Old 03-23-2018, 06:57 AM   #1
K!NCH
K!NCH is an unknown quantity at this point
1988 Mazda Rx7 Turbo
FOR SALE: 1988 Mazda Rx-7. Asking: $6500. Located in Cincinnati, OH.
Engine:
Stock turbo dynoed at 265hp/295tq
13B S5 TII short block built by GarageLife. Under 1000 miles
Racing Beat high pressure oil regulator
New Oil Pump
1000cc Injectors (primary and secondary)
FFE Fuel Rail
Aeromotive FPR
Mk4 Supra Fuel Pump
Like new BNR Stage 2 Turbo
3" Racing Beat Downpipe
3" Racing Beat Pre-Silencer
Apexi N1 cat-back (modified to be 3" all the way)
OEM Top Mount Intercooler
Haltech Sprint RE installed and tuned by Defined Autoworks (tuned for S5 turbo not BNR)
SS lines throughout
Drivetrain:
ACT Street/Strip Clutch
Racing Beat Flywheel
TII Trans
TII Driveshaft
TII Axles
TII Differential (modified or aftermarket, not sure)
Suspension
Fortune Auto 500 coilovers w/ SWIFT springs (8k front, 6k rear)
SuperNow Tie Rod Ends
Eyecandy Extended Tie Rods
Part Shop Max Rear Toe Arms
AWR Individual Rear Camber Adjusters
SuperNow Rear Camber Center Link
Pinion Snubber
HAWK HP+ Brake Pads
SS Brake lines where possible
Sportmaxx/XXR 009s (discontinued) 17x8 +35
225/45/17 Kumho Ecsta V720s
Chassis:
82,XXX miles on the body
Rear quarter panel was damaged but professionally fixed
Frame has never had any issues.
Garage kept as much as possible.
S5 conversion body conversion
TII hood
TII side skirts (mostly removed, but a full set will be included)
Moonroof motor does not work, can use manual crank.
Interior:
Blue S4 interior
Decent shape (dash is not cracked, some vents are missing, carpet is ok)
Nardi Gara Steering Wheel
Alpine head unit
Innovative AFR Gauge
Prosport Boost Gauge
Prosport Oil Pressure Gauge
Prosport Water Temp Gauge
Greddy Profec II Boost Controller
Retro Spec Logicon Three Gauge Pod (not installed)
BRIDE seat is not included, will be replaced with OEM drivers seat
Viper alarm system
Aftermarket power locks
Aftermarket power windows
The Bad:
Car smokes (blue) under throttle, I believe it's an oil control ring not an apex seal or low compression issue. Car starts, idles, revs, builds boost and drives just fine. Video can be provided for anyone interested.
Needs tuned adjusted for the new turbo.
Due to these issues towing/trailering the car is recommended.
K!NCH is offline   Reply With Quote
Old 04-04-2018, 12:05 PM   #2
K!NCH
Bump number 1.
Old 04-07-2018, 07:52 AM   #3
jedi03
Clean fc! Glws! I would recommend a good vacuum before taking pics again but again nice fc!
Old 04-12-2018, 03:58 PM   #4
K!NCH
Thanks for the comment! Yeah shes due for a good wash now that the weather is nicer.
Old 04-12-2018, 09:41 PM   #5
liquidchicken
liquidchicken's Avatar
liquidchicken is a well-known jackass
An oil control ring will require a rebuild, but at this price it seems like a fair deal. Its a pretty good looking 7... GLWS
liquidchicken is offline   Reply With Quote
Old 04-13-2018, 05:52 PM   #6
K!NCH
Appreciate it, and yeah that's why I have it priced as such.
Old 04-25-2018, 07:18 AM   #7
K!NCH
Bump number 2
Old 04-25-2018, 10:12 AM   #8
GtoRx7
GtoRx7 is an unknown quantity at this point
I have seen this car in person. Its a nice machine. These are getting hard to find. GLWS
97 s14/rotary turbo powered/535whp, 410lbs NOW N/A 20b/500whp/ 10,500 rpm
GtoRx7 is offline   Reply With Quote
Old 05-09-2018, 08:45 AM   #9
K!NCH
Sold. Please close/delete.
