Old 07-01-2009, 02:27 PM   #1
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
hate it,love it whatever build
A little background. i got the car back in 2001ish, from the shop i use to work at. condition was decent, just a shell, no main harness, front end, engine or trans. sorry no pics digi cameras were too expensive n shitty at the time.
i had some shitty taste at the time lol. and i have some beat up ass fenders lol
then i got a decent front end. but still had a shitty bumper
then i finally got a stock silvia bumper on for a while
then the 5-lug and stock s-14 wheels
and some coil-overs Tein Flex
motor was a stock red top with usual bolt ons
drove it around for a while, and the gas tank developed a leak, so as a temporary fix i used some jbweld. It worked for a while until i started to get more leaks, so i decided to bite the bullett and buy a new tank.
while the car was out of commission i bought some rims. Stern Beastface
17x8 +32 from and 17x9 +38. but i didnt end up using them and got a good deal on some Motegi Touge's 18x9 +12 and 18 x 10 +30
so then i was like eh screw it and bought a kit n threw on some fender flares
i was also wanted to clean up the engine bay and add some shit
then more changes bc i was bored. lol
decided to spend more money and build a lot of SS lines
little bit of wire tuck
figured i would paint the stock IM
before
after
then i hated the routing of the heater hoses so i did this
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 07-01-2009, 02:32 PM   #2
mattro
mattro's Avatar
mattro is an unknown quantity at this point
what is that crazyness comin off the rad? is that the overflow that looks NASTY!
mattro is offline   Reply With Quote
Old 07-01-2009, 02:50 PM   #3
japslapsilvia
air expansion tank
then it was time to get the oil cooler set up. got a Greddy Oil filter base with Thermostat, and an oil cooler from a Volvo
picked up and S-15 turbo to replace the worn out t25
added a -10 drain fitting
and to fix the fact that i cut the heater hose routing i needed to make a water return
for the Fuel system i did AN lines bc i hate rubber fuel hose. and non of that clamp a SS line to stock hard line. lol
now for whatever reason i decided that i would take the motor out and prep the car for paint and shit
door jams primered
also since im usually bored and my social life kinda sucks at the moment i cleaned up the sub frame and added some spacers and cleaned and painted the underside of the rear
Old 07-01-2009, 03:12 PM   #4
XenoVibe
XenoVibe is an unknown quantity at this point
wow R32 Skyline bumper? engine torque dampener on a 4cyl?
anyways goodjob, looks amazing.. coming along 'swimmingly'
XenoVibe is offline   Reply With Quote
Old 07-01-2009, 03:00 PM   #5
japslapsilvia
Motor is out so im like fuck it. might as well re-fresh it a bit and add some more parts
took the motor apart and found this shit
this is the #3 cam cap and mating surface
here is the cam
instead of trying to repair this i decided to get another head
got it like this
sent it to a machine shop and had it surfaced and hot tanked, and it came out like this
the block wasnt in bad condition eithor
mostly a lot of build up on the pistons
so i sent it to a buddy of mine and he checked it out, and re-ringed it, and did all new bearings, thrust washers, and honed the bores
got it back like this
bought a new tool
so i could put on these
bc springs, retainers, and cams.
then i got all new rockers b/c the stock ones were pretty scored up
Old 07-01-2009, 03:09 PM   #6
bboyoracle
bboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to behold
Send a message via AIM to bboyoracle
MORE! Love the build!
bboyoracle is offline   Reply With Quote
Old 07-01-2009, 03:13 PM   #7
japslapsilvia
so im supper inspired about some of the wiring job that are here on Zilvia,
so i cleaned up my engine harness
added that braided sleeving...looks all purdy lol
for the oiling system i used the Tomei block adapter
now it mates up nicely with the greddy filter adapter.
