01-25-2023, 08:49 PM | #1 |
Power Steering Banjo Bolt for CA18DE
I apologize if this has been asked before and if this in the wrong section. I searched but didn't find anything.
Is the banjo bolt for the pump pressure hose M18? Is it the same as the SR20? *1990 S13 Coupe w/ CA18DE Last edited by MrBlackFL; 01-25-2023 at 08:53 PM.. Reason: added car info |
01-26-2023, 07:24 AM | #2 |
Yes. It's part number 01619-00011 (checked on the JDM parts fiche for the CA18 Silvia) which cross references to like 99% of Nissans from the '80s, '90s, and early 2000s, and even up to 2019 in the Titan and Frontier:
https://www.nissanpartsdeal.com/part...619-00011.html |
01-27-2023, 08:28 AM | #3 | |
Thank you!
01-26-2023, 08:01 PM | #5 |
I just bought the one from chasebays if you want any detail I can measure it all for you.
https://www.chasebays.com/products/c...30259236733006 |
02-06-2023, 09:54 PM | #6 |
GKTech makes ones that fit and actually seal with the rubber o ring. Years ago (like 10 lol) there was a writeup on here but the actual fittings that you put into the rack were not the right length so despite it having o rings, there wasn't anything available that was long enough to actually seal. I used a copper crush washer and tighten it down a ton and never had leaks, but a few years ago actually swapped over to the GKTech ones, and no issues either, and price is very reasonable.
02-07-2023, 07:15 AM | #7 |
Yes, most aftermarket rack side fittings are wrong but the GKTech ones work.
I feel like braided PS lines in a KA/SR/CA powered street car are one of those things people often do when the stock line leaks thinking a 30 year old line leaking is a design flaw rather than just a wear item, then they ironically buy a part with a known design flaw as a replacement. In my S13 I just run an OEM-spec-aftermarket S14 high pressure line. It's one piece from pump to rack, perfect fit, zero leaks in my PS system along with a new O-ring on the return loop hardline fitting and new rubber hoses to the reservoir. Ideally I'd run a new OEM high pressure line but I don't think they exist. |
02-07-2023, 10:28 AM | #8 |
These are the fittings you need for the rack fittings.. He was on Zilvia awhile ago. These are EXTENDED so that they are a bit longer and have the rubber washer.... Great product and support somene from zilvia.
https://tightfitfab.com/s-chassis/psf
Turn and Burn! |
Tags |
banjo bolt, ca18de |
