Old 01-21-2006, 11:31 AM   #1
white smoke
white smoke's Avatar
white smoke is a well-known jackass
s13 ECM has no POT or RED LED for Diagnostics???
I have searched all around and cant really find the info I am looking for.
I have a 98 s13 blacktop in my 93 240sx. Im not 100% on the ECU information because the sticker on top of the ECU is half ripped off!
What I do know is that the is a large J on it and I can read the #'s A18-F81 G85(5 could be a 3)... The rest I cannot read. Its either a J4 (manual) or J5 (auto) ECM and is for a type X.
Here is a pic to better show you: http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
Im not sure what the deal is but my ECM does not have any way, that I know of, to test for problems. I opened it up and im sure I found where they would go but there is nothing soldered in there. It looks to have came that way from the factory but I cant be 100% on that. I got the ECU from Heavy Throttle along with my motor. Can anyone give me any info on this ECU and why it does not seem to have this feature? I know some newer ECM's only have the knob and you have to use the dash light but there is no knob on mine. Any info would be greatly appreciated.
Here is where I think the POT and LED should be: http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
white smoke is offline   Reply With Quote
Old 01-23-2006, 05:36 AM   #2
white smoke
So what is this like some unheard of ECM or what???
Let me know your thoughts guys/gals
Old 01-23-2006, 02:40 PM   #3
white smoke
25 views and no one has ever heard of an ecu with out the LED and such???
Old 01-23-2006, 03:16 PM   #4
white smoke
Some more info for you guys that might help.
The ECU is either a j4 (manual) or j5 (auto) ECU and is for a 97-98 type X s13 SR20DET. I need to know how to do the diagnostics. Maybe something like turn the key on with foot on the brake then turn it from on to off like 5 times or something like that.
Someone must know, help me out guys/gals.
THANKS
Old 01-23-2006, 08:33 PM   #5
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
it might be the auto one. NemeGuero had an auto ka24de ecu for the longest time, and it didn't have the diagnostics light either.
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 01-23-2006, 08:39 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
is the swap pretty much done as far as engines in the car, harness done and all you need is figure out if its the right ECU??? If it is then, why dont you plug it up and do the diagnostic using the dash light? Check engine light on the dash should light up just like the POT.
CLICK HERE!!!
Old 01-24-2006, 08:09 AM   #7
white smoke
POTT=Potentiometer Its not an LED but its missing both!
It very well could be that the ECU is auto. BUT it does not have the POT (knob that you turn) or the LED on the ECU. As I said the LED is not the big thing. The question is how do I put it in diagnostic mode if there is no switch (POT)?
The car runs pretty dam good and has been for the last 7 months or so. However, I would like to run the diagnostics on it and I dont know how. Someone must have done this before.
Thanks for the input
This is an 98 SR20DET Type X ECU.
Old 01-24-2006, 08:38 AM   #8
Johny5
Johny5's Avatar
just for a reference point, my 98 5spd ka also does not have the led, it does however have the POT. for you i will check my friends blacktop s13 ecu today and see if his has the POT or the LED. good luck in your search!
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 01-24-2006, 09:30 AM   #9
white smoke
Thanks for the input!
I am also thinking this might be an auto ECU. Its a J5 or J6 thats for sure! Theres got to be a way to get this thing into diagnostic mode.
Old 01-24-2006, 10:25 PM   #10
rps13dreams
rps13dreams is a well-known jackass
In the U.S. 96 and newer are obd2 and have a diagnostic data link connector under the dash. No need for LED or POT. I'm not sure about JDM.
__________ - connector is this shape, 16 pins I think.
\________/
-\______/
rps13dreams is offline   Reply With Quote
Old 01-25-2006, 05:14 AM   #11
white smoke
\________/
-\______/
HAHA thanks for the little drawing but I am familiar with the OBD2 diagnostic port. I would like to be able to check the codes myself without the OBD2 reader and honestly, I doubt it would work properly anyway. (Jp does not go by OBD's) I don't have a CEL on right now so Im not even sure if anything would come up on that. On the other hand, I don't know if I have ever had a CEL so I don't know if it even works or not.
Old 01-25-2006, 04:38 PM   #12
BillKlineVT
BillKlineVT's Avatar
BillKlineVT is making a name for him/her selfBillKlineVT is making a name for him/her selfBillKlineVT is making a name for him/her self
My 97 KA ecu had a POT, no LED...
