11-24-2013, 06:32 PM | #1 |
Trader Rating: (32)
Feedback Score: 32 reviews
FS/FT 1991 S13 Fastback 303 whp SR
Up for sale is my 1990 S13 Fastback with 303 WHP SR20. Over $20,000 invested looking to get $12,000 but am open to offers or trades. Will trade for 240z plus cash on your end depending upon condition. You can see my entire build here. All photos of my build at my Photobucket. Car was finished in May 2011 and all the components only have little over 4,000 miles on them. 119,710 on speedo when car was complete and currently reads 123,933. Needless to say it didn’t become my daily like originally planned, focus switched to my G35 Sedan. If selling car as a whole doesn’t work out I have prices set on individual parts and packages. Contact: [email protected] for fastest response.
The Good… Chassis POR 15 all rusted areas Filled all seams effected by rust POR Fuel Tank Restoration Kit Trans Tunnel Cleaned and Undercoated Engine Bay, Fender Wells Painted w/ SEM RustShield Black Floor Pans and Trunk Undercoated Hella H5 Headlights 180sx Center Section Engine... Greddy High Capacity Oil Pan Grex 1.2 mm Head Gasket ARP Head Studs Greddy Valve Springs BC Titanium Retainers Greddy Rocker Arm Stoppers HKS Cams 264/264 Circuit Sports Underdrive Pulleys Nismo Oil Filler Cap Megan Racing Motor Mounts Wiring Specialties Harness Z32 Igniter Chip Greddy Oil Catch Can OEM Engine Parts... Stock Bottom End Gasket Set Waterpump Coolant Temp Sensor Oil Temp Sending Unit PCV Valve Heater and Intake Manifold Hoses Fuel System... Circuit Sports Fuel Rail Nismo/Tomei 555cc Injectors Sard FPR AN-Type and Adapter Fitting Walbro Fuel Pump – 95 lb/min Deastch Works Fuel Pump HardWire Kit Z32 Fuel Filter Turbo Setup... (Forced Performance) FP Big 28 Turbo HKS Wastegate Actuator Circuit Sports Turbo Lines SS Auto Chrome Intercooler Hotpipe w/HKS SSQV Flange CAREX Intercooler Piping HKS SSQV BOV Samco Recirculation Hose Intake... Z32 MAF Apexi Super Suction Kit Exhaust... PBM Max 304SS Flex Cobra Downpipe Megan Racing 80mm Test Pipe Apexi N1 Dual Cat Back Exhaust Nismo Exhaust Hangers Cooling... Koyo Aluminum Radiator Koyo Radiator Cap ISIS E-Fans with Aluminum Shroud Circuit Sports Overflow Tank Blitz Silicone Upper Radiator Hose w/Sensor Bung Circuit Sport Silicone Radiator Hoses Drivetrain... Transmission Nismo Clutch Fork Pivot Megan Racing Trans Mount Slave Cylinder ACT XACT Prolite Flywheel ACT 6-Puck Sprung Hub Clutch B&M Short Throw Shifter AGP Braided Clutch Line Ichiba 5-Lug Hubs Front NA Z32 Rear 5-Lug Hubs Z32 E-Brake Assembly Subframe Powdercoated SPL Solid Subframe Bushings Rear End NA Z32 VLSD 93' J30 Axles Solid Diff Bushings JGY Aluminum Driveshaft Suspension... Stance LX+ Coilovers PBM Tension Rods Steering Circuit Sports Tie Rods Circuit Sports Rear Toe Rods Circuit Sports RUCA’s PBM Rear Traction Rods Energy Hyperflex Bushings Circuit Sports Aluminum Steering Bushing New OEM Tie Rod Dust Boots Moog Ball Joints Front (K9509) Rear (K9633) Suspension Techniques Swaybars Circuit Sports Strut Bars - Front and Rear Brakes... Centric Z32 Brake Master Cylinder Rebuilt Z32 Calipers (Front and Rear) Z31 Dust Shields Z32 E-Brake Assembly AGP Brake Lines Brembo Factory Replacement Rotors Hawk HPS Pads Wheels... Z32 Rims w/matching spare 225/50/16 BFG g-Force Sport 2 PBM Hubcentric Spacers Front 15mm Rear 15mm +3mm PBM Splined Lugnuts Electronics... Apexi Power FC and New Hand Commander Power FC Datalogit w/Software Greddy Profec B II Boost Controller – Black Greddy Turbo Timer Circuit Sport Turbo Timer Harness Innovate Motorsports LC-1 Wideband XD-16 Gauge 60mm Defi Imperial BF Series Gauges Boost Gauge Oil Pressure Gauge Fuel Pressure Gauge Water Temp Gauge 60mm Defi Link Control Unit II V2 DIF Dual Electric Fan Controller Ver. D Interior... Grey Suede Front Door Panel Inserts Grey Suede Headliner S14 Seatbelt conversion S14 Front Seats Seats Recovered (light grey) NRG Short Hub NRG Quick Release 2.0 NRG Hub Lock Sound... Alpine IDA-X305S Digital Media Receiver mjmautoinnovations 6½" Speaker Adapters (Front and Rear) Infinity Kappa Perfect 6.1 6½" 2-Way Component Speakers (Front and Rear) Infinity Kappa 1200W 4-channel Amplifier Kicker 4 channel Amp Install Kit Security... Clifford 50.7x Glass Break Sensor Tilt Sensor Dual Shock Sensor Proximity Sensor The Bad… Nardi Kallista Steering Wheel not for sale Car has 10 foot paint job by previous owner Paint chip on rear bumper Dent in passenger fender The Ugly… Some components are brown Pics… Dyno Vids… 70% Throttle...
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune Last edited by xiaphin; 11-24-2013 at 07:02 PM.. Reason: its a 90' duh... |
01-11-2014, 03:19 PM | #3 |
Trader Rating: (32)
Any interest in 2014???
Seeing if there is any interest in my car since it is a new year. Price is OBO. If not a part out might be in order...
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune |
02-16-2014, 07:34 PM | #5 |
Trader Rating: (32)
Let the part-out begin...
Hate to do this because the car is solid as is but in the car game you get more money on parts versus the whole. Check out my new part out thread
Buy my stuff!!!
Tags |
apexi, greddy, pbm, s13, sr20 |
