S13 sr redtop Cylinder 3 HELP
S13 redtop sr20det. Bc 264 cams, titanium valves, springs, retainers. 750cc injectors 60 trim top mount set up.
So I snapped an exhaust rocker on Cylinder 3 a few weeks ago. Fixed everything, put it all back together, did a compression test and Cylinder 3 still won't fire. I have good compression, I swapped coil packs, new plugs, I can't figure out what's going on. I took the plug out a few times and it seems to smell like fuel but not a ton, could I fried and injector when I snapped the rocker? I was doing a burn out and I had the motor wound out pretty good,, any help would be really appreciated
Sent from my SAMSUNG-SM-G890A using Tapatalk
