02-27-2009, 08:06 PM | #1 |
help for extended studs
So I was wondering if anybody out there has had any bad experience with the extended studs that come with the ICHIBA spacers, the ones that are not built in the spacer. Because that's what I got and I'm afraid to drive my car because 2 of them allready exploded off. So I just wanna go ahead knockem out and put some that hold like alot of stress. So what do you guys recomend to get.
02-27-2009, 08:07 PM | #2 |
hmm, if two already exploded.. common sense should probably tell you the answer?
edit: get extended studs, replace them from the hub ( not the spacer ) -> get spacer -> done
03-05-2009, 10:07 AM | #4 |
i ran the camaro ARP studs for the 08 season. not one problem. if you can get over the fact they're not knurled bling bling. you're also going to be converting your lug nuts to 1.5mm pitch.
they fit just as good as all the rest, cheap too. 55 for the complete set.
NASA PTD/SCCA ITS |
