok though)
that being said, if you want a spot on tune, SORT THE CAR, then get it tuned on a dyno. There is no other way.
If you can be satisfied with a conservative, generic tune, then get a rom tune.
And by all means, if you don't know enough about engine tuning to do it yourself ... DONT do it yourself with a SAFC...
bmaddock is offline   Reply With Quote
Old 07-24-2014, 06:15 AM   #2
bmaddock
bmaddock's Avatar
Now that you’ve installed all the parts you can without actually installing the turbocharger, make sure everything is running correctly. Make sure you’re not leaking fluid because this will just make this experience far more painful than it has to be.
Compression Check:
You should see all four cylinders have within 10% difference of each other and should be greater than 100 psi. Realistically you should be looking for close to 140-160 psi. Any lower and you likely have some trouble or if there is an outlier get ready to diagnose and solve that issue (read as valves, headgasket, or piston ring).
To perform a compression check, follow this guide HERE
Leakdown Test:
Perform in conjunction with poor compression test numbers. Instructions HERE. This will give a more accurate description of how well each cylinder seals and give a much easier diagnosis of where the leak is.
Visual Test:
Watch out for vacuum leaks. Technically in this part of the thread the turbo isn't installed but realize every loose intake connection has chance to cause issues. Use thread sealer, electrical tape, whatever you have to ensure there will be no lean idle issue or excess unmetered air entering the engine. A good indicator of vacuum leak once turbocharged is you're lean at idle and rich in boost. Think about it and it should make sense. At idle you have vacuum and will be pulling in unmetered air while in boost you will be pushing out metered air. You also should see around -20 vacuum.
Please make sure you didn’t just skip to this step and for any sense of reliability read and perform the previous steps in this tutorial. Begin by disconnecting your negative terminal.
MAF:
As mentioned earlier, it is important to consider the placement of the MAF in our system. To install this device, some small rewiring to the MAF of choice is required. There are many great tutorials available below. I wired in an N62 MAF from an Infiniti J30 but can also be found in Z32 300ZX. Here is my Blow Through setup installed. Note the window weld around the housing cap to help prevent boost leak/the MAF popping out.
For now I simply cutoff the flange on the plastic MAF housing (lowsy method) to hold me over until I purchase/make something like this: (NOTE: MAF housing must remain constant as the sensor is dependent on pipe diameter). To make this tutorial as clear as possible, just take an angle grinder to the flanges and switch to a flap wheel for final grinding. I went all the way down to where you just barely start seeing the edge of the metal mesh to make sure it's a clean 3" OD for the coupler to clamp to.
Injectors:
Mostly a simple plug & play, install these injectors as you would any other. Some injector choices require 2 or 3 wire pigtails to be spliced into the KA harness. DO NOT reuse injector o-rings. These can be attained for silly cheap at hardware stores such as Tractor Supply, True Value or Ace Hardware (just bring in an old pair and match the size) or paying for marked up o-rings at Advance Auto. It's not worth it to have a leaking injector and have trouble diagnosing first start-up. Also use some oil on the o-rings to keep them from pinching. More tutorials HERE.
Spark Plugs:
Quote from KA-T.org
Alot of people have great results when using copper plugs. I have also had great results.
and kind of a standard are the NGK BKR series.
for our cars stock you would want to use the BKR5E plugs gapped at .043
moderate boost high 200 low 300 range you can use the BKR6E plug. Gapped around the .032-.034 range.
Now for higher hp you need colder plugs. the BKR7E are used and gapped in the .030 range as well.
Also, you always want the biggest gap you can possibly get. but with our turbo'd cars the extra forced in air will blow out a spark with a higher gap. so thats why people lower the gap.
but if you plan on upping the boost very soon then get the 7E's. if not then get the 6E's and try gapping at .034". if you get some breaking up at top end then lower the gap slightly until that breaking up goes away.
Install spark plugs accordingly.
ECU:
Make sure the negative is disconnected from the battery and that you have grounded yourself, dumb mistake that could cost you. Be weary of static electricity on your body. Another straightforward procedure, remove the passenger kick panel, remove ECU and install pretuned ECU. Button the kick panel back up and close the passenger door.
