10-27-2013, 12:26 AM | #1 |
Trader Rating: (106)
Feedback Score: 106 reviews
1990 240sx fastback, NICE!
Up for sale is my 1990 nissan 240sx fastback. I would really like to keep it, but times are tough financially at the moment. It is an SE model and an ORIGINAL 5-speed car. It currently has about 260k mi with a CLEAN title in hand. It still has the original singlecam, but it has been rebuilt at some point. It also has beautifully working power windows and power mirrors. I have been building these cars for over 10 years with this being the 4th that I have owned for personal use. I know what I am selling. Yes, the mileage is high. BUT, the mileage is high on ANY 23 year old car. Finding these cars in good condition and not all screwed up by some amateur "mechanic" is almost impossible anymore, the mileage is inconsequential. This car also has a significant amount of mods done CORRECTLY on it as well. I am a ASE master tech for a profession and I've been over this car from end to end. It is in AMAZING condition and drives VERY solid. The suspension is nice and tight, the brakes are perfect, and the singlecam pulls stronger than most dualcams. It is definitely the strongest singlecam that I have ever driven, and I've driven DOZENS.
MODS: -Tein front and rear strut bars -NISMO power brace -Cusco front ladder bar -KYB shocks -Tein lowering springs -Tein front camber plates -Tein adjustable tension rods -Yanack ALUMINUM steering rack bushings -DIF solid steering shaft bushing -Peak Performance rear upper control arms -Peak Performance rear toe arms -rear subframe bushing collars -ALL Energy Suspension urethane bushings w/grease fittings -VLSD -B&M short shifter -lightweight flywheel -Exedy stage 1 clutch -Drift Freaq engine/trans mounts -aluminum underdriven crank pulley -Injen intake -Mishimoto radiator -dual Altima electric fans wired CORRECTLY with a temp. switch and manual switch -Brembo slotted rotors front and rear -Hawk HPS front brake pads -braided steel brake lines -braided steel clutchline -S14 seats -Personal steering wheel -NISMO shift knob -Kazama drift button -89-90 XE coupe doorpanels, glovebox, and rear seat (no icky "tweed" interior, RARE) -manual seatbelt conversion -91-94 rear seatbelts -Broadway mirror -Alpine headunit w/new speakers -OMP front tow hook -Carbon hood w/Sparco hood pins -OE blue tinted mirror glass -IKI H4 conversion -Apexi GT spec one-piece exhaust -Circuit Sports urethane exhaust hangers -long wheel studs -4 Ichiba hub-centric 10mm spacers (not installed) -16x8 +25 Work RS-Beta wheels, CLEAN, with centercaps -recetly purchased 225/50/16 Yokohama S-drive tires -A/C deleted -Wiring tucked in front fenderwells -upper pinch welds clearenced in front fenderwells -rolled fenders MAINTENANCE: -P/S pump -P/S hi-press line -P/S rack has been rebuilt (few years ago, no leaks) -P/S flush -PCV valve/hose -spark plugs -plug wires -cap and rotor -distributor cap o-ring -fuel filter -oil pump-front crank seal -distributor seal -valvecover gasket -rear crank seal -both coolant sensors -oil pressure sensor -new TPS -o2 sensor -coolant sensor/injector pigtails -belts -radiator hoses -thermostat -water pump -rear brake pads (fronts upgraded) -brake fluid (DOT-4) -trans oil -diff oil (royal purple) -front balljoints -inner/outer tie rod ends w/boots I'm SURE that I'm forgetting stuff here as well. I did so much it's hard to remember. Also this is not to mention all the little items like switches and small OE parts that I got to put everything back to how it's SUPPOSED to be... The ONLY mechanical/driveability/emissions/electrical issues with the car AT ALL are: -Timing chain rattles on start-up, nice and quiet once oil press builds up (timing chain tensioner bleeding down) -High flow cat is shitty at passing smog/causes intermittent code 32 (on freeway), you should get a good used OE cat or new OE replacement for smog -The horn button in the pics fell apart so there is no horn button (Ebay quality!!!) Also included with the purchase of the car will be: -JWT ecu for the singlecam -NISMO 2-WAY lsd IN PUMPKIN w/5-bolt axles + bolts The ECU is not installed because it needs to be sent to JWT and have the tune identified. If it's tuned incorrectly for whatever setup you want JWT can re-tune it for $100 and they will identify the tune for free. The diff is not installed because it needs new sideshafts. The PO ran it with loose bolts and bent the "ears" for the bolts a little. You could probably bend them back, but they're only the stock JDM 30-spline shafts and shouldn't be very hard or expensive to source. Pay my asking price and I'll have it smogged for you as well... PRICE: $4300 FIRM LOWBALLER SPECIAL: I decided to offer another deal for the lowballers out there. There will be some parts not included though. NOT included: -Nismo diff -JWT ecu -Tein strut bars -Nismo power brace -Cusco ladder bar -Urethane steering rack bushings instead of Yanack aluminum -Ichiba spacers -SMOG LOWBALLER PRICE: $3400 FIRM DOHC KA SWAP: I can also offer a dualcam swap with either deal for an additional charge of: $750 Last edited by racepar1; 11-05-2013 at 09:08 PM.. |
10-31-2013, 02:08 AM | #5 |
10-31-2013, 12:40 PM | #9 | |
GLWS Aron, hopefully it goes to a good home. Please don't sell to drift hipsters.
10-31-2013, 01:09 PM | #11 | ||
NOT parting this, BTW... |
