Old 04-01-2013, 12:57 AM   #1
Jdmtooth
Jdmtooth is an unknown quantity at this point
s13 93 MT 240sx ka won't start
So it was a normal day . Drove to the stores went it for 5 mins came out and my car won't start( will turn over) . Battery is new start works fine I'm getting fuel and I'm getting spark. I don't know what it can be , no check engine so idk.
Please help.
Jdmtooth is offline   Reply With Quote
Old 04-01-2013, 12:58 AM   #2
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
Ur not gettin air fuel or spark. Has to be one of those. How do u kno ur gettin fuel
yetijeff is offline   Reply With Quote
Old 04-01-2013, 01:04 AM   #3
Jdmtooth
I took of the fuel line and fuel is getting to the engine , I also Tryed using starter fuild
Old 04-01-2013, 01:07 AM   #4
yetijeff
yetijeff's Avatar
Are ur injectors firing? Ya ur getting fuel to the rail but whatabout past the injectors? Also how are u testing for spark?
*edit
Also a list of modifications etc could help too
Old 04-01-2013, 01:14 AM   #5
Jdmtooth
No mods, a stock ka24de
I check all spark plugs by taking them out grounding them and turning over the engine and they all spark a nice blue spark, as for the injectors I don't know but I use the starter fuild it should have turned on for a couple of secouds
Old 04-01-2013, 01:22 AM   #6
yetijeff
yetijeff's Avatar
So it's not even tryin to start? Also are u just spraying thru the tb? Try having someone hold the gas at wot and spray thru a vac port closer to the intake ports. Its possible the starting fluid isn't gettin to the intake ports. If it works its something to due with the injectors (ecu, wiring, etc)
Old 04-01-2013, 01:26 AM   #7
Jdmtooth
I did that I sprayed it in the vac line and in the tb and nothing ,
Old 04-01-2013, 07:59 PM   #8
yetijeff
yetijeff's Avatar
Dam. Has to be something to do with spark... Distributor came loose? Something with timing...
Old 04-01-2013, 08:00 PM   #9
yetijeff
yetijeff's Avatar
And maybe run a comp. test just to see.
Old 04-01-2013, 08:23 PM   #10
Jdmtooth
How do I check the timing , and comp. is good
Old 04-01-2013, 10:00 PM   #11
TwelveAM
TwelveAM's Avatar
Trader Rating: (26)
TwelveAM is an unknown quantity at this point
Feedback Score: 26 reviews
could be a loose wire somewhere.
wiggle around the injector connectors. That happen to my S13 also. 2 mins inside Autozone, and once I came out it wouldn't start. I started tightening all the wires distributor, spark plug wires, and pushing down the injector connectors made it start right up.
Just a thought.
TwelveAM is offline   Reply With Quote
Old 04-01-2013, 10:23 PM   #12
Jdmtooth
Ill give it a shot
240sx s13