I actually had some issues with my ECU after some problematic diagnosing and found a broken connection. Below is an image Martin at RS Enthalpy sent me indicating two common connection failures for our ECUs. It takes only a minute to open and check your ECU out so make sure to do this if you're having trouble diagnosing problems. 99% of the time though it won't be ECU, this is a last resort.
High Res: http://i.imgur.com/dbDZzHm.jpg
Also, you can repair any broken connections but was told the ECU can become temperamental and act buggy. Common practice is to simply find a new ECU and move the ROM tune daughterboard into the fully functional one.
Manifold:
Unbolt NA header or exhaust manifold and replace exhaust gasket. Bolt the turbo manifold on accordingly. This is where you may start noticing issues with your Power Steering reservoir and why it must be relocated or your turbo clocked accordingly. I also had issues with using a crappy ebay (Emusa) manifold and needed to modify a stud to fit correctly.
External Wastegate:
In my application I’ll be running an external wastegate with a screamer pipe. This is not for everyone, in fact you may have a divided downpipe of wastegated exhaust or you may be internally wastegated. We'll see how long this lasts, I might route into the downpipe eventually.
Turbo:
Place the turbocharger on top (or below) your manifold and bolt it down. Now back up and take some sweet pictures and show it to your friends. It’s important to correctly run the oil lines to the turbo now.
PRIME THE LINES. This is critical to life of the turbo and in particular the turbo seals. Similar to compression test, remove coil wire and fuel pump fuse. Then crank the motor over 3-5 times in 10-15 second intervals. Ensure drain line is installed first or if you're nervous the turbo isn't receiving oil, leave off and visually confirm the oil feed line is primed.
Some turbochargers also have coolant lines that run to them for additional cooling. Common routing options here involve splicing into existing water lines before and after the heater core. For a decent example check out this 350Z watercooled turbo install:
http://my350z.com/forum/forced-induc...on-thread.html
Intercooler:
Another bolt-on affair, install your intercooler with provided or custom tabs to the bumper and radiator support. Route piping appropriately and tighten down hose clamps. A hole saw can be helpful in cutting holes for the intercooler pipes to come through. Install the blow off valve, intake pipe, air filter and MAF at this time as well. An angle grinder will do work on the bumper support and cut clearance for the larger intercoolers such as the Greddy one I used. You will likey need to modify the front bumper cover. I honestly used scissors to get the most controlled cut and not have molten plastic slinging everywhere from using a cutting wheel. [img][/img]
Blow off Valve (BOV):
Install blow off valve appropriately. I placed this here also to warn those of the HKS V2 SSQV. I had some issues with compressor surge and no venting due to a stiff spring. Google what I'm talking about but the V2's had no adjustment and the spring was rumored to be set at 18psi. To remedy this I installed a sprinkler head spring with a much softer spring rate.
[PIC OF BLOW OFF VALVE]
Exhaust:
Get the downpipe bolted on to the turbo and jump under your car to connect the midpipe and remaining portions of the exhaust. I had issues with the downpipe hitting the brake lines coming off the brake master cylinder. To solve this I acquired an S14 5-speed, non-ABS brake booster as opposed to my S13 auto, non-ABS booster (yes my car is 5-speed swapped). Differences shown below.
As for the rest of my exhaust, I only had a downpipe and midpipe and then went to an exhaust shop for the remainder of my custom exhaust. This way you can have it fit correctly and function the way you want, not the way some crappy ebay company wants it to fit.
Manual Boost Controller:
Vacuum Lines:
Here is my Vacuum Diagram detailing anything I've modified from the factory connections.
It has been suggested for me to install vacuum block in the brake booster vacuum line for better consolidation but felt lazy when installing all of this. It will happen eventually but you can get by with mostly factory vacuum setup like mine.
Check your work:
Take the time now to hunt for any obvious problems. Make sure you refilled your oil, clamped all the hoses down and plugged all the injectors, MAF, and gauge equipment. Fill any lost coolant or oil that may have been lost during the install.
Once everything is installed, fluids are filled and battery is charged it's time to start the car. If the car does not start begin diagnosing, starting smallest and cheapest and working your way up. If your car starts but does not idle refer to some of my experiences posted below. Once idling smoothly it's time to go for a test and tune run. Stay out of boost and keep it calm and smooth for the first few miles. Let the engine warm up and make sure you have no air bubbles in the coolant. Basically make sure your car ran as good, if not better than you did while naturally aspirated.
