S13/LS/T56 and Universal Parts
Parts listed are new and never used, only fitted or mounted.
The price listed is obo. Buyer pays shipping and PayPal fees. Pictures attached via link. https://imgur.com/a/mrkadwh - Takata Race Harness x2 $600 (expired certification) - Takata race 4 bolt harness - ASM 3" shoulder 4pt pull up - black Part#TAK71001US-0 - Takata race 6pt sub strap (t-bar) - black - Part# TAK-79000US-0 - Sikky driveshaft S13 with LS/T56 to Winters Differential $500 - 3.5? aluminum shaft - 1350 joints - Sonnax slip yoke - Part# SKNISH1-WI-A - CVR protorque extreme starter $300 - 4.44:1 gear reduction - 3.5hp - 11 tooth pinion gear - 5 adjustment postions - Up to 400cu in 18:1 compression ratio - Part# CVS-8414 - Endless rear brake pads 240sx $200 - Part# EP064ME22 - Vibrant Tubing $90 - Polished aluminum - 90 degree bend - 4? diameter - Part# VIB 2876 - Polished aluminum intake tube - 4? diameter - Part# VIB 2877 - LS1 Valve covers ? powder coated wrinkle black $100 - LSX LS1/6/2/3/7 billet black valve cover oil cap breather - Part# CBW 025B - K&N universal clamp on air filter $60 - 4? - Part# RE-0870 - Murray Plus 160 degree thermostat housing - Part# 37960 $15 - Titanium lug nuts M12x1.5 $200 - Porterfield performance street pad $90 - Nissan: 89-96 300ZX, 92-96 300ZX Turbo, 89-93 Skyline GTR R32, 93 98 Skyline GTS R33 2.5 Turbo, 97-02 Skyline GTT R34 - Part# AP 460 R4-S - MSD LS coil harness power upgrade - Part# 88867 $50 - Bosch wideband 02 oxygen sensor - Part# 0258007057 $50 - Aeroforce Technology Inc $400 - Interceptor OBD2 Dual Gauge Chevrolet Camaro 96-02 - Part# PT102 - ICT Billet LS coolant steam port crossover hose kit $50 - LS1 throttle body bypass - Part# 551692 - Ortiz Custom Pods $90 - 89-93 Nissan 240sx - Triple pod Ac vent - 52mm gauges - Part# OCPN-0003_CST - Speedhut Gauges with Broadfield Custom cluster $800 - 2-5/8" Water temp gauge 120-260f w/warning - 3-3/8" GPS speedometer gauge 200mph w/ turn signal and high beam - 3-3/8" Tachometer gauge 10k rpm shift light - 2-5/8" Fuel level gauge programmable w/warning - Chase Bays fuel line kit $200 - Nissan 240sx S13/14/15 with GM LS | vortec v8 - Part# CB-N-LS-FPR - Racepak IQ3 logger dash - Part# 240-DS-IQ3LD $1800 - GMB water pump $100 - 97-04 v8 5.7L, 05-06 v8 6.0L - Part# 130-7290 - Nick Williams 102mm DBW billet throttle body $650 - Mechman billet machined 170 amp racing alternator GM truck LS engine swap Part# B8206170M $400 - Walbro F90000274 Fuel pump x3 $270 - E85 or Gas - Flow 422lph @ 3 bar - 15.6 amps @ 13.5v - Saikou Michi Co. USA closed loop oil catch can $200 - Internally baffled dual body w/ ball valve drains - cylinder size 2.5"x 6" - Hose size 3/8? - LS1-LS6 - Part# S1-LS1-DC3 - CXRacing aluminum ignition coil packs relocation plate for LS1/3/LSX Camaro Part# COVER-LS-COIL $80 - Derale Hyper-Cool extreme remote fluid cooler w/ 800cfm fan pressure tested 250psi - Part# DER-15875 $350 - Chase bays Chase bays 14" tucked aluminum radiator $700 - Passenger side oe style - CB-12FAN x2 - With shroud - ATL fuel cell MB115 - expired $600 - 15 gal - CFD-600-HP - "black box" surge tank kit w/ cfd-104 hp pump 102LPH @100psi - OS - TF703 - offset remote fill paddle valve - Sikky Manufacturing S13/14 subframe bushing set $70 - Stock height - Part# BK101 - ARC 12000 series switch panel kit $700