My roommates 97 180sx Blacktop ECU had a weird little pot (alot smaller than the normal nissan one), and no LED... manual ecu.
I thought I heard the 98 ecus were weird in terms of using a daughterboard on them... so maybe there is some other trick to get the codes
Sorry I couldn't offer very helpful info...
BillKlineVT is offline   Reply With Quote
Old 01-25-2006, 07:42 PM   #13
white smoke
Does he have a J5 or a J6 ECU?
Old 01-26-2006, 09:07 PM   #14
white smoke
Old 01-28-2006, 12:40 PM   #15
white smoke
Any one have any more info?
Old 01-30-2006, 05:43 AM   #16
white smoke
There has got to be someone who knows something. I cant be the only person with an ECU like this!
Old 01-31-2006, 03:22 PM   #17
white smoke
Up for info................
Old 02-04-2006, 12:02 PM   #18
white smoke
Ok I must be the only one on the board with this ecm. Its rare, taking highest offer. lol
Old 02-05-2006, 12:49 AM   #19
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
Mine came from a manual and i have a J4 ecu
IIRC, automatic (type x) is the J5
it probably doesn't help your question, but thought i'd point that out
Pepperoni is offline   Reply With Quote
Old 02-07-2006, 07:19 AM   #20
white smoke
Thanks, Does yours have the diagnostic POT and or LED?
Old 02-08-2006, 11:25 AM   #21
Smurfey002
Smurfey002 has a spectacular aura aboutSmurfey002 has a spectacular aura aboutSmurfey002 has a spectacular aura aboutSmurfey002 has a spectacular aura aboutSmurfey002 has a spectacular aura aboutSmurfey002 has a spectacular aura aboutSmurfey002 has a spectacular aura about
Send a message via AIM to Smurfey002
\________/
-\______/
congrats, you win a prize.
i have a 97 RHD silvia and to do diagnostics on it you HAVE to use the consult port and hook up the tool. obd was not available on that car. so....idk about how you'd do it w/ a swap, but i know that in order for me to do it i eithor a) have to use the tool from nissan(or buy one at like 1.5G's) or use the snap on(or other brand) adaptor for any generic obd scan tool. then again i have an S14, i presume it's the same scenerio though.
Smurfey002 is offline   Reply With Quote
Old 02-09-2006, 03:34 PM   #22
white smoke
So I gotta go to autozone to use the OBD2 tool??? Im not sure if they even have an OBD1 reader so how would I go about it then? How do you wire up the Consult connector? Anyone know?
Thanks
Old 02-12-2006, 02:18 PM   #23
white smoke
Bump................
Old 02-15-2006, 05:50 PM   #24
white smoke
Anyone Else????????
Old 02-15-2006, 06:23 PM   #25
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
if you have access to an esm of some sort you can figure out how to pull codes via the light on the dash. On most obd1 vehicles you can jumper 2 pins in the diagnostic port to get the light on your dash to blink the first set of numbers is the 10's spot...there will be a slight pause then the next set of blinking lights is the 1's spot...it will do this 3 or 4 times then if there are anymore codes it blink the next code. I can look it up at school tomorrow and see. Unless someone can tell you on here
g2ic02 is offline   Reply With Quote
Old 07-15-2020, 11:07 AM   #26
Anselmo Gil
Anselmo Gil is an unknown quantity at this point
did anybody every figure how to read codes without the led or what is a pot
Anselmo Gil is offline   Reply With Quote
Old 07-15-2020, 11:35 AM   #27
S14rebuild
Is this the oldest thread bump todate? Holy shittt
Old 07-15-2020, 02:18 PM   #28
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
I know, what the heck is going on!? 14 y/o thread bump
Anselmo Girl, I'd recommend making a new thread if you want help on your issue. Most of the people from this thread are probably in a nursing home now.
If the ECU is wired up right, It'll flash the MIL (maintenance Indicator Light) on the gauge cluster in concert with the LED. If your ECU is missing one, you should be able to put it into test mode and read the MIL light in that case. Check the FSM for instructions;
https://www.nicoclub.com/nissan-service-manuals
NukeKS14 is offline   Reply With Quote