Then start easing into boost. Every psi of boost is substantial at these early stages so work your way up. Any problems with your vacuum lines, MAF location, intercooler pipes, PCV system, etc will begin to show up now. Eventually you'll work your way up to full boost. Not much more advice for you after that. Happy boosting!
For reference (Enthalpy tune, yours may be different):
14-17 Idle AFR
14-15 Partial throttle criusing
17 in gear, full vacuum AFR
12 or lower in boost AFR
-20 inHg at idle
-25 inHg in gear, full vacuum
Common problem areas: boost leaks, torn injector o-rings, fuel pump not hotwired, vacuum hose loose, SAFC, failed sensors (check ECU codes).
Final Thoughts
This thing is silly fun. No dyno verification but even with a slipping OEM clutch this thing is a blast. I won't drag this last paragraph on any longer than it needs to be but I would suggest this to anyone looking for experience in turbocharging cars and looking for more power out of their KA. It's been a tremendous learning experience and makes me proud to drive my car knowing I did this whole installation. Who cares about SR this, KA-T is better than that, blah blah blah because it's all fun in the end and I can't be more happy. I'll try and get dyno results up one day but that might be a bit.
There's always going to be problems with your build and bigger, better ways of doing things. Try not to get wrapped up in all the options and commit to one of them. Nothing ventured, nothing gained. With this experience I'm already looking to learn more and indulge in my next adventure, standalone DIY tuning. Good luck to everyone and make sure to search for this info, it's definitely out there.
For those still interested, here are some other parts I’ll be installing soon...
Name Brand (Garrett, BorgWarner) T3/T04 turbocharger
Name Brand (HKS, Tial) Wastegate
White Bunny clutch setup (D21 flywheel+300ZX clutch
Powered by Max multigauge (Volt, Oil Pressure, Water Temp)
Standalone ECU
Other stories/build threads I learned from:
http://www.ka-t.org/forums/viewtopic.php?f=40&t=39690
http://www.ka-t.org/forums/viewtopic.php?t=38784
Old 07-24-2014, 06:15 AM   #3
bmaddock
bmaddock's Avatar
Install Diary:
Day 1:
I had issues installing the turbo manifold as the exhaust studs hit the manifold's turbo flange. I had to cut the stud shorter. Also had the downpipe hitting a brake line coming off the brake master cylinder. To solve this I acquired an S14 5-speed, non-ABS brake booster as opposed to my S13 auto, non-ABS booster (yes my car is 5-speed swapped).
Day 2:
The largest problem I'm having is lack of idle right now. The engine will turn over but I'm forced to feather the throttle to keep it really alive. It will idle but sounds off in timing and barely holds it. I checked the resistance and continuity in all my injectors and they appear good (11 ohms). Hooked a timing light up to each spark plug wire and spark seems to be consistent. There is also some white smoke coming out of the downpipe (the extent of my exhaust right now) that could be oil but I think is indications of rich combustion.
I'm going to look more into this tomorrow but am curious if anyone has better suggestions. My main leads are possible vacuum leak, bad o2 sensor, off in timing (though I don't know how as it was never touched and ran fine NA), or leaky injector o-rings. It could also be an incorrect tune but can not rule that as an issue just yet. I've also considered crankcase ventilation as an issue because right now I have the stock (NA, OEM) PCV system in tact expect for the valve cover port is now in the turbo intake plumbing instead. Eventually I'd live to place the valve cover VTA and place the PCV valve in vacuum using the turbo intake pipe while blocking off the intake manifold but I don't think this should be an issue while just attempting to idle. I could be wrong, please correct me if so.
Day 3:
Fixed my crankcase vent earlier today and cleaned my MAF. Correctly routing the PCV so that it's in vacuum via the turbo intake, blocking off the vacuum tree into the manifold, and put a filter on the valve cover.
The car still starts right up but won't really idle. Seems rich (no wideband) and no smoke anymore. I got the car to idle eventually but it's less than 500 rpm. I then tried holding the engine at a certain speed but it would slowly bog down and try to stall out. I'm going to post up my vacuum diagram later but don't forsee any issues. Suggestions are appreciated.
