Old 05-20-2008, 03:29 PM   #1
KasperSlide
KasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choices
DIY headlight restoration
Heres a Do It Yourself headlight restoration I did it on my s14 but ill show you on the PT loser cruiser
Buy the kit at your local auto part store. i got this one at pep boys. ask for headlight restoration kit or look in the light bulb section
First choose the sand paper that will suit ur app if the light has no heavy scratch or damage then start with the 2000 grit. fill the container with water and let the sand paper your going to use soak (all sheets that you chose)
start wet sanding the headlight. use on general direction
during this process the headlight/ sand paper will dry wet it regularly. repeat this step with the 2500 grit
wipe the headlight clean
as you can see the headlight is still foggy. but dont worry
grab the cloth that was givin in the kit along with the polishing compound (milky stuff). wet the end of the cloth with the polish. use heavy pressure in circular motion wet the cloth with the polish every 30sec-min. wipe clean every so often till you like what you see
this was the end result with the PT
and this is my s14 after doing this. note mine were really bad
KasperSlide is offline   Reply With Quote
Old 05-20-2008, 03:35 PM   #2
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
came out good...nice work dude
ecuastyle84 is offline   Reply With Quote
Old 05-20-2008, 03:38 PM   #3
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
we did the same on my friend's zenki. but we didnt wet sand it at all, we went straight to the milky compound. then it was still yellow so we hit it w/ car polish. that stuff works wonders!
aoiken3 is offline   Reply With Quote
Old 05-20-2008, 04:05 PM   #4
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
I may have to try this.
thelinja is offline   Reply With Quote
Old 05-20-2008, 04:16 PM   #5
KasperSlide
its alot less expensive than buyn new headlights. i recommend it before goin and buyn new one
Old 05-20-2008, 04:26 PM   #6
KasperSlide
only took about 30-45mins BTW and the kit cost like 12 bucks
Old 05-20-2008, 04:40 PM   #7
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
i did the same thing with brasso and Maguires plastic X
works like a charm
-los
los_inc is offline   Reply With Quote
