Old 01-05-2024, 08:44 PM   #1
240boosted
240boosted has a little shameless behavior in the past
sr20det intake and exhaust gasket question
Do you guy think it worth to spray copper spray on a new gasket for the intake gasket and the 7 layer gasket oem nissan exhaust manifold gasket
240boosted is offline   Reply With Quote
Old 01-08-2024, 02:55 PM   #2
slider2828
slider2828's Avatar
Nah no need.... it should seal. The 7 layer allows it to adapt to slightly non flat surface itself..... If the 7 layer doesn't seal, you got worse problems.
Turn and Burn!
Old 01-09-2024, 10:18 AM   #3
240boosted
ok thank you i just seen alot people posting about that that applies for intake manifold gasket also too the oem nissan one seems a bit flimsy do you think that https://www.sikky.com/product/s13-sr...lnator-gasket/
this gasket would be a better seal or just try the gasket again i ask bc i had a vacuum leak and it would start from there thanks.
Old 01-09-2024, 10:28 AM   #4
slider2828
slider2828's Avatar
The intake is different from the 7 layer exhaust. 7 layer exhaust provides squish so there is some sealing help....
They apply sealant to intake cause that is 1 layer thin metal maybe?
Just a get a new intake gasket, don't need to apply anything. The intake gaskey sort of has a crush surface as well.... you will see when you get it....
Turn and Burn!
Old 01-09-2024, 10:45 AM   #5
240boosted
OK yes i thought so thank you so much one last
from this picture
https://ibb.co/dc2mDhR
i know 2 is for the charcole canister but what does 1 and 3 go to?
Old 01-09-2024, 04:53 PM   #6
Kingtal0n
Kingtal0n's Avatar
intake spacer thermal gasket no spray its like plastic thats what you want if you can
exhaust you can spray copper gasket sticky, its okay for a new gasket and new surfaces i think its good. However it wont save you from leaks what you really need is the exhaust support properly attached to the transmission and the manifold properly supported etc....
Old 01-09-2024, 05:57 PM   #7
240boosted
Thank you its a mazworx manifold i have
my last question is in this photo https://ibb.co/dc2mDhR
i know 2 is for the charcole canister but what does 1 and 3 go to do they need to go to anything
Old 01-10-2024, 07:11 AM   #8
Kingtal0n
Kingtal0n's Avatar
Its water inlet and outlet. If you do not connect that water there is a wax element in the throttle body that wont expand so the idle speed will always be wrong. I know its dumb but it needs water to idle properly.
Old 01-14-2024, 09:01 PM   #9
240boosted
ok i have to look at fsm for how they work then i never seen it connected