Day 4:
Took some time and cleaned MAF connection, still ran about the same. I then plugged IACV and ran slightly better but I still could not hold the engine at one speed. I pulled the dipstick out and faintly could smell gas...leading me to believe that my timing is off. Does anyone know what Martin (RS Enthalpy) sets timing to? I emailed him but I'm sure he's busy this week. Used tune is not the way to go, forgot about timing.
Day 5:
Car is running better. I replaced the O2 sensor, got new injector o-rings since mine were pretty loose fitting, and cleaned corroded MAF connections. It fires right up but seems to chop up, hesitate and stall out now. Below is a video of how it's running. I only see -15 at idle though so I'm certain of a vacuum leak but haven't actually looked since I noticed that tonight. I'll try some tomorrow. I fear my EGR block plate isn't sealing well enough. I also noticed a sizeable exhaust leak I'm looking to plug up tomorrow. I'm sure this doesn't help me out with even more skewed O2 readings causing rich conditions.
Watch at 0:14 when I hold the gas pedal at the 2000RPM position yet the motor chokes and stalls (too much fuel?)
[video=youtube_share;yQSm-seLbtA]http://youtu.be/yQSm-seLbtA[/video]
Day 6:
Took me a while to do the obvious but finally checked codes and got code 34, knock sensor. I should have checked this before hand but after plugging up all exhaust leaks and any potential vacuum leaks I was fed up and sent the ECU to my tuner. He found potentially loose connections and is fixing those while I prepare for starting it up. Despite Martin's awesome response time, it's still taken close to 2 weeks to ship, fix, and now return the ECU to me. Hopefully coming in tonight, then I'll try starting the car again.
If it idles bad still, I will then pursue code 34, knock sensor. For tesitng and validation I will likely do the resistor trick to relieve the ECU of the code. From my understanding, code 34 moves the timing map into a protective secondary where timing is extremely conservative to save the motor. I have a feeling this is my problem as it's common for KA's knock sensor subharness to short out and cause these issues. This has been a great learning experience, reminding me to always check the small things and not to forget them.
Day 7:
After diagnosing for nearly a week straight, then narrowing it down to a control issue, it turned out to be the ECU. Took a while between shipping to FL and receiving my repaired ECU, but it started right up and idled perfectly. -20 vacuum, solid idle.
I feel like you don't hear of this issue very often but be weary of used ECUs and potentially broken connections. Martin (RS Enthalpy) sent me this image, indicating two areas of concern when checking your ECU's condition. My bad connection is on the right.
I also cheated and used the resistor trick to rid my car of the knock sensor code but this is a bad idea. I'm currently waiting on my new knock sensor subharness to come in so that I can reissue my knock sensor.
One Month Later:
Tune is slightly lean, sent to RS Enthalpy to revise for richer in-boost conditions.
Two Months Later:
Still battling exhaust leaks. If you hear a ticking noise when under load but not easily heard off throttle..it's likely an exhaust manifold leak. I had some issues with manifold gaskets and did a temporary, ghetto fix using copper RTV. It's ugly but will have to do for now. Basically I looked up the Emusa top mount manifold and some of the earlier designs had horrible ports. Not only were they not port matched to the head but they were drilled off center. Haven't had the time to address this just yet.
Four Months Later:
Blew out my paper T3 gasket, now using OEM Nissan 300ZX metal T3 gasket (Nissan Part #: 14415-4P200). Also using sprayable copper gasket on all of those flanges too so that I can stop them all up.
Old 07-24-2014, 06:17 AM   #4
bmaddock
bmaddock's Avatar
Still working through some formatting errors that seemed to have popped up. I'm open to advice and refining the thread so feel free to post up.
Old 07-24-2014, 07:16 AM   #5
HORShi
HORShi's Avatar
HORShi is an unknown quantity at this point
Man...I'm so glad you made this thread man. I was literally looking left and right at KA-T.org, Zilvia KA24DET section and many other 240sx forums to find something in this critical of detail at this specific power range. Please keep updating man. I'm currently on a "college" budget so trust me I know haha (Software Eng/IT gets expensive as hell initially) but I definitely want to continue my research and use others builds as a guide of what to do, and what not to do to build KA-T right the first time. Please keep updating man, I'm definitely subscribed to this thread.
http://underworld-jp.com
HORShi is offline   Reply With Quote
Old 07-24-2014, 07:48 AM   #6
pinkyrang
pinkyrang is an unknown quantity at this point
Very extensive write up here
pinkyrang is offline   Reply With Quote
Old 07-24-2014, 07:53 AM   #7
bmaddock
bmaddock's Avatar
Thanks guys, I plan on keeping it updated and perfecting the thread. Eventually I'd like to add in an update with reliability of such a high mileage KA-T and maybe suggest better options for parts. I'm already preparing to rip apart my intake manifold very soon and redo the vacuum system to simplify it. I'll also get videos soon but right now my computer sucks for editing so haven't spent any time putting them together.
