Old 06-24-2007, 10:49 PM   #1
nyrps13
nyrps13 is a well-known jackass
s13 tranny seal leaking help.
my rear tranny seal is leaking ,where the drive shaft connects to the tranny.. i wanted to know if it is the same seal as the K24 trannys or different. i have the SR tranny. If differ where can i find one?? (S13 SR20DET)
nyrps13 is offline   Reply With Quote
Old 06-24-2007, 11:37 PM   #2
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
It's the same.
mRclARK1 is offline   Reply With Quote
Old 06-25-2007, 03:38 PM   #3
nyrps13
thanks man....
Old 06-25-2007, 04:17 PM   #4
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
As previously stated, they are the same. Seals don't usually go bad.. Something makes them go bad. As was the case in my tranny, the rear bearing for the main shaft went bad, causing the seal to go bad. When you replace the seal, wiggle the shaft around. It should move, but just a little.
-Bart
DJ_Sunrise is offline   Reply With Quote
