Old 12-23-2009, 06:51 PM   #1
democong
democong is an unknown quantity at this point
High output Alternator
Want to buy '95 240sx high output alternator for USDM KA24DE engine.
democong is offline   Reply With Quote
Old 12-23-2009, 06:57 PM   #2
JEDIs13
JEDIs13's Avatar
Trader Rating: (31)
JEDIs13 is an unknown quantity at this point
Feedback Score: 31 reviews
get a nissan quest alternator.. they are 125 amp IIRC. and fit on a KA with a little modification
Originally Posted by dOMEmE View Post
mine is the "cocaine diamond" why, becasue i like cocaine and diamonds
JEDIs13 is offline   Reply With Quote
Old 12-23-2009, 08:15 PM   #3
democong
Thanks, read about the mods req'd. for the quest alternator after doing some searching on the forum.
I need about 120 to 160+ amps at idle.
I'm looking to achieve this with a rebuilt or brand new oem 90 amp '95 KA24DE alternator.
Old 12-23-2009, 08:51 PM   #4
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
um...is there a way to squeeze out more amperage out of an alternator rated at 90 amps max?
upsdude is offline   Reply With Quote
Old 12-24-2009, 08:54 AM   #5
democong
Anything's possible.
Old 12-24-2009, 09:22 AM   #6
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
If that's the case, why not start with the quest alternator in the first place?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-24-2009, 10:20 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
Not going to happen with the stock alternator.
Do the Quest alternator, and you'll get 125A just off idle (1500rpm or so). That's A TON. If you want bigger, you'll have to retrofit a 'real' high output alternator for car audio applications, which have outputs of ~300A, and cost a ton ($400+).
Old 12-25-2009, 09:58 AM   #8
democong
I know 'some guy' on the web mods factory KA24DE Alternators to output over a 100 amps at idle (600-700 rpm) and 220 max at 1500 rpm. He's been doing this for all other vehicles probably since the early 2000's.
I'm looking to see if anyone on here knows about this, and has tested it out on a 240sx. Or if anyone on here, with a legit electrical business, can obtain a used 80 or 90 amp KA24DE alternator (95-96 240sx), modify rectifier, add as many diodes as necessary, replace bearings and all parts necessary to make the alternator a fully functional direct drop-in/plug-in.
My car has very good grounds at the moment so power side cable requirements (alt. to batt.) will be suggested by builder.
Thanks.
Old 12-26-2009, 07:25 PM   #9
democong
If a high output alternator were available for your vehicle as a direct, no-modification-necessary- drop-in, would you get one?
Old 12-29-2009, 04:13 PM   #10
democong
Ok people, found some Engineers out in Dallas, TX. that can rebuild the stock Hitachi's to output ~70 amps @ idle (600-700 rpms), and ~165 amps at about 2500 engine rpm.
send pm if you're interested.
Thanks for the help guys.
Old 12-29-2009, 04:31 PM   #11
Jonathan Rivera
Jonathan Rivera's Avatar
Jonathan Rivera is an unknown quantity at this point
hey what about for and sr20det. can u use the quests alt?
Jonathan Rivera is offline   Reply With Quote
Old 12-29-2009, 06:20 PM   #12
democong
Don't know, but I'm sure anything's possible.
