09-14-2007, 08:49 PM | #1 |
My cas, i just ordered, has no color dots
i have searched and searched but no one has this problem. my cas has no color dots, how i determine where to align it to?? although it has the pin that goes through the shaft, help please, ill give rep.
09-15-2007, 10:52 AM | #2 |
Ok when installing the CAS There are two dots next to eachother with the gear pointing away from you the Left dot should be the Yellow one so when installing it line up the right Dot (Not Yellow) with the "slit mark" (while engine is @ TDC #1Cylinder ) and when you install it it will rotate to the Yellow dot. So the Yellow Dot should line up with the Slit Mark after Install. Bam your done
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
09-15-2007, 12:29 PM | #3 |
didnt he just say there were no colored dots?
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
09-15-2007, 01:10 PM | #4 |
I told him the two dots next to each other the LEFT ONE WAS THE YELLOW ONE!
read it closer next time
09-16-2007, 08:23 PM | #5 |
If you don't have the colored marks on your CAS, do you have an indent? My S13 DE did not have the colored marks but did have an indent to use to align the CAS
A picture of mine... |
