Old 07-04-2008, 11:44 AM   #1
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
SR stall issue and what ECU(SPL Brain) specs?
i thought i rechecked everything and now i have this plug wire that i think is a ground not pluged into anything. does anyone know where it goes. its for my s13 redtop.
also after running my car for a few minutes it stalls out and is hard to keep a good idle. currently i have no BOV and i have mounted a FMIC so should i just plug up this hole until i have a BOV and would that solve my problem?
Heres some engine bay shots as well tell me if you see anything wrong this is my first swap and i wouldnt mind some criticisim.
FRoSt415 is offline   Reply With Quote
Old 07-04-2008, 02:50 PM   #2
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Plug up that b.o.v insert it's causing major boos leak.. Bad air flow=Bad idle.. And that ground wire, there is a little metal tab right next to it on the fire wall. It plugs right on to it.
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 07-05-2008, 12:05 PM   #3
FRoSt415
FRoSt415's Avatar
is it safe to drive with that plugged up and without a BOV?
Old 07-05-2008, 12:11 PM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
yea, i just wouldn't do a lot of crazy boosting if you want to save you turbo's life
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-05-2008, 02:58 PM   #5
FRoSt415
FRoSt415's Avatar
sounds koo, i just need to drive it around a little and go to the muffler shop. no major boosting.
Old 07-05-2008, 11:23 PM   #6
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
that ground is for the igntion, there is a spot for it on the fire wall under that lip in your picture.
njd07 is offline   Reply With Quote
Old 07-07-2008, 12:11 AM   #7
Joel 180
Joel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choices
also do something with the t piece on the valve cover. You dont want to drip oil onto the exhaust manifold
Joel 180 is offline   Reply With Quote
Old 07-09-2008, 11:19 AM   #8
FRoSt415
FRoSt415's Avatar
cant find tab for the ground and pluged the hole but my idle is all messed up now what can i do? ill post a video in a day or so.
Old 07-15-2008, 10:12 AM   #9
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
yeah def plug the hole up (major boost leak) should stop you from stalling. Idle is messed up how? low/high idle or constantly moving around?
reccakun08 is offline   Reply With Quote
Old 07-23-2008, 09:31 AM   #10
PhopsonNY
PhopsonNY's Avatar
PhopsonNY is an unknown quantity at this point
If you cannot find the tab, then it must be missing. All you need to do is make your own ground from good thick copper wire to connecting point on the block to a good ground point on the chassy.
Above!!!
PhopsonNY is offline   Reply With Quote
Old 07-23-2008, 12:47 PM   #11
FRoSt415
FRoSt415's Avatar
HELP me Identify THIS!!!!!
ok video is to big for photbucket but i think i have it fixed thanks guys i have a new problem now. can it be my ECU i have this ECU but i dont know what the specs are on it for. i have read in the past that it is for stock sr's but an not sure. when i unplug the Air flow sensor it idles just fine at about 1,500 rpm after it warms up. can anyone help me with identifying this ecu to what specs i need to run right?
Movie of idle that i can fit it cant rev past 3k MVI_0983.flv - Video - Photobucket - Video and Image Hosting
ok its the MAF i think its tuned for z32 will be getting one in a few weeks let me know if anyone has one for sale for a good price.
