12-14-2013, 07:51 AM | #1 |
S13 1992 240sx
TESTING WATERS
I'm not for sure im ready to sell this car yet , but I wanna know what I could get for my car. You can text 7o6-604-4183 for any other questions. Located in Columbus, GA. 1992 240sx S13 Taffetta White paint No rust at all 5% tint Pig nose front lip Motor: Red top Sr20det Brian Crower 264/264 Cams CP Forge Pistons 86.5mm 9:1 Eagle Connecting Rods Brian Crower Ti Springs HKS 555cc Fuel Injectors Samco Hoses Koyo Radiator (Greddy Cap) Electric Fan with custom shroud HDI Bar Type Intercooler HKS SSQV BOV 1st Gen Ichiba Exhaust Manifold wrapped GT2871.64 a/r Turbo Circuit Sports Stainless Steel turbo lines Tomei Rocker Arms Cometic Steel Headgasket ARP Headstuds Splitfire Performance Ignition system Circuit Sports Mini oil catch can Nismo Air Intake (Blitz filter) Z32 Maf sensor Z32 fuel pump 260lph Z32 fuel Filter Megan Racing Fuel Pressure Regulator NGK Spark Plugs Nismo oil cap New Alternator Electronics: Apexi Neo Safc Glow Shift Wideband AFR Boost & Oil Pressure Gauges HKS Evc-S Electronic Boost Controller Split Fire Ignition Coil Upgrade Keyless Entry with Alarm Alpine Headunit Pioneer 6x1/2 and 6x9 Suspension and Misc: Megan 3" Cat Back Dual Tip Exhaust Circuit Sports Moon Face Downpipe Megan Racing Test Pipe GSP Type R Coilovers Energy Suspension Poly Bushings Nismo Poly Motor & Transmission Mounts Circuit Sports Drift Button Powered By Max Aluminum Subframe Bushings Digital Heads Up Cluster (Working) J30 LSD DNA Strut Bars 3-Piece Ichiba 5-lug Conversion Steel Braided Clutch Line Spec Stage 3 6 Puck Sprung Clutch Fidanza Flywheel 11lb Fully Stitch Welded Chassis Celica GTS Seats S14 Seatbelts No HVAC Interior Gutted Behind Seats, but still Clean!! XXR 522 17x9 Front 225/45/17 Rear 255/40/17 |
12-14-2013, 11:10 AM | #2 | |
12-17-2013, 08:50 AM | #4 |
Some nice parts in the build I just don't understand whi you would remove hvac even if it was a track only car what do you do if the humidity is up anf your windsheild fogs
Tags |
240sx, hatchback, nissan, s13, sr20det |
