Old 11-27-2016, 06:51 PM   #1
Clean98
Clean98 is an unknown quantity at this point
Nismo 2way with q45/TT axles
Nismo 2way R200 diff w/ 6x1 output shafts
Q45 6 bolt driverside axle
Z32 TT 6 bolt driverside axle
All in very good condition it's a spare for my s14 I could use the cash for other goodies
Will ship at buyers expense
SOLD
IMG]http://uploads.tapatalk-cdn.com/20161128/08a7fd98cb4052c5ebb03e785b17e88c.jpg[/IMG]
Clean98 is offline   Reply With Quote
Old 11-28-2016, 08:03 AM   #2
EnergeticPhenom
EnergeticPhenom is making a name for him/her selfEnergeticPhenom is making a name for him/her self
This actually works? Sorry, I could just be informed. I thought my only option was with a Vlsd and those 6 point outputshafts
EnergeticPhenom is offline   Reply With Quote
Old 11-28-2016, 08:13 AM   #3
Clean98
Of course it works it's a nismo 2way for a skyline so you get the 6 bolt shafts for the bigger axles
Old 11-28-2016, 08:58 AM   #4
EnergeticPhenom
Very nice setup! Figured it must be skyline. Do you know if the threads are for m13 or m12 gear bolts?
Old 11-28-2016, 09:07 AM   #5
Clean98
It sure I will have to look I had an early model q45 ring gear in it I will measure them tonight
Old 11-28-2016, 09:48 AM   #6
Clean98
It's 13mm I just googled it
Old 11-28-2016, 11:20 AM   #7
waterboy
waterboy's Avatar
waterboy can only hope to improve
what diff housing does this fit in?
waterboy is offline   Reply With Quote
Old 11-28-2016, 11:47 AM   #8
Clean98
Q45 is what I had it in not sure what else it fits it's an r200
Sent from my iPad using Tapatalk
Old 11-28-2016, 12:34 PM   #9
waterboy
waterboy's Avatar
what spline are the stubs
what model nismo diff is it
Old 11-28-2016, 12:53 PM   #10
TheRealSy90
TheRealSy90's Avatar
The real benefit here is the larger splines on the stub shafts since it's a skyline carrier.
It may be an R200, but the Q45 diff doesn't fit an S-Chassis housing. So if this fits in the Q45 housing, it probably also won't fit an S-Chassis housing.
Such a good signature.
Old 11-28-2016, 12:58 PM   #11
Clean98
Thanks for the info I have a q45 housing in my car I never tried to put it in my s housing
Old 11-28-2016, 01:11 PM   #12
Clean98
Not sure I'm the exact model and they are the larger 31 spline stubs
Old 11-29-2016, 05:26 AM   #13
Clean98
Bump still available
Old 11-29-2016, 08:57 AM   #14
MaxTheRabbit
MaxTheRabbit is an unknown quantity at this point
IIRC, the only thing stopping it from fitting is the larger output bearings right? you could press on different bearings to fit the s-chassis housing I think
MaxTheRabbit is offline   Reply With Quote
Old 11-29-2016, 10:00 AM   #15
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
let me know if you need help saving money on shipping
Old 11-29-2016, 05:55 PM   #16
Clean98
I priced it out yesterday it was $120 ish ups it's heavy 70 lbs lol
Old 11-30-2016, 09:52 AM   #17
Clean98
Hump day bump!
Old 11-30-2016, 10:41 AM   #18
r240sxse
r240sxse is an unknown quantity at this point
This fits the R200, Q45 fits LSD fits S-SHASSIS HOUSING (R200). The housings are what change R230 is the Q45 housing if im not mistaken.
r240sxse is offline   Reply With Quote
Old 11-30-2016, 12:10 PM   #19
Clean98
Q45 is an r200 not an r230 your post is confusing
Old 11-30-2016, 03:24 PM   #20
Koukiii
Koukiii is an unknown quantity at this point
Damn dude why is my raise a couple months away...Very nice parts
Koukiii is offline   Reply With Quote
Old 11-30-2016, 06:07 PM   #21
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Dang!
I want just the diff.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 12-01-2016, 05:34 AM   #22
Clean98
Bump
Old 12-01-2016, 11:30 AM   #23
Clean98
Originally Posted by Black R View Post
Dang!
Make me an offer
Old 12-02-2016, 06:41 AM   #24
Clean98
It's the weekend bump OBO!
Old 12-02-2016, 09:01 AM   #25
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
Rb26kouki is an unknown quantity at this point
Feedback Score: 63 reviews
Only those output shafts will work?
Q45 6x1 output shafts seem to be longer
Rb26kouki is offline   Reply With Quote
Old 12-02-2016, 09:31 AM   #26
Clean98
Yes this is a clutch type the shafts are shorter than the normal q45 lsd has a longer shaft on one side you can't use these on a regular diff it won't work
Old 12-03-2016, 09:34 AM   #27
Clean98
To the top reasonable obo
Old 12-04-2016, 04:41 PM   #28
elguapo260sx
elguapo260sx's Avatar
elguapo260sx is an unknown quantity at this point
i run this exact same setup. the stub shafts are from and r32 gtr with the helical diff. i used a q45 housing and gear set. yes it works. driven several thousand no issues. you just need to setup the gear lash. id rather have a 1.5way diff for how i drive. you will also need the q45 hubs or the z32tt hubs, bigger splines for the axles. bump for you
elguapo260sx is offline   Reply With Quote
Old 12-04-2016, 05:13 PM   #29
Clean98
Thanks!
Old 12-05-2016, 07:50 AM   #30
Clean98
Bump
