03-24-2009, 04:26 PM | #1 |
quick question about spindles
When using s14 spindles on s13, do you have to use s14 suspension mounting brackets? I know the holes are bigger, but are the mounting brackets wider? Thank you. Oh this is for the front of course.
Nothing says racecar like a stock car with no interior. |
03-24-2009, 04:39 PM | #3 |
yea or a s14 ball joint. I just need to know if the suspension mounting bracket is the same width.
03-24-2009, 04:39 PM | #4 |
What brackets? Use the S14 spindle and ball joint. Done. We've covered this for over thirteen years.
03-24-2009, 04:41 PM | #5 |
Negative.^^^ You don't HAVE to use S14 LCA, but it makes it easier. Everything is just a bolt on affair except for the coilover mount. You can either be ghetto and drill the hole out like I did or get the sleeves that Enjuku sells.
I remember reading something about using the S13 LCA, but you have to have a S14 ball joint pressed in? Correct me if I'm wrong... EDIT: RDM answered the questions. |