Old 07-27-2014, 06:02 AM   #8
senger
senger is an unknown quantity at this point
not sure if im going full retard because im running off 2 hours of sleep. but whats TB and VTA
senger is offline   Reply With Quote
Old 07-27-2014, 11:22 AM   #9
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Dam +1 rep for you! How long did this take for you to write this?
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 07-28-2014, 06:25 AM   #10
bmaddock
bmaddock's Avatar
VTA = Vent to atmosphere. All my damn subaru friends use the term and ended up using it myself haha. TB is throttle body I'd assume, maybe I forgot the context I used it in and CTRL+F didn't pull up anything for me.
When I started collecting parts and doing research I was keeping a running log of hyperlinks, then decided this would help the community so just elaborated some.
Just got my RB25 clutch & flywheel installed, once it breaks in some I'll definitely get a video of it together and maybe a review after I get a chance to do an event with it.
Old 07-28-2014, 08:20 AM   #11
waxball88
waxball88 is an unknown quantity at this point
It is nice to have this consolidated in one place.
waxball88 is offline   Reply With Quote
Old 07-28-2014, 09:21 AM   #12
HORShi
HORShi's Avatar
@ bmaddock
Not to thread jack, but regarding my tranny/white bunny clutch issue in the other thread I made...it's my slave and clutch cylinder. Both died on me. Plus my damper "devil" box is still installed smdh. So will remove on test Wednesday.
But I want to ask you. Which T3/T4 50 Trim exhaust housing did you choose? .48 or .63?
I'm debating on getting the T3/T4 in .48 instead of .63 because I do not plan on pushing the car no more than 300HP, and if I do get close to that #, its on a track day. Plus looking at other KA-T drivers dyno charts, the .48 looks slightly better in spool time and response which would be good for a nice daily driven street car. I'm just worried that if I go .63, then I won't truly be able to maximize its potential or efficiency compared to the .48.
Old 07-28-2014, 09:33 AM   #13
waxball88
Originally Posted by HORShi View Post
@ bmaddock
I can't comment on the .48, but i ran the .63 for a long time. Plenty responsive for a street car
Old 07-28-2014, 10:24 AM   #14
bmaddock
bmaddock's Avatar
I have a 0.63 A/R turbine housing. Honestly I haven't driven enough turbo cars to comment on the responsiveness of the two sizes but this turbo doesn't appear to be unreasonably laggy. Testimonials and associated turbo setups added to this thread could help others decide on a turbo size but I'm sure the information is already out there.
But good to hear about the clutch setup! I'll keep that in mind if I start having similar issues but both my master and slave are only around a year old.
Old 07-28-2014, 10:29 AM   #15
Touge_Monster
Touge_Monster's Avatar
Touge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond repute
Awesome information in here. Thanks dude!
...180 Style...
Originally Posted by Panda-Eats-240 View Post
This thread gave me aids, thank you based god.
Touge_Monster is offline   Reply With Quote
Old 07-28-2014, 03:21 PM   #16
Sleepy_Steve
Sleepy_Steve is an unknown quantity at this point
Wow Ben! I knew you were keeping detailed track of this project of yours, but I had no clue you've been this detailed in sharing what you've learned to. Well done man!
'95 240 | @SleepySteve72
Sleepy_Steve is offline   Reply With Quote
Old 07-29-2014, 09:40 AM   #17
XMcEvilson
XMcEvilson's Avatar
XMcEvilson is an unknown quantity at this point
nice writeup bro
XMcEvilson is offline   Reply With Quote
Old 07-29-2014, 11:27 AM   #18
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
You sir, are the fucking man.
DJ_Sunrise is offline   Reply With Quote
Old 08-01-2014, 01:43 PM   #19
NotLowEnough
NotLowEnough is an unknown quantity at this point
^ +1! You sir ARE THE FUCKING MAN!!!
