#152 |
I thought boring out the KA to 2.6 would drop the RPM revs to like 5500 instead of its 8000. You would get some nice torque but wouldn't this be useless for drift/track/ I only see this being used for 1/4 times and thats it. In which case I wouldn't bother.
#153 |
![]() Join Date: Dec 2008
i got a twim cam harness 240sx and my car is a single cam does anybody know why it doesnt plug into the dashborad consle
its 93 harness gold top s13 motor and my car use to be single cam doing a motor swap and dashborad consle doesnt plug in help |
#154 |
not true. The crank is FCW, and allows RPM's over 8000.
* > Drifting JWT powered Altima |
#156 |
![]() Join Date: Jan 2009
not sure
I'm not 100% sure but I dont think the 264's will work with the sohc cam pistons, something about valve clearances, you have to get your pistons milled.......look it up its on zilvia......
#157 |
Yeah, You have to get your Pistons milled for the valve clearances, Or you'll bend valves when you attempt to start up.
Here's my ka build info 95 Ka24DE: BC 264 cams BC Stage 2 Dual valve springs Clevite Crank bearings Clevite Rod Bearings Micro Polished crankshaft Arp head studs Stock HG (new) Stock Rods Stock Pistons(Cleaned up of all carbon) Gasket matched intake and exhaust ports Freshly cut Valve Seats New Valve guides Freshly cut valves(Also sand blasted of all carbon deposts on valve heads) I'm curious as to what WHP numbers I'll be seeing. |
#159 | |
Did you ever actually do this and if so what were the results?
#161 |
![]() Join Date: Apr 2008
dont really care for the idle plannin on gettin bc spring kit n runnin stock 240 248 cams for now and see what i get ...if not im runnin the 11.0.1 with 264 cams
#167 |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
oh good call, i do believe you are correct.
what was the shipping time like on the xsessive manifold btw?
2004 Nissan 350z 2002 Nissan Silvia |
#170 | |
![]() Join Date: Nov 2006
Probably just a 10HP increase if anything. Just a 4 banger. Want numbers, drop a lot of cash or forced induction in there lol.
1986 Porsche 944 Turbo (951) 1995 Nissan 240sx (S14) Miss ya. |
#171 |
10whp???
i remember a while back before i owned a 40... i was reading up some old guy's build and he made 160whp on a N/A KA24DE with just I/H/E then 185whp on a tuned ECU. |
#174 |
you know you can take ka24e pistons to a machine shop and have valve reliefs milled in them for about $25 a piece and you can run beefier cams, If your going for a NA KA setup I highly recommend using more aggressive cams and porting polishing the head..... |
#175 |
hmmm wish i knew it was so cheap before i even put the motor back together..hopefully my ecu should be back by the end of the week no later than begining of next week
#177 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
DC sports, Greddy made one for the s14, which bolts to a s13 and allows you to run a sr20 downpipe. Its kinda hard to find though.
Slip Gypsies Blog Quote:
#178 |
Xtune, I have it and its good. 110 shipped I believe. Survived winter and a shitload of exhaust abuse such as jacking the motor up, tranny swap etc all without unbolting the header from the exhaust.
#180 |
after looking around for hours and hours, i figured i would ask here.
does anyone know where to get the xtune header for a sohc . i pmed one person, but didn't get a reply yet. thanks in advance........ |
