07-09-2017, 08:10 AM | #2 |
What're you doing, going for some kind of record? Just keep it at 7500rpm, it's never going to make power past that anyway.
What cams? What turbo?
07-09-2017, 03:04 PM | #4 |
Id imagine it would hold up to 9k RPM's no problem. its fully counterweighted. and the heads the known weak point for revving that high anyway. so its not like an SR bottom end has never been taken to 9k before
07-09-2017, 05:03 PM | #5 |
You will make sharply declining power after 7500rpm if you aren't running a decently large turbo that can feed in extra boost.
07-10-2017, 02:06 AM | #6 |
For now, until 7000 rpm its pretty stable - using stock head and 1.2 bar of boot with the current turbo (gt2871r)
http://oi57.tinypic.com/29y49wz.jpg |
07-10-2017, 02:24 AM | #7 |
Trader Rating: (32)
Feedback Score: 32 reviews
I'm assuming you're building a solid lifter head at the very least? Stock bottom end can be revved to about 8K rpm safely..and by safely I mean <400whp. Anything above that and you're pushing the limits of the stock rod bolts.
07-10-2017, 06:33 AM | #9 |
It'll go until it doesn't anymore and it'll be completely reliable until then.
High RPM = High Chances of Breaking Shit Quickly My SR snapped an OEM rod at about 400hp and sent it through the side of the block and that was on the factory redline. |
07-10-2017, 08:21 PM | #10 |
I'd say 7500max.
Tight stock bearings dont like to be spun high. LOTS of failed stock bottom ends out there making well below 400 horses. And I've had a few making 380 that lasted quite a long time with a 6500rpm rev limiter. IMO 7200+ Is pushing it too far. iirc, the FSM says the rod bearing can be as tight as 0.0008". Whereas you might want something like 0.002" instead for that much rpm. |
