04-16-2012, 03:46 PM | #1 |
s14 subframe install into s13
Been doing alot searching on this. And found answers to my questions besides one. My question is, I have the complete rear-end off a s14.from the differential to all arms. Now that being said is it just a bolt-on affair? Thanks in advance!
04-16-2012, 03:52 PM | #2 |
you will need to get Offset Conversion bushings, unless you want to ghetto rig and stretch the stock rubber bushings out.
www.aceupmotorsports.com |
04-16-2012, 03:54 PM | #5 |
Trader Rating: (18)
Feedback Score: 18 reviews
You can get the bushing from spl and stance. Also try searching. I already posted something about this. But yes everything will work. You need the bushings and depending on what bushing you get you may have to modify the rear crossmember at the front hump.
04-16-2012, 04:00 PM | #7 |
Trader Rating: (42)
Feedback Score: 42 reviews
You need offset bushings, but you can also do the strech the rubber bushings if your a cheap ass and like ghetto rigged cars. You also need the obvious s14 diff cover. And if you don't have aftermarket arms you need the stock s14 toe arms
04-16-2012, 05:08 PM | #10 |
^^^^ S13 rears, also like said above you will need to get out the BFH for the front of the sub frame ,it touches on the underside of chassis!!
MR JACKSON. |
04-16-2012, 05:33 PM | #11 |
ive done this swap twice.
you will need an s13 ruca the s14 ruca will block your coilovers So to end it all s14/15 subframe into an s13 parts needed s14 subframe s14 rlca s13 ruca s14 toe arms s13/14 tension offset bushings from spl. s14 diff cover. Modify exhaust hanger on subframe Last edited by tacotacotaco; 04-17-2012 at 10:07 PM.. Reason: the old asshole pointed it out. |
04-17-2012, 08:45 AM | #12 |
Location: bangin on my chest Account: BANNED #fucksupreme
you guys are amateurs
i like with all the great sage advice people have given, not one has even mentioned the fact that you need to relocate the exhaust hanger screw provisions "nah man, who needs that shit, you still have 2 more hangers in the rear" my best suggestion, get off your ass, drop both subframes, put them side by side and compare. expect a lill bit of downtime, no big deal. its all possible, but as everyone else has already commented - you'll need to start with offset bushings since the newer subframe is wider. you guys also forgot that he needs to use the s14 spindles, ball joints (taper) is different fucking amateurs... and all of this is just "off the top of my head" see, i told you guys im smart. not just good looking, but smart. |
04-17-2012, 07:22 PM | #13 |
False. All s13/s14/z32 rear lower control arm ball joints have the same taper; all uprights are interchangeable in that respect.
S12 || KN13 || S13 || B16 |
04-17-2012, 06:30 PM | #14 |
^^^^ OMG your the best..... we shall bow to you god of 240sx,lollollol. well if he is starting with a complete subframe,no need to mess with spindles,but now if he is peicing it all together then ,yea different story. And I would thinkthe whole exaust hanger crap would be obvious once installed....
MR JACKSON. |
04-18-2012, 11:37 AM | #16 |
04-18-2012, 01:39 PM | #17 | |
S13/S14/S15 Front Diameter = 41mm S14/S15 Rear Diameter = 41mm S13 Rear Diameter = 38mm i had my s13 spindles powdercoated only to find out that i was unable to use them with my s15 subframe and OE lower control arms, so off to the dumpster they went. i now run s14 spindles. even when you go s14 5-lug on the front of an s13, the front ball joints need to be changed as well. incorrect. some s14 subframes have minor reinforcements, others do not. the reinforcements are negligible though, i would prefer adding my own gussets as the OE ones are minuscule. damn people, get yer shit straight. you all know i'm the fuckin KING around here. :-) |
04-18-2012, 04:34 PM | #18 | |
I said the ball joint tapers are the same, not the press fit diameter of the housing. All the rears have the same minor/major shank diameter and length. Yes the ball joints are control arm specific, but upright universal. You are correct on the front tapers, however. It's Kouki s14 subframes that have the additional reinforcements, same as s15.
09-17-2017, 11:24 AM | #19 | |
there is no difference between kouki or zenki, s14 or s15, spec R or spec anything. The bracing varies wildly on all of these subframes, no matter the year S14 or S15. Its a random shitbag lottery. Grab yourself a welder and add the braces, done and done. I did the same with all the control arms, boxed them in and braced them. |
09-30-2017, 09:02 AM | #20 | |
04-18-2012, 01:57 PM | #23 |
04-18-2012, 03:43 PM | #24 | |
plus, i fully expect everything clearcorners says is true because i remember a thread a few years ago when with his own struggles put this crap on his car when touge factory was the only company that made solid offset conversion bushings while everyone was stretching their rubber bushings. |
04-18-2012, 04:38 PM | #25 | |
haha you mean back when S15 subframes were considered an enigma? OH SHIT, S15 SUBBBBFRRAAAAME!!!! Then 2 years pass and its like "oh, they're practically the same" with only minor differences. note to all: those 2 rear exhaust hangers are known to fail, i've seen the bolts corrode and the 2-hanger assembly comes crashing down. FUN :-) Thats why I highly advise using ALL hangers, which is why I spent the time to cut and relocate my s13 provisions onto the new subframe |
04-18-2012, 05:30 PM | #26 |
Trader Rating: (24)
Feedback Score: 24 reviews
I remember i seen someone cut the part where it hits the tranny hump and mentioned how much he cut, but i cant seem to find it! i forgot to save it, can someone please show me the way?
04-19-2012, 07:35 PM | #27 | |
09-13-2017, 04:33 PM | #30 |
im running s14 rear subframe with s14 adjustable toe arms, s14 rlca, s14 diff cover, s13 axles, s13 spindles, s14 traction, s13 coils, s13 ruca. I have major toe in issues and my toe arms are adjusted as short as possible. I have read numerous threads and there seems to be debate on whether or not you need to run s14 spindles. I only started to have toe problems when I switched from s13 rlca to s14 rlca and im guessing it is because I have s14 rlca on s13 spindles. please help
