Old 07-17-2014, 02:58 PM   #1
hastyk
hastyk is an unknown quantity at this point
Crazy no start problem!
I have a 1993 240sx with a ka24de with a 98 model ka24de head on it (says the previous owner).
I've been struggling with a no start problem here recently and it got really strange. I have the cam timing correct and the Idler sprocket looks correct according to the fsm. I tried moving the distributor around 1 tooth at a time, still nothing. Bought a new harness from wiring specialties, nothing.
The weirdest part is that only the fourth exhaust runner is getting hot... but all the plugs are getting spark.
I'm at a loss.
Thanks for any help.
Kevin
hastyk is offline   Reply With Quote
Old 07-17-2014, 03:13 PM   #2
PedroJG
PedroJG is an unknown quantity at this point
Have you checked your injectors? it seems like only one cylinder is firing
PedroJG is offline   Reply With Quote
Old 07-17-2014, 03:15 PM   #3
hastyk
I was just thinking bout that...can I just take the whole rail out and see if they're spraying? Weird thing is that I bought it with a spun bearing, drove it for a day then took it all apart. Injectors "should" be fine.
Old 07-17-2014, 03:17 PM   #4
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
Spray maf cleaner in the intake, if it fires up and smotth for a second then it can b a fuel problem
Primo's Silvia is offline   Reply With Quote
Old 07-17-2014, 03:21 PM   #5
hastyk
I sprayed starter fluid in the intake...sometimes the motor will hit like it wants to turn over but no full crank and run deal
Old 07-17-2014, 03:27 PM   #6
PedroJG
There are different test you can do to your injectors. Unplug your injectors from the harness and check the ohms of the injectors, it should be around 11-14 ohms I believe but don't quote me on it, check service manual for specs.
Old 07-17-2014, 03:28 PM   #7
hastyk
Ah. I'll try that. Any other suggestions?
Old 07-17-2014, 03:30 PM   #8
Primo's Silvia
Hmm well it could b a couple things try switching the 4th plug to the 1st see if that changes anything
Old 07-17-2014, 03:35 PM   #9
hastyk
The timing on the cam gears is almost completely correct...you can hear what I'm guessing is the valves click into place. And no, I just figured this one was good since I was driving it 2 months ago. Any way to see if there are any codes being thrown?
Old 07-17-2014, 03:36 PM   #10
PedroJG
well it can be a lot of things so try that first and let us know how it goes.
Old 07-17-2014, 03:37 PM   #11
PedroJG
Check ecu for codes. http://www.tamparacing.com/forums/ni...de-ka24de.html
cam, chain, distributor, runner, timing
