Old 11-12-2020, 02:17 AM   #1
LtSlayer
LtSlayer is an unknown quantity at this point
SR SR20 vacuum leak?
Ok let me start with saying I'm not a complete novice when it comes to mechanic work in general but was a little stumped by this. My car has an s13 SR20DET swapped and it goes through it's ups and downs. I noticed one day the car was significantly down power above ~3k and was leaning out as opposed to running very from earlier that same day and proceeded to replace every coupler and check my previous work with the rocker arms. Everything checked out but when I went to turn on the car I let the fuel pump prime. This is when I noticed the vacuum leak:
The car makes a hissing sound coming from around injector 1/the fuel regulator as the motor primes. I'm no referencing the hum from the pump but an audible hiss from around there. I didn't see or smell gas and soapy water didn't spot it either.
I've read something relatively similar and it was the O-ring on the fuel injector but I swapped this injector 2-3 months ago and never replaced the O ring. Could this really be the problem?
Any other ideas?
LtSlayer is offline   Reply With Quote
Old 11-12-2020, 04:14 AM   #2
S14rebuild
Why not make a boost leak tester, and pressurize the system in silence (engine not running) to make it easier to pinpoint your vacuum leak
Old 11-14-2020, 02:03 AM   #3
LtSlayer
The leak is tied to the fuel system, what exactly would I pressurize? I helped fixed 2 vacuum leaks on 2 of my buddies cars last weekend but this is different since its tied to the motor being primed. What part of the motor would I pressurize?
Old 11-12-2020, 09:00 AM   #4
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
^ need to do that for the soapy water thing to work
zombiewolf513 is offline   Reply With Quote
Old 11-14-2020, 02:05 AM   #5
LtSlayer
I was seeing is pressure leaking out from the fuel system would make the bubbles but I'll try that soon. There's a T joint that runs to my boost gauge, I'll pressurize that. Since it's when the fuel pump primes its pretty quiet anyways.
Old 11-14-2020, 05:43 AM   #6
S14rebuild
Cant be a vcuum leak is its hissing when the car is not running and only when then fuel pump primes
Old 11-14-2020, 09:25 PM   #7
LtSlayer
I'm saying it's easy to hear before the motor hides it. I took it apart to check the valvetrain and replace all the couplers. After trying to use soapy water to find the leak I'm hesitant to start her up again, if you saw my wiring harness you would be too. I'll fire her up on Wednesday fs. My question is, what could cause a hiss from around the intake manifold when the fuel pump primes?
Old 11-14-2020, 09:26 PM   #8
LtSlayer
Old 11-14-2020, 11:35 PM   #9
zombiewolf513
replace the o rings on the injector you replaced
Old 11-15-2020, 12:01 AM   #10
LtSlayer
I'm getting lazy to go to the parts store as it's miles away. I did put Vaseline on it tho to help seal. I may need the car to go back home in a week or so as well. It ran but would run lean under load. wont it run rich once the turbo spools? i didn't want to force it so I didn't get to see. I can do a balancing act and keep my eye on the gauge. It's 5 miles of street 95 of highway
Old 11-19-2020, 10:00 PM   #11
LtSlayer
I bought a complete set to replace every intake gasket, I'm going to put new rings and the thick rings that keep the Injector centered. Is Vaseline or silicon grease better to set these in? I used Vaseline with install of the same rings months ago and see no pitting. I'm going to replace all the vacuum lines since I'm pulling the entire intake manifold anyways and I'm going to paint everything to make the bay look a bit cleaner.
Any suggestions while I'm in there?
Old 11-20-2020, 01:08 AM   #12
zombiewolf513
Clean the iacv
Old 11-20-2020, 01:36 AM   #13
LtSlayer
Clean the iacv
That could very well be dirty since a rocker arm was broken earlier and the exhaust cycled into the intake. Would that make the vacuum leak hiss we all love so much?
Old 11-20-2020, 04:04 AM   #14
LtSlayer
idle hasn't been noticeably affected, only AFR underload or over 3K with an audible hiss/sandy scratchy sound. No fuel leak and hardly smells like fuel at all.
Old 04-30-2021, 12:17 PM   #15
nmerriw
nmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura about
Fpr
I know this is an old thread, but for anyone having similar issues this sounds like a failing Fuel Pressure Regulator to me, the hiss is probably the fuel flow through the regulator into the return line, as there is no vacuum generated without the engine running
nmerriw is offline   Reply With Quote
Old 11-20-2020, 02:32 AM   #16
zombiewolf513
engines make clicking and hissing noises. i cant tell you where its coming from bc im not there. is the motor having any issues running and driving other than making a hissing noise from somewhere?
lean, sr20, vacuum leak