KAs are like Frank's RedHot, Nissan put that shit in everything
NotLowEnough is offline   Reply With Quote
Old 08-06-2014, 03:40 PM   #20
Wykydtron
Wykydtron's Avatar
Wykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really nice
Here's another good thread to reference... I was literally just reading it before I found this thread. Thanks OP.
Wykydtron is offline   Reply With Quote
Old 08-06-2014, 04:16 PM   #21
Def
Is that intercooler pipe coming right off the cold side cast and have a really tight radius? If so, you've got it backwards on your setup. The tight bend is right by the IC so that the piping goes straight up through the very inner edge of the battery tray.
DEFSPORT
Old 08-25-2014, 01:23 PM   #22
bmaddock
bmaddock's Avatar
Thanks for that, I'll have to flip it around when I get a chance but runs fine now. This weekend I'm doing some prep for September 6th event so I'll try and get a GoPro together and take some photos/videos before and during the event.
Old 09-10-2014, 02:09 PM   #23
HORShi
HORShi's Avatar
Any updates man? Seen you mention something about an event you was preparing.
Old 09-11-2014, 08:39 AM   #24
Sleepy_Steve
IIRC it was a drift day at Shenandoah Speedway in Virginia... forget who runs it.
Old 09-11-2014, 01:21 PM   #25
bmaddock
bmaddock's Avatar
Yeahhh I was supposed to run an event on the 6th but still haven't found a daily driver so I refrained. While in school it was easy for the car to be down and bicycle everywhere but now I need the car for full-time work so I'm taking less chances with the car right now.
But I just switched to BKR7E (from 6E's) spark plugs and cured some of my ignition issues in full boost. This car is so much fun, I just need to find a daily driver so I can get back to driving events. sleepy, I want to do an HPDE with you.
Old 09-12-2014, 06:05 AM   #26
bmaddock
bmaddock's Avatar
Fixed ignition issue. I had a small exhaust leak and finally took a look at it last night. Holy hell does plugging a small manifold leak improve things. It makes sense but used some Copper RTV where cylinder #4 started leaking at the manifold temporarily, copper manifold gasket in the mail. I can not explain how smooth the boost builds and holds now, I love it and no more stuttering in boost. It almost felt like preignition but we're good now.
Old 10-06-2014, 08:51 PM   #27
bmaddock
bmaddock's Avatar
Such a weak burnout but enjoy! Better videos and pictures eventually, working through some tune issues and what not but RS Enthalpy is a great mail tuner.
http://youtu.be/4d1hlLCgfEc
http://youtu.be/4d1hlLCgfEc&fs=1&hd=1" width="858" height="508">http://youtu.be/4d1hlLCgfEc&fs=1&hd=1" />http://youtu.be/4d1hlLCgfEc">http://www.youtube.com/watch?v=http://youtu.be/4d1hlLCgfEc
Old 10-07-2014, 07:12 AM   #28
ProjectPanda13
ProjectPanda13 is an unknown quantity at this point
Send a message via AIM to ProjectPanda13
Subscribed for updates. Great job on the write up. Mad props for putting the time out.
Latez.
-Dave
ProjectPanda13 is offline   Reply With Quote
Old 10-13-2014, 07:19 AM   #29
bmaddock
bmaddock's Avatar
Relocated power steering reservoir near clutch master cylinder, added PS cooler, and installed Altima electric fans. I'll be creating additional tutorials for those as well.
I also just received my tune back from RS Enthalpy. We've been working through some lean boost issues. This is my third revision of my tune but Martin has been more than willing to help me perfect it. As expected from mail-order tunes, they aren't perfect so just realize it may take refinement. Here's a short video of it doing a lame burnout. I'll post better pics/videos,etc after the next two weeks or so. I have a drift event coming up this Saturday and finally just bought a daily.
http://www.youtube.com/watch?v=4d1hlLCgfEc
Old 12-12-2014, 12:03 PM   #30
bmaddock
bmaddock's Avatar
RIP KA-T.org bump!... hopefully not gone for good. Feedback is appreciated for this thread, I know I need to add some more pictures.
Will likely be adding built KA and megasquirt tutorials in the coming months, I've fallen in love my KA-T and want more!
ka-t, ka24de, rs enthalpy, sr20, turbo ka