i also didnt like the banjo bolt for the turbo oil feed line so i got this from Pegasus
now that every thing was apart i wanted to check the tranny to make sure it was in good condition, it was dirty as shit
took the casing apart to inspect all the gears n synchros
everything lookd pretty good and i never had a problem with it. since it was all apart i decided to paint the housing, but i had to clean it up
dont ask y b/c i dont know but i went with john deere green
now it was time to start cleaning up and get my motor back togather
got an Apexi 1.1 HG
and ARP studs
figured i would color coordinate some shit
then for whatever reason again, i got a differnt turbo, Gt2871 with .82 AR T3 flange and a top mount manifold from JGS tools
Old 07-01-2009, 03:44 PM   #8
japslapsilvia
started to work on the bay, kinda shitty pic of it partially painted
and i also got the kit primed
the complet mod list so far is this
Motor
re-ringed, and new bearings, thrust washers.
new water pump and oil pump/front cover
new timining chain kit, tensioner guides etc.
BC 264 cams, Ti Retainers,Springs
Apexi 1.1 Hg, and Power FC
new rocker arms
CS rocker arm stoppers
all new gasket set.
Greddy oil pan, filter relocation base, Air expansion tank, oil catch can, turbo timer, Profec E-01 Boost controller, and MSS
Koyo rad with sard 1.5 cap
Trick flow fuel filter
all Braided SS lines for oil and fuel.
HKS SSQV
egay FMIC
volvo oil cooler
custom fan shroud with 12" puller fan
PE belts.
GT2871 turbo
JGS manifold
modified fuel rail for AN lines
Sard FPR
Q45 fuel pump.
Greddy IM (just got it in the mail)
AEM wide-band
Espiler JGT-500 cat-back
test pipe
megan dp
custom tubo outlet pipe with V-band clamps.
Exterior
origin aggressive kit
origin roof spoiler
flares
silvia s13 front
Suspension/Brakes
Tein Flex coilovers
5-lug
S14 FLCA
Sub-frame spacers
z32 brakes front and rear with q45 e-brake and 2+2 cables.
180sx brake booster
z32 master
Greddy FSB
Cusco RSB w/V-bar
Tein EDFC (just got it, in the mail)
Wheels
Motegi Touge 18x9 +12 front
18x10 +30 rear with spacer = -2 offset
those will be changed once i find some baller rims
interior.
eastbear copy seats
working DCC
180sx cluster with HUD wired in. KPH on cluster and MPH on HUD
Kazama Shift Knob.
i still need to get injectors, cam gears, some seals for the tranny. re-do the dash in suade, and a waste gate.
and here is how she looks at the end of the day lol
i just injured my back so i really cant work on it too much...hopefully i will be able to get more done next week.
Comments.
Old 07-01-2009, 03:58 PM   #9
allntrlundrgrnd
allntrlundrgrnd's Avatar
oh my, green looks rad haha
nice progress man, hope a speedy recovery for ya!
Old 07-01-2009, 04:20 PM   #10
Sergio180sx
Sergio180sx's Avatar
Trader Rating: (24)
Sergio180sx is on the path to ruinSergio180sx is on the path to ruin
Feedback Score: 24 reviews
I love this build i wanna go all ss lines to but dont know where to start good luck with recovery bro
Sergio180sx is offline   Reply With Quote
Old 07-01-2009, 04:55 PM   #11
japslapsilvia
Thanks!! yea i herniated a disk in my lower back, pinched my sciatic nerve and fractured a lumbar. had surgery last week and have to wear a back brace for like 2 weeks....kinda sucks, but at least i can go on short term disability lol!!
anyways. here is the tranny all put togather
then i figured WTF and painted the engine cross member, tranny mount, and front tension bracket gay purple.
here are some shots of the engine bay all painted and cleared, the color is cast coat iron
i just got this thing in the mail......
one more thing to mount lol
here are some shots of the motor all mocked up and ready to go in.
Old 07-01-2009, 05:08 PM   #12
Driftastic
Driftastic's Avatar
Driftastic is an unknown quantity at this point
looks like the only thing you didnt paint was the valve cover which just so happens to be in need of a repaint from the looks of that rub spot....lol
seriously sweet build.
