Old 02-19-2019, 11:42 AM   #1
ferlepo
ferlepo is an unknown quantity at this point
Exclamation No Spark Plug - Silvia 200sx
Hello friends!
My name is Fernando from Argentina, I have a Nissan Silvia S14 Zenki SR20DET LHD.
I have a big problem! The engine not start and I dont have spark.
I made this:
1. Check the ignition relay = WAS OK (next to the ECU motor, passenger side)
2. Check the ignition fuse 7.5A = WAS OK (fuse box, near to clutch pedal)
3. Continuity between fuse 2 and pin 43 of the ECU = WAS OK
4. I have 12 volts on the blue wire coils (I have new colis and new spark plugs)
5. I checked the injectors and CAS = WAS OK
I'm desperate because I do not know what else I can check.
Someone can help me?
ferlepo is offline   Reply With Quote
Old 02-22-2019, 08:09 AM   #2
jedi03
how are your grounds, specifically the one on the back of the head?
Old 02-22-2019, 12:30 PM   #3
ferlepo
Hello!
Yes! I just installed more than 4 ground. (intake manifold, head, engine block and behind the fuse box).
I dont have +12v on the ECU. (ECM)
PIN 49, 59 and 109 must have 12v. but I dont have it.
I checked everything. I do not know what else I can check.
I checked every relay and fuse.
Old 02-23-2019, 12:21 PM   #4
ferlepo
I have +12v in the CAS and my 4 injectors.
But I dont have spark.
I checked the pulse injectors with a led light and it's OK (blinking) but I dont know why it does not start the engine.
Do you have any new idea?
Old 02-26-2019, 08:33 AM   #5
jedi03
if your fuses are good but you don't have power to the pins that need power i would try swapping relays with known good ones and if that still doesn't work then check the wire from the fuse to the ecm for damage
Old 02-26-2019, 10:17 AM   #6
ferlepo
Thanks for your advice.
Yesterday I remove the CAS sensor, put the switch ON, and I did spin by hand but I cant hear injectors noices.
Fuel pump is activated when I spin by hand the CAS sensor.
Old 02-26-2019, 10:19 AM   #7
ferlepo
[QUOTE) check the wire from the fuse to the ecm for damage [/QUOTE]
Do you know wich is the wire?
