12-19-2012, 12:48 PM | #1 |
replacement throttle body for stock ka24de?
is there any 'new' oe replacement throttle bodies available for a stock ka24de?
..or if not 'new' than just something 'newer' than a 90's ka24de throttle body?
FS: Nismo R-Tune Camshafts for VQ35DE. |
12-19-2012, 01:26 PM | #2 | ||
If your after stock replacement just hit up the parts store, you can have them ordered from autozone but last I looked it was really expensive or check out the dealerships.
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
12-19-2012, 02:26 PM | #3 |
Just curious what wrong with the existing TB?
12-19-2012, 03:56 PM | #4 |
nothings wrong with the existing TB..well..
my original one has a TPS screw neck stuck in it and the TB was fine. a used replacement one i got, i think is bent or somethings wrong with it. It's letting more air in and giving me a high idle and no matter how much i adjust it, nothing helps and its burning up more fuel than it should. ..but i was just curious if there were any new replacements available out there.
12-19-2012, 04:07 PM | #5 |
Theres replacement but dont think that your issue. Good possibility is the TPS wasnt set where it needs to be and ECU think your TB is partially open. The small TB Idle screw may need adjustment as well.
12-19-2012, 04:29 PM | #6 | |
i wasn't looking for a brand new TB as a solution, was just wondering if there was incase i decide to get one in the future.
12-19-2012, 08:31 PM | #7 | |
You don't adjust idle on you TB.
Look in my Sig and that is the right way to do it.
12-20-2012, 04:05 PM | #9 | |
why'd you replace it?
12-20-2012, 05:08 PM | #10 | |
Formatting was strange on my phone when I posted that, I could only see the parts about adjusting your TB.
12-21-2012, 05:08 PM | #11 |
yeah, whats up with that? i stopped going to zilvia on my phone because things started looking funny..strange.
12-21-2012, 05:25 PM | #12 | |
It has to do with the way mobile browsers try to resize sites so you don't have to scroll side to side. Did you use a new gasket on the TB? Might have cracked the old one just enough to let more air in.
12-21-2012, 05:30 PM | #13 |
yup, used a new gasket. even picked up a spare the other day just for when i put a new TB on.
01-27-2013, 03:27 PM | #14 |
put a new(used) TB..adjusted idle..she's running fine now.
only issue is...runs a little 'inconsistent'. think theres an air/vacuum leak somewhere. will be running some tests.