Driftastic is offline   Reply With Quote
Old 07-01-2009, 04:54 PM   #13
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
nice job dude, cant wait to see the motor in the car.
PEGASUS
nismo racer is offline   Reply With Quote
Old 07-01-2009, 05:01 PM   #14
intel
intel is making his/her stupidity well-knownintel is making his/her stupidity well-knownintel is making his/her stupidity well-known
sweet deal! i totally loled in the manner how you posted the pics and short comments as if you were actually narrating
intel is offline   Reply With Quote
Old 07-01-2009, 05:07 PM   #15
prang11
prang11's Avatar
prang11 will become famous soon enoughprang11 will become famous soon enoughprang11 will become famous soon enoughprang11 will become famous soon enough
Badass!
msglghtBOOO
prang11 is offline   Reply With Quote
Old 07-01-2009, 05:44 PM   #16
gmember240
gmember240's Avatar
gmember240 is an unknown quantity at this point
this is an amazing build. keep up the great work!
gmember240 is offline   Reply With Quote
Old 07-01-2009, 05:49 PM   #17
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
badass very clean, loving the harness.
Killa_D is offline   Reply With Quote
Old 07-01-2009, 05:54 PM   #18
nothix
nothix's Avatar
nothix is an unknown quantity at this point
I vote for green valve cover too!
nothix is offline   Reply With Quote
Old 07-01-2009, 05:59 PM   #19
Om1kron
Om1kron's Avatar
ditch the greddy manifold and put the stock one back on.
Wayne Edwards
https://om1kron.blogspot.com
Old 07-01-2009, 06:08 PM   #20
wannabdr1ftr
wannabdr1ftr's Avatar
wannabdr1ftr is an unknown quantity at this point
wow thats one hell of a build so far im loving it
wannabdr1ftr is offline   Reply With Quote
Old 07-01-2009, 06:21 PM   #21
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
Looks Great,cannot wait to see the final product!
Shadowhunter is offline   Reply With Quote
Old 07-01-2009, 06:33 PM   #22
rednissan180
rednissan180 is making a name for him/her selfrednissan180 is making a name for him/her self
nice!!!
i love the green and purple!!!
rednissan180 is offline   Reply With Quote
Old 07-01-2009, 06:44 PM   #23
wafflez66
240 Dismantler
wafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond repute
agreed ..............
Originally Posted by Knuckshaft View Post
You're the one playing in the sand box with no panties on.
wafflez66 is offline   Reply With Quote
Old 07-01-2009, 06:40 PM   #24
David B S12
David B S12 is an unknown quantity at this point
love this so far man, the green tranny, is, AWESOME
David B S12 is offline   Reply With Quote
Old 07-01-2009, 07:03 PM   #25
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Nice job so far sir!
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 07-01-2009, 07:12 PM   #26
shanelach
shanelach is an unknown quantity at this point
I like. Thats a nice barney paint scheme you got going on haha.
shanelach is offline   Reply With Quote
Old 07-01-2009, 07:42 PM   #27
Leo-kun
Leo-kun's Avatar
Leo-kun is an unknown quantity at this point
Looking good so far. Nice job!
Leo-kun is offline   Reply With Quote
Old 07-01-2009, 07:08 PM   #28
drift_limo
drift_limo's Avatar
drift_limo is a well-known jackass
Send a message via AIM to drift_limo
really nice build ...
hope you get better so i can see this thing finishd!
dirtypenguin.wordpress.com
drift_limo is offline   Reply With Quote
Old 07-01-2009, 07:45 PM   #29
HyperTek
since you seem to have been around since 01, seems like you know and appreciate all the baller parts =D
Keep it Classy
Old 07-01-2009, 08:13 PM   #30
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
good luck recovering from back surgery. i had a discectomy in december it was terrible for about three weeks, but stay active.
bigOdom1 is offline   Reply With Quote
