08-12-2008, 10:26 AM | #1 |
Trader Rating: (40)
Feedback Score: 40 reviews
Whats stock boost for S13 S14 SR20DET
Sounds like a very simply question but one that isn;t very easy to find a deffinate answer to.
What I do know: S13 SR20DET Wastegate actuator has a 7lbs spring so it is either 7psi or higher, now before someone jumps in and says you answered your own question not so fast. The W10/W11 Avenir AWD SR20DET commonly swapped into the FWD B13/B14/P10/P11 chassis also has a stock wastegate actuator with a 7lbs spring inside, but is boost controlled from the factory to .65bar (9.4psi) IIRC. What I dont know: S14 SR20DET I dunno nothing about that not even what the stock wastegate actuator is rated at with no boost control if any. Last edited by UNISA JECS; 08-12-2008 at 11:58 AM.. |
08-12-2008, 10:34 AM | #3 | |
stock for most of the swaps in the US....7lbs.
08-12-2008, 10:55 AM | #6 |
Trader Rating: (40)
I guess notch top is S14? ok so if it is that pretty much tells me that the stockwastegate has a 7lbs spring inside it, now if we can find out the factory boost pressure.
08-12-2008, 11:20 AM | #9 | |
Trader Rating: (40)
But we wanna know what the stock boost is from the factory, if you say its 7psi that doesn;t make much sense because what would be the purpose of the factory boost solenoid For example: U12 Bluebird rated at ~207ps journal T25g U13 Bluebird rated at W10 Avenir rated at 230ps journal T25g W11 Avenir rated at 230ps ball bearing 25g RNN14 GTi-R rated at 230ps journal T28 I imagine none of these boost 7psi from the factory, what would be the purpose of a boost solenoid then.? |
08-12-2008, 11:23 AM | #10 | |
Pretty sure this thread was created to dispel some of the myths or questions surrounding the inconsistent answers that are always giving about the stock boost pressure on the S13/S14/S15 motors. Most people in the US claim stock boost pressure is 7psi on the S13, because a lot of them don't have the stock boost solenoid on there, or their's aren't working, thus so far, everything "assumes" that it's 7psi stock. I think Unisa Jecs is trying to PROOF it once and for all, so we can all put it on the records and say "yes, stock is ___psi". |
08-12-2008, 11:23 AM | #11 |
Trader Rating: (40)
Maybe I wasn;t clear enough in my first post, my bad.....I just dont wanan see a bunch of people replying that they boost 7psi, we know this already, that just means you dont have the stock boost control solenoid in your car working.
Please read the first post again and then look at whats highlighted in RED about the Avenir. |
08-12-2008, 11:25 AM | #12 |
I don't have time right now to look through the S14 SR20DET FSM that's commonly found on the internet as a PDF file, but I'm sure it mentioned the boost solenoid in there.
I just don't remember if it mentioned the default pressure of boost it's supposed to generate if it's working properly. |
08-12-2008, 11:28 AM | #13 | |
Trader Rating: (40)
Same thing goes for the RNN14 GTi-R I have a FSM for that to with the same, no mention of the stock boost pressure, I will look again to make sure as well. |
08-12-2008, 11:30 AM | #14 |
Yep. I'm almost certain it's 11lbs for the S13 SR. I'm not quite as sure for the S14.
My seller review thread |
08-12-2008, 11:37 AM | #15 |
Trader Rating: (40)
You know what im going to ask Matt from Nistune since he is in Australia and AFAIR they sell factory Nissan SR20DET atleast S14 im not sure if they sold S13 out there.
08-12-2008, 11:42 AM | #17 |
The point of the Nissan boost solenoid is to switch from the low boost and high boost settings. Low boost is 4psi high boost is 7psi.
I didn't know that about the Avenirs.... we really don't get those motors to often so I haven't put that much research into them. Last edited by slidingsky; 08-12-2008 at 01:35 PM.. |
08-12-2008, 11:44 AM | #18 | |
Trader Rating: (40)
By default if the boost soleniod failed your boost would drop to 7psi via the rating of the stock actuator. I know that the U12 U13 W10 S13 all have 7lbs wastegate srpings +/- .5lbs *AWD SR20DET engines are my background knowledge of the SR20DET, I just have never knew for sure the stock boost of any but the W10 Avenir. |
08-12-2008, 11:45 AM | #19 |
4 pounds is way too low. Boost without a solenoid is 7 pounds; the solenoid can *only* increase boost, not decrease it.
Gah, beaten to the punch.
08-12-2008, 11:56 AM | #21 | |
Trader Rating: (40)
You could disconnect your solenoid and I can guarntee you yoru boost will not drop below 7psi +/- .5psi (for wear and tear of the wastegate) |
08-12-2008, 12:18 PM | #22 |
What sense does it make to boost to X Psi if you have a wastegate that is rated for 7 Psi? The real question would be to get something around a 15 Psi spring and then see what happens with a working boost solenoid in place. Assuming that it really is 11 Psi like suggested (not doubting it btw).
08-12-2008, 01:03 PM | #23 | |
All a boost controller or boost solenoid does is create a controlled leak so that the wastegate thinks the manifold is seeing less pressure than it actually is. Stock wastegate actuator is 7 pounds. The factory solenoid creates a controlled leak between the manifold and the actuator so that when the manifold sees 10-11 pounds (pretty certain it's 11), the actuator sees 7 and opens up.
08-12-2008, 01:10 PM | #24 | |
Trader Rating: (40)
08-12-2008, 01:21 PM | #25 |
Trader Rating: (40)
When you think about all this:
KA24DET @ 7psi has an effective compression ratio of 14.0:1 SR20DET @ 7psi has an effective compression ratio of ~12.5:1 SR20DET @ 9.7psi has an effective compression ratio of 14.0:1 This shows one example why it takes more boost on a SR to make the same horse as the KA all things equal. Factory boost pressure has to be similar to the Avenir SR20DET from the factory. |
08-12-2008, 01:42 PM | #27 | |
Trader Rating: (40)
To add to this just called my friend that I swaped a W10 Avenir SR20DET into his B13 Sentra SE-R years ago and I just remember he installed a RNN14 GTi-R T28 journal bearing and he told me the actuator pressure is ~9psi but thats only confirming the wastegate rating. |
08-12-2008, 01:48 PM | #29 |
Im sure that the S14 Boost level is no Higher than the Red Top Since the S14 still runs 370cc Injectors
I have a video @ home of a RHD BONE STOCK 180SX with a close up on the boost gauge when I was test driving it, I will find it and upload it when I get home... If interested. If I remember correct I dont think I ever saw it go above .7 Bar
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
08-12-2008, 01:54 PM | #30 | |
Trader Rating: (40)
Try and get the video uploaded if you can that'll be cool. |
